***Building Materials***
Posted by Anonymous on Friday, November 4, 2005 1:37 PM
Hey guys,
i am currently making a diorama where a building is sort of the focal point of the diorama, it is in 1/72 does anyone have any suggestions on what to make the buildin out of (if there are any others apart from plaster cast)
all help would be very much appreciated
thankyou
    June 2005
Posted by smokinguns3 on Friday, November 4, 2005 3:59 PM
I found this in the forum hope it helps ive heard of use foam board but have never tryed it my self
http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=51727
heres another
http://www.ehobbies.com/1000-0275.html
Rob I think i can I think i can
Posted by Anonymous on Friday, November 4, 2005 4:26 PM
Thanks, Thats a great help, got to try it out!
thanks again
    January 2003
Posted by gburdon on Friday, November 4, 2005 10:50 PM
Lone_Soldier
As you are in the U.K. you should be able to locate the two books I listed in the post quoted above.
Another material source you can use in 1/72 scale is cardboard from cereal boxes and different grades of paper. If you can locate the Architectural Modelling in 4mm scale book it is an excellent reference for building with cardstock and other materials like this.
I hope this helps
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
Posted by Anonymous on Saturday, November 5, 2005 6:33 AM
Cheers gburdon, i'm going to buy both of the books, thanks for all the advice
    June 2004
Posted by clfesmire on Tuesday, November 8, 2005 4:29 PM
Well Lone,
The building of a structure is your baby, choose the materials that suit you best. I have used styrene, cardstock, brass and wood for my 1/87 structures. Currently I am building a diorama that needed an old barn and decided to build it from wood. The roof is 600 grit sand paper. The folder URL below gives a very brief step-by-step and the finished product is at the end. Of course the books previously mentioned will be much more comprehensive and help much more than this I'm sure but until then.... Just click on the folder "dio build"
http://pg.photos.yahoo.com/ph/stryper50/my_photos
