HELP!!!!
mmc
    February 2007
HELP!!!!
Posted by mmc on Saturday, August 25, 2007 11:15 AM
I am just about to start my next dio, and i was wondering if anyone could help me with a couple of things. First has anyone used balsaboard for base building? And do i need to seal the board before i start building my dio. Hope this makes sense!!! many thanks
    August 2006
Posted by IanIsBored2000 on Saturday, August 25, 2007 11:53 AM
Balsa board is pretty thin and flimsy I think.  Great for scrathcubilding diorama parts, not so great for supporting heavy building materials, ie; clay, plaster, dirt/wahtever else you use. Other members can probably help you more. Smile [:)]
-Ian
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
    May 2007
Posted by Sic Semper Tyrannis! on Saturday, August 25, 2007 3:10 PM
Balsa is a no-no in my humble opinion. I have luck going to the local hardware mega-store and picking up the smaller scraps of lumber. A quick sanding, staining and polyurethane coat and you are ready to go!
SST
On the losing end of a wishbone, and I won't pretend not to mind. ----------------------------------------------------------- 1/35 Dragon SdKfz 251/1 sMG Various 1/35 Figures 1/35 Dragon Stug III Ausf B. (Balkans)
    January 2007
Posted by the doog on Saturday, August 25, 2007 11:46 PM
DEFINITELY SEAL the wood with a good water seal before you start, or you'll warp the base with your ground material--cellluclay, plaster, whatever...all your hard work for nothing! I give mine TWO coats just to be sure.
Balsa is definitely OUT as a choice for base, too. Too porous, too easily breakable, and too easy to bend and deform. Opt for a more durable wood.
mmc
    February 2007
Posted by mmc on Sunday, August 26, 2007 3:12 AM
Thanks for all the advive, going to pay a visit to the local hardware store, thanks again
    January 2007
Posted by IYAAYAS on Sunday, August 26, 2007 6:36 AM
are you talking about balsa foam?  I think the foam will be ok, but do not use the "wood" as it will not support the weight.
http://www.balsafoam.com/balsafoam/default.asp
http://www.dickblick.com/zz331/11/
mmc
    February 2007
Posted by mmc on Sunday, August 26, 2007 12:13 PM
hi iyaayas, it is the wood but its sandwiched between two layers of a fibreglass type material, after doing a bit of research, ive found its the same stuff surf boards are made from
