- Member since
February 2004
Backdrops,how to...for scale models.
Posted by JohnReid
on Sunday, November 13, 2011 6:23 AM
Building your own facades or backdrops are really easy things to do
using materials that are usually available to most of us.They are quite
cheap to build and require only hand tools to make.
Glue,cardboard,tongue
depressors , coffee stir sticks or small scale scale lumber is all you
need.The core could be plywood ,cardboard or foamboard or whatever, as
long as it is easy to cut,and does not warp with the use of water based
materials like carpenters glue(white or yellow) and acrylic paint.
You
will need a flat surface to work on and lots of #11 Xacto blades
(changed on a regular basis) and your basic core material to start
with.You will want to be able to easily change your design as you go
along ,if you wish to.Save all cutouts from doors or windows etc... to
use as perfect patches if required.I just usually tape any mistakes over
using the patches,because these basic shapes only act as a easily
worked flexible core for any brick or wood sheathing.The actual strength
will be in the sheathing material you put on or your basic framing.
Before
starting I will usually make a small scale complete structure,walls and
roof etc ,using cardboard or thick paper.It doesn't have to be to any
exact scale as it is only something that is used to stimulate your
imagination or work out a final composition.If you want to build it to
scale then that is OK too as you then will be able to take direct
measurements for the scaled up version.
I will be using lots of pics to illustrate how I do things and as little text as possible ,I find long texts can be boring .
Well
here goes ! I hope that you guys enjoy it.The thread will probably end
up a little long so please just bypass it if you don't want to read
it.Cheers ! John.
Guide my hand in your work today.JWRR. My goal in life is to be as good a person as my dog already thinks I am.
My Photoshop:
http://s6.photobucket.com/albums/y250/JohnReid/
