1/35 Marder I 39(H) Hotchkiss "Hit 'em when they slow down at the bend!"
    June 2012
Posted by ghostt180 on Sunday, November 18, 2012 12:06 AM
My first Trumpeter kit and had a few dramas with this one. Things needed trimming, instructions weren't the best in some steps, but got there in the end. Still have to reduce shine on figures and add ammo for the MG and what not.
21st Panzer Division somewhere in France 1944
Posted by tigerman on Monday, November 19, 2012 1:54 AM
Hi bud. Work looks great, but the pictures are small. Any chance of getting larger ones?
 Eric
    June 2012
Posted by ghostt180 on Monday, November 19, 2012 2:17 AM
Thanks Tigerman. Took the pictures with an iphone 5 which is all I have ATM.  I think I reduced the pixels too much in paintbrush. Will see what I can do!
    September 2006
Posted by Blitzwing on Monday, November 19, 2012 4:50 AM
It looks like you did a pretty good job with it. Some bigger pictures would be nice but you seem to have done pretty well with it. What sort of problems did you have with the kit?
URL=http://picasion.com/]
    July 2006
Posted by telsono on Monday, November 19, 2012 4:40 PM
Very good work on this. I had researched these some, they were the work of Major Becker of 21st PD. On many of them, the shield section on both sides of the gun had a wire mesh so that foliage could be attched to it. there is also one photo that hints at a unit insigna that was in the form of a triangle with 3 colors.
i11.photobucket.com/.../39H105cmLeFH18SfaufGeschut3.jpg
i11.photobucket.com/.../39H105cmLeFH18SfaufGeschut4.jpg
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    April 2012
Posted by PaperPanzer on Monday, November 19, 2012 11:14 PM
Overall, the dio is excellent. my only problem with it is that not all the figures are facing the same way, unless that was intended? ( I need to put down Shep Paine's book...Smile)
Auctung! Panzer!
- "And now for something completely different..."- Monty Python's Flying Circus
    June 2012
Posted by ghostt180 on Wednesday, November 21, 2012 2:06 AM
Maybe I am too used to using Tamiya, as this was my only Trumpeter build. Some trimming is required to make things fit "properly"  and gaps needed filling. The instructions weren't the best also, but I searched the net and found other people had the same issues.
I was the intention that the NCO with binos is scanning the horizon and not looking at what the officer is pointing at. However I see Paperpanzer's point...maybe someone should be looking at where he is pointing!! Would like to add a couple more crew as there were normally 5. Maybe a crew lifting ammo perhaps.
