SAND
    March 2011
SAND
Posted by mike midnight on Thursday, January 19, 2012 10:53 AM
when i spread a layer of white glue to a base to make a beach or desert scene i sprinkle the sand on top then pat it down,  when it dries and i blow off the sand it is a lot darker than the actual sand color.  how do i keep the natural light color ????
Posted by VanceCrozier on Thursday, January 19, 2012 11:26 AM
"keep it a natural light colour".... if the white glue darkens the sand, you may have to start with sand that is lighter than what you want on the final product. Or, lay it down & paint it the colour you want. Other than that, changing adhesives maybe??
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2005
Posted by mfsob on Thursday, January 19, 2012 11:41 AM
I ran into the same thing, because using white glue, which is mainly water, will cause the sand to darken, Try using a spray adhesive, like the 3-M brand, or even something like misting watered-down whilte glue for a very thin layer of adhesive and adding another layer of sand on top of what you already have.
    February 2011
Posted by gunner_chris on Thursday, January 19, 2012 1:33 PM
Try painting the surface something like tan, and while wet apply the sand then?
    April 2004
Posted by vespa boy on Friday, January 20, 2012 8:06 AM
My guess is that the glue is covering the sand grains and affecting the refractive index between the air and the grain of sand. In my experience you can lessen this problem by diluting the white glue. Try a mixture of 25% white glue and 75% water. You may need several applications and its best done using a dropper bottle...research it on some model railroad forums...those guys know how to landscape.
http://public.fotki.com/nkhandekar
This ain't no Mudd Club, or C.B.G.B.,
I ain't got time for that now
    March 2011
Posted by mike midnight on Friday, January 20, 2012 2:06 PM
thanks everyone,  i will let you know what i did in a few days    mike
    January 2007
Posted by the doog on Tuesday, January 24, 2012 7:17 PM
Let the base coat of sand dry, then coat it with Testor's Dull Coat and sprinkle on a fresh, thin coat of new sand. It should retain its original color without problems.
    March 2007
Posted by bondoman on Tuesday, January 24, 2012 7:51 PM
All good advice. as a railroad guy, paint the underlayment a very light color, sift the sand on through a sieve into the wet paint. Put on another thin layer and seal it down with clear flat or dilute white glue.
The usual tools for railroad landscapes are a broad brush, tupperware and a mesh strainer like a pasta drainer, the wire kind. And misters from the plant store- cheap plastic ones.
Sand is cheap so practice is easy.
Also, use much lighter sand than the real thing. I used to run around collecting dirt from the area I modeled, but it doesn't look right on a base. There's a scale effect.
Arizona Rock and Mineral makes great stuff.
http://www.rrscenery.com/
    March 2011
Posted by mike midnight on Saturday, January 28, 2012 6:15 AM
as for the sand i used a fine sand for sand blasting, it is already strained, and the grains are much finer for small scale. for the modle i did it was cartoon style .the road runner and coyote, i painted the sand light mixed colors so i could start with a light base ,and try again but it came out so good i left it alone..  but the other dio is a serious one so i will give your a method a try...
    March 2011
Posted by mike midnight on Saturday, January 28, 2012 6:18 AM
the problem with spraying dull coat is the background and large rocks are in place to make natural drifts,, it would be a nightmare to try to tape everything...
