Atlas ICBM, something different, FINISHED
    January 2003
Posted by yardbird78 on Sunday, August 3, 2008 10:14 PM
I worked on the Atlas F ICBM at Dyess AFB, Texas, in 1964-65 as my first assignment in the USAF.  I recently came across a 1/72 Anigrand resin kit of the Atlas that can be done as an A, B, C or D model.  I wanted to modifiy it into an F model, but found this to be totally non feasible.  It would be about like trying to modify an F/A-18 Legacy Hornet into an E or F Super Hornet.
I have found several major errors in this kit that will have to be corrected at the beginning.
1. The full scale Atlas had the LOX & RP-1 tank section made out of stainless steel that was only a few thousandths of an inch thick.  Essentially just a big metal balloon.  The model has panel lines around the circumference of the tank that would scale out to about an inch deep.  The first picture shows them with one side filled and the other side already sanded down.  The sanded down half is the belly of the missile and the unsanded half is the top.
2. The long pipe in the 2nd picture is the LOX transfer line from the LOX tank in the upper part of the missile down to the engines.  The instructions show this installed on the belly side when it should be on the top side.
3. All three nose cone options have huge, vertical, sawtooth striations all the way around.  This is correct for the early versions with a test payload.  The RV adapter for the ICBM had a smooth finish.
I got the panel lines filled in and sanded, then when I was trying to line up the two tank halves, I busted a big chunk out of one half.  You can see the irregular line in the first picture where I patched in back together.  Both pictures show the horrible fit of the two halves.  I have them glued together at the bottom and just sitting in the skirt section which is also glued together.  I had to place a scab patch inside the tank halves and will slowly glue them together from the bottom towards the top.  The fairings on the skirt over the booster engines have a horrible gap and the RV adapter doesn't fit very well either and both areas will need some work.  This is my first all resin kit and I am certainly NOT impressed with it.
Darwin, O.F.  Alien [alien]
I probably should have posted this over in rocket & space section, but it seems the traffic level over there is about the same as the number of pedestrians walking across Death Valley.
The B-52 and me, we have grown old, gray and overweight together.
    September 2003
Posted by Daywalker on Sunday, August 3, 2008 10:17 PM
Darwin-
Looks like you have your hands full on this one!  The fit looks terrible in the photos!  Hopefully, you will be able to tame that beast. Thumbs Up [tup]
Frank
    March 2004
Posted by subfixer on Sunday, August 3, 2008 10:19 PM
I wonder if you could also post this in the armor forum as it is a type of artillery you might say.
I'm from the government and I'm here to help.
    January 2003
Posted by yardbird78 on Sunday, August 3, 2008 10:24 PM
Uuhh, 9,000 miles is what you call REALLY LONG RANGE artillery.  I will post it over there.
    February 2005
Posted by RadMax8 on Sunday, August 3, 2008 11:44 PM
Pretty cool subject, Darwin. Sorry to see it's giving you such fits.
    January 2003
Posted by yardbird78 on Wednesday, August 6, 2008 1:06 PM
The first two photos show the overall missile after I managed to get the tank halves mated together.  I had to heat the resin in pretty warm water and then super glue them together while holding quite a bit of pressure until the glue set.  The RV adapter still needs some work to get it to fit correctly.  I added the tapered fairings to both equipment pods on the sides and filled in the canyon, (gap), on the engine fairings.  The three little gizmos in front are the exhaust bells for the engines.  The big pipe on the side has two functions.  The bottom end fits into a connection in the silo and is the LOX fill & drain valve to get liquid oxygen into or out of the upper tank.  It also serves as a means to get LOX from the tank to the engines during launch.
These two photos show the gross mis-alignment of the joint between the tank section and the booster skirt.  The green T-square is parallel to the bottom of the tank section and you can see how much it angles off to the side.  It wasn't feasible to square up the bottom of the tank section, so I had to sand the skirt section to match the angle.  You can see that in the second photo.
    July 2003
Posted by KJ200 on Wednesday, August 6, 2008 3:50 PM
You don't see one of those every day on the boards, and judging by the fit I can see why.
Great to see something totally different, and you look like you've mastered that bad boy!
Karl
    July 2007
Posted by Moon Puppy on Wednesday, August 6, 2008 4:00 PM
What I don't get, how you can remember the details that you do! I can't remember what I did for lunch yesterday!
Remember, we are told Post Counts don't matter! (unless it's really high)
Modelers' Alliance
    November 2004
Posted by brain44 on Thursday, August 7, 2008 9:56 AM
I must say, Darwin, you certainly qualify for the title of "Master Modeler"! I have had similar experiences with short run kits that often ended up being introduced to the wall paper at near Mach 1! Angry [:(!] I often wondered what Anigrand quality was like, now I know! Disapprove [V]  At any rate, you are certainly whipping the beast into submission, my hat is off to you!
Brian   Cowboy [C):-)]
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." John Bernard Books (The Shootist)
    January 2007
Posted by trexx on Thursday, August 7, 2008 5:11 PM
Very compelling project!
Super-Neat-O! I'd sure like to see it finished...
    January 2003
Posted by yardbird78 on Saturday, August 16, 2008 9:44 PM
I finally got this thing beat into some semblence of a decent model.  As noted in the earlier posts, I had a LOT of trouble just getting the basic pieces lined up and glued together.  Changes to the kit include:
1. Move the LOX fill & drain pipe from the belly to the top
2. Add the LOX overflow vent to the RV collar
3. Add the reinforcing ring around the base of the RV collar
4. Reshape the RV collar & remove the ribs
5. Reshape the vernier engine nozzles
6. Correct, or at least try, the grossly misaligned mating ring between the tank section and the skirt section.
7. Smooth out extremely rough surfaces and remove assorted small blobs of resin.
8. Cobble together all of the decal markings from the spares box. The only thing in the kit was two very undersized national markings
The Re-entry Vehicle or Warhead contained the 1.4 MegaTon nuclear weapon inside a metal shell and was covered with a white ablative coating. (similar to the white coating on the X-15 for a few flights).  The RV adaptor collar was made of aluminum and had the LOX overflow vent coming out the side.  Photos of a fully fueled Atlas show a large plume of what looks like smoke coming out this vent.
The main body or tank section was made of stainless steel and appeared as a polished surface.  The pointed equipment pods on the sides and the covers over the engines were made of very heavy fiberglass and painted aluminum color.  The main portion of the skirt was aluminum and the engine bells were a metal alloy that looked like magnesium.  The large, bent tube coming out the bottom of the skirt was the RP-1 (fuel) fill and drain valve.  Comments welcome, pro or con.
More photos of the Atlas ICBM.
    September 2003
Posted by Daywalker on Saturday, August 16, 2008 9:57 PM
Well done Darwin!  Judging from the fit issues you were dealing with, I figured it would be a while until we saw this one finished.  Nicely done, doubt if we'll ever see another of those 'round these parts. Thumbs Up [tup]
Frank
    June 2004
Posted by phoenix7187 on Saturday, August 16, 2008 10:04 PM
Looks great, I build rockets as well. The extra work you did shows, it really payed off. between ther mods and the fit issues you manged to make a winner out of her. If I remember correctly that a single warhead like the minutemen  I and II vs the minuteman III which could thorw three MIRV at hardended targets.
Stan
    August 2006
Posted by texgal45 on Sunday, August 17, 2008 11:35 AM
Now that certainly is different!  You did an excellent job, especially considering the difficulties that you had with the parts fit.
Grandma L
bred, born & raised in North Texas, now displaced to Yankee Land
    February 2005
Posted by RadMax8 on Sunday, August 17, 2008 11:38 AM
Great work Darwin. With those fit issues, your metal finish is outstanding. Very cool subject, I hope people build more!
    February 2007
Posted by Luftwoller on Sunday, August 17, 2008 4:01 PM
Wow Darwin, i dont know how i missed this 1st time round. I love wierd, strange and odd. This ticks all the boxes. It looks like it was a Pig as well. Looking at the finished pictures youd never guess you had any issues with it. Top marks fella. I love it.
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    January 2003
Posted by yardbird78 on Monday, August 18, 2008 11:59 AM
The Atlas D, E & F, the Titan I and II as well as the Minuteman I all had a single warhead.  I am not sure, but I think that the Minuteman II had 3 MIRV's and the Minuteman III had even more.  The Peacekeeper that replaced about half of the Minuteman missiles had up to 10 MIRV's.  The Atlas F that I worked on in '64-'65 had the ability to store two separate targets in the guidance system, but the launch crew had to select either A or B before launch.
It is really amusing to me to think about the computer that was an integral part of the guidance system on the Atlas.  It was a big cube, about 3 feet on each side that weighed a couple hundred pounds and all it could do was add, subtract and multiply.  There were 3 accelerometers in the gyro platform that fed information for each of the 3 axis (pitch, roll & yaw), to the computer and it figured out where the missile was at that moment and where the warhead would impact if cut loose right then.  When the results of those calculations got to a certain point, the BECO signal was sent for Booster Engine Cut Off and the skirt with the two booster engines was separated from the rest of the missile.  A little further into the flight, the SECO signal for Sustainer Engine Cut Off was sent and then when the computer figured the RV would impact close to the target coordinates, VECO or Vernier Engine Cut Off was sent, the arming signal was sent to the RV and it separated from the missile and went it's merry way.  If any of those events did not occur within a certain time frame after launch, the arming signal was blocked and you wound up with a very expensive rock.
An Atlas moments after launch.
An Atlas F without RV, sticking it's nose out of the silo.
An Atlas F at an operational silo.  It looks ready to launch, but it is probably just a PLX or Propellant Loading Exercise with a dummy RV.
    January 2007
Posted by trexx on Monday, August 18, 2008 12:20 PM
Excellent! Well done!
Your comments and notes are interesting too.
    September 2003
Posted by mojodoctor on Monday, August 18, 2008 10:23 PM
Outstanding job here!
You've captured the vehicle nicely, and have done an excellent job with the parts you have before you.
My dad was the technical illustrator for Aerojet General (Sacramento Division, both liquid and solid propulsion sectons) where these engines were built from 1960 thru 1993, and I can tell you that this model would serve well in their display. Be proud of your work and give yourself a big slap on the back!
Matt Fly fast, fly low, turn left!
    January 2003
Posted by yardbird78 on Monday, August 18, 2008 10:24 PM
I received a PM asking me where the silo in photo #3 is located.  It is from the 577th Strategic Missile Squadron, site #11 at Willow, Oklahoma, northwest of Altus.  While I was trying to figure out that answer I was jotting down some other miscellaneous BS about ICBM's and came up with the following.
All of the Atlas D, E and F silos still remain, although most have been gutted for scrap metal. The 72 Atlas F vertical silos were mostly gutted and then mother nature filled them with water. I think that all of them are now in private hands and a few have been cleaned up at least enough to enter them without killing yourself. The Launch Control Centers on several have been turned into extremely neat underground homes.
The 2 Atlas D bases with 3 sites each were at Offutt AFB, Omaha, Nebraska, and FE Warren AFB, Cheyenne, Wyoming. Each site had 3 missiles in individual above ground, horizontal coffins.
The 3 Atlas E bases with 9 sites each were at FE Warren AFB, Wyoming; Fairchild AFB, Spokane, Washington; and Forbes AFB, Topeka, Kansas. Each site had one missile in individual ground level, horizontal coffins
The 6 Atlas F bases with 12 sites each were at Plattsburgh AFB, Plattsburgh, New York; Lincoln AFB, Lincoln, Nebraska; Schilling AFB, Salina, Kansas; Altus AFB, Altus, Oklahoma; Dyess AFB, Abilene, Texas; and Walker AFB, Roswell, New Mexico. Each site had one missile in individual below ground, vertical silos.
4 Atlas F sites were destroyed by accidental explosions during PLX's, one at Altus and 3 at Walker.
Vandenburg AFB, California has examples of all of the various ICBM's.
53 of the 54 Titan II sites at Little Rock, Arkansas; Wichita, Kansas and Tucson, Arizona were deliberately destroyed with large amounts of explosives to keep the Russians happy. One south of Tucson has been kept intact for a museum.
Titan I squadrons were at Ellsworth AFB, Rapid City, South Dakota; Lowery AFB, Denver, Colorado; Beale AFB, Marysville, California; and Larson AFB, Moses Lake, Washington, and have all been pretty well stripped out. Ellsworth, Beale & Larson each had three sites with 3 missiles each stored in vertical, underground silos. Lowery had six sites with 3 missiles each.
For some reason, the Titan I sites seem to have developed more contamination and are LETHAL to anyone entering them without full self contained breathing apparatus. It is a phenomenon similar to what happened to the ships sunk at Pearl Harbor. The water combines with trash and debris and forms cyanide gas.
Da _ _, once I get started, the BS just keeps rolling along!
    February 2004
Posted by dhenning on Monday, August 18, 2008 10:59 PM
My dad was a crew chief ion the Titan II n the 308th SMW at Little Rock.   I have been planning and hording bits and pieces to someday build a 1/144th cutaway of a Titan II silo.  Also hanging on to two "All Systems Are Go" Atlas/Mecury kits from Revell (the reissues from the 90s) with the launch gantry.  Have been dreaming of making an Atlas D in a coffin launcher out of them.
If you are interested in ICBMs, I highly recommend this website:  http://www.siloworld.com/
Fantastic collection of photos, drawings, tours, etc. for all ICBM systems.
Great build of a challenging kit.   I thought about ordering the 1/72 Titan II from this company, but after seeing the photos-I'll pass!
    November 2004
Posted by brain44 on Tuesday, August 19, 2008 10:02 AM
Now that brings back childhood memories!  I clearly remember the Atlas site at Sugarbush, NY (Plattsburgh AFB remote site) and the awe when those big doors opened and the missile rose up against a clear blue summer sky,  We always wondered if this was going to be the real thing in '61 or just a test, but the vapor drifting off the side of the missile made us all nervous!  It was a marvelous sight!  I understand that the site is in private hands now, having been partially converted to underground living quarters and dead storage for possibly record archives.....thanks a million for the background info!  Were you ever stationed at PAFB?
    January 2003
Posted by yardbird78 on Tuesday, August 19, 2008 11:07 AM
I was stationed at Dyess AFB, Abilene, Texas.  I was never stationed at Plattsburgh.
A recent development in the history of Atlas sites: http://omaha.com/index.php?u_page=2798&u_sid=10408219
Never saw anything about those accidental explosions in the media, many people killed or injured?
IIRC, there was one fatality and a small number of minor injuries total for all 4 accidents.
While I was in Tech School at Sheppard AFB, the instructors conducted a safety demonstration about the hazards of mixing LOX and any petroleum based product.  LOX and oil together form a gel that is not hypergolic (explodes on contact), but it is MUCH more unstable than nitroglycerin and will detonate from the slightest physical or electrical shock.  They took a 1 oz dixie cup and put ONE TABLESPOON of LOX and TWO DROPS of 3 in 1 OIL in the cup.  They then dropped a 5 pound lead weight down over a guide rail onto the cup.  The force of the explosion blew the lead weight several hundred feet into the air.  Can you imagine the force of the explosion when several thousand gallons of LOX and RP-1 fuel get together inside the silo and detonate?  One of the accidents, I think at Walker AFB, happened with the silo doors still closed.  One of the 135 TON concrete doors was found about a quarter mile away.  Chicken Little said, "The sky is falling, the sky is falling!"
    January 2003
Posted by yardbird78 on Tuesday, August 19, 2008 11:08 AM
This is a photo of an Atlas F just seconds after launch at Vandenburg AFB, California, and the BEGINNING of an explosion that totally destroyed it.
The rectangular silo door is clearly visible under the missile.  The missile is centered over that door at the start of the launch and SHOULD stay that way.  It is obviously displaced to the right.  Notice the exhaust plumes from the two vernier engines on the sides.  The right one is pushed down close to the missile and the left one is stretched out, again indicating the missile drifting to the side.  The blast/flame deflector is to the left, so nearly all of the, "hell, fire and brimstone" from the engine exhaust should be going to the left.  That huge plume of yellow/orange fire to the right is NOT supposed to be there.  Apparently there was a major rupture in the tanks and the LOX/RP-1 fuel has mixed together and has ignited.  I suspect the range Safety Officer has initiated command destruct which was a mechanism that slashed the bulkhead dividing the two tanks and caused the explosive destruction of the missile.
    January 2007
Posted by trexx on Tuesday, August 19, 2008 3:45 PM
I was born and raised in Sacramento California and have fond memories of Aerojet noise.
(1967-1975) Often, a sonic vibration would eminate from everwhere, but mostly the from the ground. Like a short-wave Earthquake. Suddenly everything would instantaneously shake at a high frequency. Most noticeable is window glass as it shook within the frame. Every window, every frame everywhere... just shaking like mad. Then as suddenly as it started, it would stop, cease... to quiet and gradually birds would begin to chirp again.
For years and years you could see "rocket" stands and apparatus out in the grounds near Aerojet proper. They're gone now. Now it's condos. A lot of condos.
    March 2007
Posted by JMart on Wednesday, August 20, 2008 12:17 AM
I just found this thread.. what a great build, impressive WIP blog and loads of GREAT infomation! Thank you for taking the time to post all that, truly an educational experience...
    July 2004
Posted by mucker on Wednesday, August 20, 2008 10:06 AM
Darwin, that's a neat, unique build there. THe finish came out great. It must be nice to have such a rare model in your display case....I'm sure it shows well. Very impressive in size,. too
    October 2003
Posted by ModelNerd on Wednesday, August 20, 2008 1:04 PM
Now there's something I don't see every day! Most impressive. Reminds me, I think I got a Revell V2 kit stashed around here somewhere.
Great work!
- Mark
    March 2007
Posted by MattSix on Wednesday, August 20, 2008 3:52 PM
Nice work! Thanks for all the background info, too!
A really great presentation all around!
    January 2003
Posted by yardbird78 on Thursday, August 21, 2008 12:22 AM
These are a couple shots of full scale missiles.
This is the # 4 launch of an Atlas A on June 11, 1957 from Launch Complex 14 at Cape Canaveral.
This the # 6 launch of an Atlas A on September 25, 1957 from Launch Complex 14 at Cape Canaveral
