Barbwire and Sandbags..........
Posted by Anonymous on Thursday, September 8, 2005 4:34 PM
How can i make good looking barbwire and sandbags for 1/72 scale.
any help would be good.
-SSpanzer,
    October 2003
Posted by rebelreenactor on Thursday, September 8, 2005 5:48 PM
Italeri make a kit with both of those in them in the same scale. I think its called battlefield accessories set.
John
    January 2005
Posted by hemble on Thursday, September 8, 2005 6:23 PM
Hi sspanzer
Yep the Italeri battlefield kit has sand bags in them but they are sought of rigid looking try using greenstuff to make your own that way you when you place them on top of each other they will look more realistic.
As for the barbed wire use black cotton glue it inplace using model glue and then once that all dries go over the cotton with superglue this will make ithard and then paint over that.
Ron
Posted by Anonymous on Thursday, September 8, 2005 7:49 PM
cheers for the idear on baebed wire ron it sounds like it might work,about the sandbags you say greenstuff what do you mean by that?.
-SSpanzer,
    January 2005
Posted by hemble on Friday, September 9, 2005 11:01 PM
Hi SSpanzer
Green stuff is a 2 part putty that you add together you can get it from Games workshop or any good hobby shop.
Ron
    January 2003
Posted by scotty on Saturday, September 10, 2005 3:03 PM
Ther's an explanation of how to make your own barbed wire on amourama.com.
Scott
Posted by Tinker on Saturday, October 22, 2005 1:53 AM
Scott,
That is a great way to make barbed wire. There's one little problem though. Two or three of the photos show the wire twisted in the wrong direction. All twisted lines from sewing thread up to and including the largest diameter cables use a right-hand twist. If you use a hand drill, run it in reverse to get the clock-wise twist.
" 'Polls' are surveys of uninformed people who think it's possible to get the answer wrong." ...Ann Coulter
Posted by Anonymous on Saturday, October 22, 2005 6:45 PM
Hey SS! I feel that at 1/72 you would not see the 'barbs' on the wire. I think a single strand of wire will do-the implication of a battlefield and a strand of wire will complete the illusion.
Posted by Anonymous on Monday, October 24, 2005 1:30 AM
FSM magazine had a multipage step by step instructions on making sandbags some time ago. Sorry but I have no idea of the issue or dates.
On rhe wire...soaking cotton thread in half water and half PVA (white glue , woodworkers glue, etc) and wait until it is dry enough to bend to shape works. This only works with cotton not nylon thread and some colouring will be needed to disguise the shiny result.
Finally barbed wire on battlefields was often placed directly off the roll so it has sort of a spiral / spring shape to it.
Good luck ,
Pete.
    October 2005
Posted by Huang He on Tuesday, October 25, 2005 12:13 PM
Use the table napkin paper the do-it-yourself
