Berlin Diorama 2
Berlin Diorama 2
Posted by Anonymous on Sunday, September 18, 2005 12:05 PM
Thanks for all the advice and suggestions in regards to the fire hydrant. I painted it red, washed it, and weathered it. I am not sure if it is accurate, but it looks good, and adds a little color to the diorama.
One more question- Does anyone have any suggestions on a material to use for power lines on telegraph poles. I tried using surgical suture, but it does not appear heavy enough.
Thanks again
EJH
    October 2003
Posted by rebelreenactor on Sunday, September 18, 2005 1:04 PM
How about regular wire?
John
    May 2005
Posted by terry35 on Sunday, September 18, 2005 4:30 PM
How about a light guage spring steel, should be available from an engineering supplier or jewelry supplier
    September 2005
Posted by Kykeon on Sunday, September 18, 2005 4:30 PM
Try using .020" electronics solder. It stays where you put it, unlike wire, string or other materials. A spool of solder, available at an electronics shop, will last several lifetimes worth of projects. Plus it is good for many other applications as well.
Posted by Anonymous on Sunday, September 18, 2005 6:05 PM
Try Using fine wire that comes looking like its cotten on a roll,its heavy cheap and will look good.
-SSpanzer
    May 2005
Posted by CDNTanker25 on Sunday, September 18, 2005 8:48 PM
mmm how about stretched sprue?
James on the bench: Merkava II With MCRS-20% Merkava IID 75% IDF Magach Batash
    July 2003
Posted by stukabomb88 on Sunday, September 18, 2005 9:23 PM
I agree, stretched sprue can be stretched, and shaped in any way, with a little practice.
"If you live for personal gain, you have lived in vain." -Devon OpdenDries
    October 2003
Posted by rebelreenactor on Monday, September 19, 2005 1:28 AM
streched sprue will be too light.
John
    May 2005
Posted by CDNTanker25 on Monday, September 26, 2005 11:11 AM
Reb you can stretch sprue to be any size... .
any thickness, you just need to regulate the strength and speed of your pull on both ends!
Posted by Anonymous on Wednesday, September 28, 2005 12:13 AM
Wink [;)]
Posted by Anonymous on Wednesday, September 28, 2005 7:59 PM
id get two thin wires and wrap them around each other, cuz powerlines are not just long wires, if u look at them youll see..
-DJ
