Tiger scene
    February 2007
Tiger scene
Posted by T-rex on Thursday, April 12, 2007 5:20 PM
As the tiger progrest is improving and near completed I decided to show this fantastic model on a diorama, if you remember I said it was going to be base on a photo of my book but I won't make my tiger a taget practice for anti-tank weapons, but I have another idea, and not its not czechloviacia, think of this!
A Tiger 1 back from combat in summer russian 1944, with battle damage bullet holes on it (I can simply do this with a needel and pierce the tank at spots that are most likely to be hit) it's being exam to make sure its still functionnal, a german soldier will be talking to the commader of the tank right beside the vehicule, another commander in the tank turret hacht, and another figure at the back to check the exaust pipe. The dio scene will be a praire wilt maybe a tree and a stream, I have some spare bare wires that can be place and the tank tire tarck of coures.
I think this is a good scene cause it maches the camo of the tank that I will use my airbrush and it resemble alot like the photo, just diffrent propurs, the bullet damage is to show how tought the tiger is like these images of the website.
http://www.alanhamby.com/history.html
I just want your opinion of this? is it a good ideas
One last thing, this dio is also practice for the stream (which I learn from another forum) and most importantly, the grass which will prove to be a challenge, does anyone know how to do grass in a Dio?
Thats all for now thanks for your time.
Working on: Trumpeter SU-152 (1/35) Trumpeter E-10 (1/35) Heller Somua (1/35)
"The world is your enemy, prince of a thousand enemy. And when they'll find you, they will kill you... but they will have to catch you first ''
    January 2007
Posted by IYAAYAS on Saturday, April 14, 2007 8:00 AM
Well you've got a great idea, and it's a really good start, just a little advice:
1) By bullet holes, are you meaning large caliber rounds, cause a "bullet" would barely scratch the surface on a tiger.  It might do some damage to the zim, but not the armor.  Obviosuly the larger the caliber, the more damage it would make.  If you are placing holes in the tool box or other thin metal make sure you use a dremel tool on the inside to "thin" the area a little before peircing it, it helps to make the "hole" look more realistic.
2) Grass is fairly easy these days, many companies like Woodland Scenics make products that are very esy to use.  Just search you LHS or favorite OLHS for diorama materials.  The best sources are often ones that have a lot of model railroad stuff.  It is easy to apply, simply dilute white glue (Elmers type) with 50% water, then add a couple drops of liquid dishwashing soap.  The either spary it on with a cheap spray bottle, or brush it on using an old brush.  Before it dries sprinkle the grass, dirt, what ever around.  Wha-la instant grass!
You mentioned you want to do a prairie, sounds like a great idea with a lot of possibilities.  Just search for pictures of the plains of Russia, and you'll get a good idea of the colors of grass you'll need.
3) Water is also easy, the same company also makes instant water, that is very esy to use.  It can be found in the same section as the grass stuff.
Hope this helps a little...
    January 2007
Posted by the doog on Saturday, April 14, 2007 9:05 AM
Sounds like a pretty cool idea; I'd offer this thought though...place more focus on the fact that you want to show the toughness of the Tiger by having the two dudes by the side of the tank actually examining the shell hits; this will draw the observer's eye to what you're trying to emphasize. You might want to delete the guy "checking the exhaust"--it would seem to me that it might distract from your main theme (why is the guy checking the exhaust?Confused [%-)]) unless there's a shell hit ther--but then again, that being the Tiger's weak spot, it might not be plausible...? Maybe a grenadier with a bottle offering a drink of congratulations might add a whimsical and poignant touch? I would put the second "commander" (panzer crewman?) on the tank's deck either facing the "inspecting" guys, or have him nervously scanning the horizon with a pair of binoc's--this would add a "subplot" to the composition of the scene, i.e. "where'd that shot come from?!" Hope thi provides some inspiration!Whistling [:-^]
    February 2007
Posted by T-rex on Monday, April 16, 2007 10:03 AM
Glad that you ask that dog, first of all the tiger is almost complete just need to add forest green as camo and some weather, I have applie redbrown after a coat of dark yellow, only proble is the stripes are too big and should have reduce the size, well it still good, not bad for my first try, i'm really prode of myself.
The figure near the exaut pipe was origanly the gunner on the tank turret but due to his wrong position I wanted to place him behind the tank to show the back of the tank, it has the most assesories there, but I could place his on a hill lowering his binoc.
The bullet hole are large calebers (not anti-tank, that would just blow the tank up) are the tank is not in a battle scene he's back from a battle scene, but I could add a crew member helping out another wounded memeber from the tank.
I can't make the soldier talking to commander cause of the hach, its standing betwween them, but I can't make him standing up on the tank neither cause he's satnding too, it won't look good, maybe he could just be walking beside the tank where the bullets have hit, or at a point where I want the viewers to see the impressive tank.
At my local hobby shop Model land in calgary is a great place for model supplie, there are lots of figure kits that the possibiletise are endless, there a surviving panzer crew likt that could go with my scene (I know it panzer but its almost the same as the tiger crew) and some allies and axis tank supplie wich could be useful for that scene and my firefly scene.
Finally weather, I bought a weather kits which at first I didn't know what it was but its some powder set, I practise on another tank but didn't applie on it so good, How do you applie weather? and what weather would be good for the scene? I'm assuming green (for the foliage that the tank roll over) or weathed brown of dust brown for dirt.
    August 2005
Posted by sumpter250 on Monday, April 16, 2007 12:33 PM
   The Woodland Scenics "water"( in the bottle, not the meltable pellets) is an excellent product, but.....there is a learning curve. First, the product recommends no more than 1/8" depth, at a time. I'll talk about setting time in a bit. Second, the product is moderately thick, and has a tendancy to "climb" because of the greater surface tension. and finally, it "dries" flexible. The depth limitation, actually allows for the adding of detail (an eighth of an inch at a time). To insure the product is thoroughly set, allow about 5-7 days between applications. The "climb", can be reduced by thinning the product with water. This can be done by adding water, or by brushing water around the edges, where you don't want "climb". ***NOTE: adding water WILL cloud the product! You will have to wait until the product goes clear (it will.....in time, about 1-2 weeks, depending on the amount of water added) before adding more. As thick as this product is, it will find any way it can to "exit" the scene. Try to seal the pond/stream bed before pouring the "water", and put a drop cloth beneath the dio. It is a one part product (not like an epoxy resin), there is no foul odor, you can use this indoors, and not have to take a vacation while it sets. There is a second product, called "water effects", which can be used to create ripples/waves/turbulence/etc.  I have used this product, and would use it again.
   There is a two part system, called Magic Water, that I have heard good things about, but I haven't used it.so can't provide info about its use.
Lead me not into temptation ..................I can find it myself
    February 2007
Posted by T-rex on Thursday, April 19, 2007 4:48 PM
What about trees, what is the best way of making the most realistic tree in a dio?
And is the weather that I said in the last forum, is it correct?
"Finally weather, I bought a weather kits which at first I didn't know what it was but its some powder set, I practise on another tank but didn't applie on it so good, How do you applie weather? and what weather would be good for the scene? I'm assuming green (for the foliage that the tank roll over) or weathed brown or dust brown for dirt."
    March 2007
Posted by armornut on Saturday, April 21, 2007 12:23 PM
 Keep prcticing with weathering,its a subtle art but with dramatic effect. try to "overweather" with your pastels then "blend" it all togther with a wash or dullcote.you can use an old model and whatever color you have available 'til tour comfotable with the technique then apply that skill to your finished tiger.Keep in mind the time of year your showing(spring ~winter)this will dictate how dark or light your weathering will be. Also check out a construction site using heavy equipment,that may give you an idea of what, where, and how much to weather the mighty tiger.Happy modeling.
we're modelers it's what we do
    February 2007
Posted by T-rex on Monday, April 23, 2007 3:01 PM
I did practice on a body of another tank but it didn't show as good as I though. I try appling it by a brush but it didn't stick to it, also, the brush I use was a ox tail bush so the hair just fell off and stick to the tank. Are all weather powder dust, or some come in paint or any other form? Just about any hints on weather apply will help.
    March 2007
Posted by armornut on Saturday, April 28, 2007 10:31 AM
 Hey t-rex, testors modelmaster has a line of enamal paint with the following colors raw sienna(looks like dry mud),burnt sienna(rust),raw and burnt umber(both look like moist dirt or oil).there may be more but i've had good luck with these as well as pastel chalks.obviously the paint can be airbrushed or drybrushed.as an after thought pastels need a rough surface to stick to,i use an eyeshadow brush appropreaited from my wife to apply them,it sometime takes me several "coats" to obtain the look i want.also its a light touch much softer than drybrushing to apply but the pastels will take to the highlights or raised detail quicker than deep crevises.hope this point you in the direction ya want to go happy modelling.
    January 2007
Posted by Deputy_Brad on Saturday, April 28, 2007 2:03 PM
For your trees you have a few options. What scale are you doing too?
1. Premade trees - Probably the easiest way but also most expensive. Also they may be premade but still not look the greatest and usually require touching up. Painting of the trunk and highlighting the foliage.
2. Tree kits - Not as expensive. These are just bare tree armatures that you add foliage too. Theres many companys that make them. Supertrees by Scenic Express has some really nice kits but are more model RR suited as you get HUNDREDS of trees and it costs more than other kits. Check your LHS and you can find many tree making materials. Its mostly just clump foliages, lichens, polyfibre, and "fine-leaf foliage".You also need a good glue to work with. A very high-tack glue. I sometimes use superglue or a low-temp glue gun.
3. MAKE YOUR OWN - By far the best method, and the one I use the most. Go outside on a walk and pick up twigs and branchy looking plants. Go out into the garden and look at the plants and pick ones that may suit your needs. Use twisted fine gauges of wire then paint over them with some sort of mix of plaster/flour and water/glue then paint. For foliage you dont have many options other than going to your LHS and buying different types. I highly recommend Woodland Scenics "fine-leaf foliage" although you will pay a bit more than for regular foliages. Use fine scenic turfs colours such as burnt grass, yellow grass, and various shades of green to highlight. Sprinkle it on top sparingly.
It all depends on what kind of trees your trying to model, your scale and your season. Check out this site for scenery help. Its a model RR site but its great for that kind of stuff. You can find all sorts of tutorials on it and by using google or asking around at hobby shops.
www.nscale.net
My real name is Cam. Interest: anything 1/72, right now mostly sci-fi and modern In progress: 1/72 Sci-fi diorama (link in my web) 1/72 Leopard 2A5 1/72 APC Conversion to a MEGA DESTROYER
    February 2007
Posted by T-rex on Monday, April 30, 2007 1:59 PM
It's a 1/35 scale, scene, probaly summer.
I only know one way of doing home made trees, start by finding twigs and small branches and cover the tip with liquid glue, them place them in static grass, wait till there dried then spray the leaves with forest green, (depending on season) finally the trunk is color brown. simply pock them in the base before the grounds work dries, or make a hole and drill them in place.
Its the grass the problem, I can't simply place static grass over the grounds work, its too small, it will look too fake, it needs to be longer and more notice (if you know want I mean).
The scene is supposde to be the battle of kursu, I'll do my best on it.
    February 2007
Posted by T-rex on Monday, May 7, 2007 2:19 PM
Ok, now its time to start on it, I bought a wooden base, styrofoam, plaster and some bushes and static grass, I've also got some earth brown acylic paint and a new air compresseur to help me out. I still need some groundswork but I don't know what it is or where to get it? didn't see it at my hobby shop. I do have a weather set which is powders dust, and there is a color call dirt brown, if I applie this well it will make a realistique dirt for the scene. Any more advise.
    January 2007
Posted by Deputy_Brad on Tuesday, May 8, 2007 12:30 AM
I dunno using weathering powders for ground cover is a good idea if you have a large large amount and money isnt an issue, but mostly save it for your models not ground work. It comes in small quantities and is pricey to cover a large area probably. If you have a paypal account you can buy scenery supplies off this site for cheap www.cchobbies.com . Or you can ask your LHS about them. Most hobby shops carry ground work materials. The main company is Woodland Scenics for scenery materials and Scenic Express. You can also try sifting dirt, although it is a good idea to bake your dirt in an oven to kill the unwanted. Be sure to remove any wood particles from the dirt before hand. The baking kills off germs which live in the dirt which could be hazardous to your health. Also old cushion foam can be ground up in a blender with water and dyes or paints to make your own ground foam. The advantage of this is you get your own variety of colours and its WAY cheaper than buying it plus you get a lot more. There is also spices and herbs which can be used sparingly for accenting you scenery. Break open some tea bags and spread around for fallen and dead leaves. It works great because (surprise, surprise) ITS DEAD LEAVES. These are just a few suggestions theres many many options. If you give me specific questions as to what you want to model such as fresh soil, dead grass, sand, dirt just ask and we can give you a more specific answer on how-to.
    February 2007
Posted by T-rex on Friday, June 1, 2007 10:00 AM
The scene that I was trying to copy was this one.
Close up, you can see this is a tiger.
But I think that those soliders are americains testing new anti-tank bazooka, I refuse that my tank get blow apart.
Posted by Anonymous on Friday, June 1, 2007 7:38 PM
The soldiers in that pic are German - judging by their Kragenspiegel they are from an SS unit.
    February 2007
Posted by T-rex on Tuesday, June 5, 2007 9:43 AM
Kragenspiegel?
SS unit?
    November 2006
Posted by ww2modeler on Tuesday, June 5, 2007 10:16 AM
I think that the Kragenspiegel is the SS unifrom or part of it. The SS was Hitlers elite Panzer arm. The SS were "loyal" fighters that were charged with commiting war crimes. The Malmedy Massacre, the French town, And numerous atrocities on the Eastern Front. Just google it and you'll find a ton on them.
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
Posted by HeavyArty on Tuesday, June 5, 2007 2:45 PM
That is really a biased answer.  The SS were considered elite fighters who were used for special missions and standard combat operations.  They committed no more or no less atrocities than any other unit.  They were the German WWII equivalent to Army Rangers or NAVY SEALs, etc.
    February 2007
Posted by T-rex on Tuesday, June 5, 2007 3:33 PM
I think I know who they are now, they have a unique camo uniform, but the figure aren't the SS, its mostly the Enviroment that I was trying to replica.
Now back to the tiger,
There's has been a few change in plans.
First due to failer of camo I can't get it right the tiger can't bet in a fegitaqted enviroment like my picture.
Second right now the tiger is in north afican campaing outfit, which is just dark yellow, but it won't be a supreme dio in the middle of a desert.
What could be simpler and better is just paint him one last time in german grey and converd it into a early tiger in a german town, but if I add another coat of paint it mit ruin it even more.
What ever outfit it would have would madder which scene it goes. So far I have the wooden base and I'm cutting the styrofoam for the hill, but what can I use to stick that all to the groundwork, Plaster mixte with white glue?
    November 2006
Posted by ww2modeler on Tuesday, June 5, 2007 3:53 PM
Desert dios can be better than others. It doesn't matter what setting it is. Its the skill. I like desert dios because they draw attention to the focal ppint. The tank. putting another layer of paint on would make it look thick. You should remove the paint if you were going to do that.
David
On the bench:
Posted by m1garand on Wednesday, June 6, 2007 7:36 AM
Germans used Grey Colour at the earlier part of WWII and then changed colour to Dark Yellow.  Dark Yellow wasn't just for North Africa.  Dark Yellow was used as base colour for German vehicles and then camo was applied by field crew.
    November 2006
Posted by ww2modeler on Wednesday, June 6, 2007 11:46 AM
HeavyArty, sorry, my mistake. Thanks for correcring me.
David
On the bench:
    February 2007
Posted by T-rex on Wednesday, June 6, 2007 1:19 PM
I'm still alittle confuse of how to do the dio itself, I've got the base, and cut some syrofoam for elevation but I need to applie something to cover it all up to make it look like one piece, its that step before groundswork.
Still stuck on the grass but useing moss can look realistique too.
    January 2007
Posted by Deputy_Brad on Wednesday, June 6, 2007 5:49 PM
Plaster of paris works well and its all I really use for ground work. You can buy it pretty cheap at any Home Depot or department and craft store. I paid about $13 for a 1 Kg box of it
Also for grass try buying some faux fur. You can get it in a sheet and it comes in a variety or colours. It looks like a field of grass when glued down and properly trimmed and accented.
    February 2007
Posted by T-rex on Wednesday, June 6, 2007 8:59 PM
I Know! Great deal! best offer ever, they even sell it already mixte with water, I've use it to make molds of the czech building, which mit be convert into german or russian.
Already the building assesories are done.
But to make the mixte sticker, I'll mixte white glue, it should help, and best of all, any srapt drie plaster can be use for rubbel. thanks!
 I learn that almost anything can be use for dios, for instent, you know that moss they sell at pet shop for reptials to make the cage more natural, it sort of looks like grass, I'm sure that can be place in the dio as grass, and for trees, no problem, branches for chamelions which added leaves can look fairly realistique is propely ajusted.
    February 2007
Posted by T-rex on Thursday, June 7, 2007 9:10 PM
Wheter its the sahara desert or the russian winter, the tigers there, so the scene are endlist, but thing aren't doing intirely as plan, so many ideas but so little skill.
Here's some photos of tigers, and tell about the czech building above.
http://www.alanhamby.com/gallery.html
And is this a mold or a pieces?
    August 2005
Posted by Phil_H on Friday, June 8, 2007 8:16 AM
It's the actual piece, made by a process known as vacforming. You need to cut the parts away from the backing sheet, sand the edges flush where they join other parts, open up the windows, doors etc. While you can use it as a mould, the details will be softer because the detail side is the outside.
    February 2007
Posted by T-rex on Monday, June 11, 2007 9:57 AM
After whatching a DVD of woodland scenic "the clinic" I now know the basic of m,aking a dio, and its alot easier that I though, I'm now more determine to do one than ever!Big Smile [:D]
Posted by T26E4 on Saturday, June 16, 2007 11:12 AM
hi TRex: after reading thru this thread, I'd like to add one item.  I don't know if you're still going to do this or not but it's in regards to your idea for damage on the Tiger.  A big caliber high explosive round (17cm or larger) would crack the thinner armor and kill everyone inside.  Smaller stuff would just scrape the dense armor , knock off equipment, possibly injure the occupants -- but there wouldn't be any penetrating hole.
Rule of thumb: penetration =  death or serious wounds.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    June 2007
Posted by Nick Nasta on Wednesday, June 27, 2007 2:18 PM
There are some great looking Tiger 1 dioramas on www.battlesceneproductions.com
Dioramas Dedicated To All Veterans, Past & Present
