Tile Grout as Snow
wes
    February 2006
Tile Grout as Snow
Posted by wes on Friday, February 17, 2006 1:54 AM
i was just wondering how to use tile grout as a medium to simulate snows in dioramas. how is it going to be applied. what are the procedures in using the given material. what material will be used to make it stick to the figures and the base.
thanks in advance
Posted by Kelly_Zak on Friday, February 17, 2006 9:03 AM
Wes, check out my dio here called "Abandoned?"
I used white tile grout for all of my snow(and all groundwork as well, but different shades of earth tones)
I used the sanded kind, found the non-sanded way too "soft" it was like flour...basically what I did was have my base, vehicles and figs ready to go, and I took a small cup and started pouring on the grout in sections to the base, shaking the can as I was pouring to level things out a bit. Once a section was ready, I took a small spray bottle of water, and lightly misted the grout, just enough to make the surface damp. I then took my big bottle of white glue/water mix, and started to add that to the grout. Now the grout already has binders in it, but I find adding the white glue/water makes it a stronger bond. I let it sit for about 10-15 minutes, then I add the vehicles, first making the tracks in the ground then setting it in place. For the figures, I added a little of the grout to the clothing, then just planted them into the grout. I keep a spare set of unassembled legs ready for adding footprints. Once you have everything in place, let fully cure for a day or two. If you find some dry spots, just go back and add some more white glue and water.
"There you go with those negative waves again!"
wes
    February 2006
Posted by wes on Saturday, February 18, 2006 9:54 PM
thanks kelly_zak, your idea was a great help, i viewed your diorama, it was amazing, you can truly feel the winter.  thanks again!!
    February 2006
Posted by starduster on Friday, February 24, 2006 10:29 PM
Tile grout is great for ground cover, I used it for my mars dio last year and with  styrofoam as a base it worked great, check it if you'd like.   Karl
http://pg.photos.yahoo.com/ph/brtfan001/my_photos
photograph what intrests you today.....because tomorrow it may not exist.
