diorama bases
    June 2006
diorama bases
Posted by Tankluver on Sunday, August 8, 2010 4:57 PM
If you use styrofoam as your main base should you glue it too a piece of plywoood?
    May 2005
Posted by hughes2682 on Monday, August 9, 2010 10:31 AM
I've used a urethane glue for the base I am currently working on.  No problems with adhesion!
Cheers
Dave
http://img.photobucket.com/albums/v317/Aaronw/Groupbuilds/ClassicAviationGB2010bomb.jpg
With enough thrust, pigs fly just fine.
Posted by HeavyArty on Monday, August 9, 2010 1:44 PM
I would.  Styrofoam isn't really strong enough to support much weight by itself.  A stained and sealed wooden base always add to the finished look of the dio as well.
    May 2008
Posted by Boba Fett on Monday, August 9, 2010 1:54 PM
definately. Unless it's a very small base for a vignette or something. It could bend, buckle, break, even chipped away without plywood. GO to home depot and pick up a bunch of the stuff for 2-3 bucks.
    March 2008
Posted by EasyMike on Wednesday, August 11, 2010 9:13 AM
Yes.  Styrofoam breaks easily.  It needs some type of support when used as a base.
Smile
