aides in painting canipoes?
    November 2003
Posted by GA.modelmaker on Friday, November 14, 2003 11:05 AM
hi folks been away to long. and i was wondering has thier been any adies in helping you paint the outside of canpioes?
Posted by Swanny on Friday, November 14, 2003 12:22 PM
Try the Black Magic line of masks availible from Meteorprod.com
    July 2003
Posted by KJ200 on Saturday, November 15, 2003 2:41 AM
Or if you are cheap like me......
......mask of the vertical glazing bars first, as this is easier than masking each panel individually, and then paint, starting with the interior colour first, before applying the outer colour.
Once all the verticals are complete, do the horizontals, and so on.
it is time consuming, but with a little patience produces a very neat canopy.
This isn't my idea, I got it from 'Eagles Wings', by Nicholas Wigman.
Karl
Posted by Abastyr on Saturday, November 15, 2003 7:45 AM
I like using Parafilm. When stretched, it will adhere to any plastic surface, you can cut away any panel lines, or whatever, than paint, than peel off the remaining Parafilm, which leaves no left over adhesive for a perfect looking canopy.
    September 2003
Posted by engstrome on Saturday, November 15, 2003 9:19 PM
Second on the Parafilm. Good stuff. Cut it with a curved blade instead of a #11 for the best effect
VB, E
    May 2003
Posted by nicodemus on Saturday, November 15, 2003 10:11 PM
Have you tried/used bare metal foil?
You can find both Bare Metal Foil, and Parafilm at Micromark.com
Good luck
Steve-
minutes to buy, hours to build-
a humble ham-fisted modeler in the midwest-
    January 2003
Posted by plasticmod992 on Saturday, November 15, 2003 10:55 PM
I use Parafilm and Bare-metal foil, both with excellent results. A quick tip using the Bare-metal foil: to safely remove the residue left behind use a product called Goo-gone Citris. Dampen a little on a Q-tip and gently wipe away the residue. The Goo-gone not only clean away the adhesive but seems to polish the canopy a bit too! Good luck!
PS: Look for Goo-Gone Citris at home improvemet stores and some supermarkets.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    May 2003
Posted by widepaul on Monday, November 17, 2003 9:02 AM
Where can I get Parafilm?Big Smile [:D]
Thanks,
Paul
Posted by wroper11 on Monday, November 17, 2003 9:26 AM
It is made by testors and you can get it at your local hobby shop. It is greta stuff that's what I use for my canopies too. It will stretch and bend around contours.
Wroper
USAF PRIME BEEF ENGINEERING READY...ANYTIME...ANYWHERE! HOORAH!</font id="blue">
Posted by Lufbery on Monday, November 17, 2003 10:24 AM
I've recently used the Ambroid liquid mask to good effect.
Regards,
-Drew
-Drew
Build what you like; like what you build.
Posted by Abastyr on Monday, November 17, 2003 7:01 PM
I'd recommend purchasing the Parafilm from a Medical Supply vendor on the internet. I got a roll that was 4 inches wide, and 125 feet long for around $40 It will last me a lifetime, as most canopies can be covered with a 2X2 inch piece.
Check www.modernbio.com/parafilm.htm
Posted by Anonymous on Monday, November 17, 2003 11:11 PM
No matter what i tried as far as masking, i still couldnt get it right. I finally started putting a strip of masking down, painting it the color or the fuselage on the outside and interior green for the inside.
I use a straight edge and a new #11 exacto knife to cut the tape. Works for me
