dragos wrote: |
SteveM wrote: | dragos wrote: | If Celluclay is not available in the area, what other material/mixture do you recommend? |
You could always mix sand with paint, glue and water, If you want to add natural soil for texture, there ain't no law against it |
Thanks for the tip. What kind of glue, I suppose it's not the same as used for styrene. Would acrylic paints work? Thanks for your time! |
Just use Elmers /water mixtue. Not too thin or, like Aj said, it'll really flatten. Create some topography by gluing styrofoam to the base first. Small hills, or build up a road.
Use cheap acrylic paint like Anita's or the like. Cheap at Hobby Lobby or Michael's. I'd get Burnt Umber, Coffee Brown, earthy colors. You don't need much in the mixture, you could always paint it when dry.
Just to clarify, the dried result sholudn't be left alone... you'll apply dirt, dust, grasses. You're just providing substrate.
Steve
