Roads (again)
Roads (again)
Posted by Anonymous on Thursday, January 13, 2005 2:49 PM
What-ho chaps!
It's been an ashamedly long time since I've been on these forums, what with university and all these trivial inconveniences and now I've a little free time during my hols, I've reverted back to my trusty 1/35 WWII figures, dioramas in particular.
My incredibly silly question (as I've asked it before, about a year ago) is what can I possibly make a road of the non dirt variety out of? I've tried the old split pea method several times and I'm so cack handed it never works. The particular scenario I'm working on is based in a French town during summer so painting techniques may also be helpful. Bear in mind the area I have to cover is about 30x10 cm so I'd rather I didn't spend my 2 weeks free laying 1 mil cobblestones!
Thanks in advance,
Seb
Posted by Anonymous on Thursday, January 13, 2005 3:43 PM
check out plastruct.com.....they have all sorts of styrene with cobblestone patterns for roadways. and lots and lots of other stuff
Posted by Anonymous on Thursday, January 13, 2005 3:52 PM
Tamiya also offers sheets of different street surfaces, you simply glue them to your base.
Posted by Kelly_Zak on Thursday, January 13, 2005 4:15 PM
Kancali (www.kancali.com) make a series of rubber matt sections in several different patterns, you could always scratch as well. Take some plaster, make a form out of say some big building blocks or wood, and pour yourself a flat rectangle. you could make it as thick or thin (well not too thin), and when fully cured, scribe out the cobble pattern of your choice.
I've tried the Tamiya paper road sections, and they work great!
"There you go with those negative waves again!"
Posted by Anonymous on Thursday, January 13, 2005 6:22 PM
I have been meaning to try something. Maybe you could give it a go and tell us if it works.
My idea was to lay down a thick coat of thin pva glue and then pour some kind of bean, like a split pea or lentil and let it dry and dump the excess off. Then, grout it like ceramic tile with spackle or something water based, wiping enough off the top to expose the "stones".
Maybe a small short rice of some kind.
Posted by Anonymous on Thursday, January 13, 2005 6:47 PM
Thanks guys, there is one problem though, I have no idea where to get Tamiya sheets from, my local hobby shops certainly don't have them and I can't find hide nor hair of them on the net!
As for the lentil idea Hatewall, I've tried it a couple of times before and ascertained that it's perfect...if you're patient enough to lay every single tiny split lentil flat side down. I have the misfortune of choosing bigger scenes and therefore get stuck. Anyway, I better head off to bed now or I'll have red eyes in the morning!
Adios,
Seb
Posted by Anonymous on Thursday, January 13, 2005 7:11 PM
ah,... but thats good to know that it works.
Depending on the project, I may be able to tough it out.
Posted by Kelly_Zak on Friday, January 14, 2005 2:00 PM
Seb, try going to www.hobbylinkjapan.com and look under the listings for Tamiya, they will have the sheets there, and you can look at the different styles they have...
Posted by Anonymous on Friday, January 14, 2005 7:19 PM
Thanks KAzak, found them and all the related items. This is a goldmine of stuff! Thanks again,
Seb
Posted by Anonymous on Friday, January 14, 2005 9:16 PM
i built a diorama out of some pink insulation board, i used a hobbyknife to carve the road and add tracks. i then painted it. it turned out ok. here are the only pics i have cause i got rid of all of the ones of the dio it's self:
