P-61 wip... Finished!!!
    January 2009
Posted by fermis on Tuesday, March 16, 2010 12:20 PM
Thanks!!!
Jon_a_its
good work... ( = better than i can do)
As one with bad shakey hand syndrome, how did you paint all those moulded on pipes & cables?
The majority were replaced, which makes them much easier to paint. I have pretty shakey hands too. So every time I break out a brush, the part stays on the bench and I rest my hand on the bench as well to curb the shake. A very small brush, a tiny amount of paint and a ton of patience help a lot!!!
    March 2009
Posted by Spike190 on Tuesday, March 16, 2010 12:21 PM
Nice save Fermis, when I read "defeated" I thought you'd chucked it!
Cheers...
Mike  Toast
    January 2009
Posted by fermis on Tuesday, March 16, 2010 12:30 PM
Spike190
Cheers...
NO sir!!!!!
I kicked its ARSE!!!!
    November 2008
Posted by uglygoat on Tuesday, March 16, 2010 1:20 PM
it does look awesome m8!  my p-61 from my childhood was defeated.  it is lying in a bin full of old busted models.  i've got one in the stash, but i'm waiting a long while before i crack it open.  i will be bookmarking this build for reference though!
tim
    March 2009
Posted by Spike190 on Tuesday, March 16, 2010 5:26 PM
fermis
 Spike190:
Cheers...
NO sir!!!!!
You sure did!!
Cheers...
Mike  Toast
    December 2009
Posted by FastEagle1 on Tuesday, March 16, 2010 7:18 PM
Fermis,
That's awesome, brother.  I echo the sentiments of the other's on this post, your canopy looks great.
I'm waxing poetic and thinking of the whole Phoenix thing......sweet!!
    January 2009
Posted by fermis on Tuesday, March 16, 2010 11:40 PM
Thank you, thank you!!!Bow DownBow DownBow Down
 Moving on, my boom/wing joint is obviously a bit off!!!
I cemented on the left wing, let set, then test fit the right wing with tail. This was the fit!!!  NO GOOD!!! (my own fault)
001-8.jpg picture by fermisb
 So, something had to give somewhere. The tail being the only option.
002-7.jpg picture by fermisb
I removed about a 1/16" and a little bit of sanding and everything fits beautifully.
The gaps at the wing/fuse joint were small enough that a bit of thinnly stretched sprue took care of them.
003-4.jpg picture by fermisb
Just need to mask off the gear bays and engines and she'll be ready for paint!!!!!   WOOOOOHOOOOOOOO!!!!
    May 2008
Posted by MIflyer on Wednesday, March 17, 2010 12:33 PM
Jeremy,
Amazing work, dude. This is the most extensive WIP thread I've seen of this kit - thank you, because I've got two of these beasts in the stash. Yes
Can I ask what your weapon of choice was for the rescribing job? It looks great.
When I build one of mine, I'm seriously considering vac-ing the canopies so that they'll be just a tad oversized... maybe then they'll fit!
Kevin
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
    January 2009
Posted by fermis on Wednesday, March 17, 2010 2:20 PM
Hey Kev!!!
 Thanks for the comps. Man, it's been quite a while!!! I was starting o wonder if you'd move on elsewhere!!!
I scribed with a needle in a pinvice, used the same needle for the rivets as well. Got a coat of grey on her this morning, almost completely lost the rivets, ut they're there, very subtle, just the way they should be!!!
TWO stashed!!!!  I know it'll be at least ten years before I even think about putin one in the stash(to sit for a few years!!!
    March 2004
Posted by Mikeym_us on Wednesday, March 17, 2010 9:33 PM
I would strongly suggest investing in a SAC metal landing gear set I have a set coming in either Tommorow or Friday along with a Quickboost P-61A .50cal set on top of a P-40C cockpit set. Oh and I ordered a Quickboost P-61engine set today from Sprue Bros.
You will definitely need a metal landing gear set for that beast luckily the SAC sets are plug and play especially after major assembly and painting(got that one from the website).
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    January 2009
Posted by fermis on Wednesday, March 17, 2010 10:16 PM
Mikeym_us
I thought about those, not for very long though. It's a bit late now anyway, gears are already in place. My last ones gears held up quite well for 7/8 years, and that one had a bit more weight to it. I'm not real gung-ho on spending more money on goodies, than I spend on a kit anyway. Sometimes I'll spend the extra few bucks, but I wanted to full challenge with this one!!! My A/M expense on this is about 5 cents worth of styrene, 18 cents in pennies(weights) and about a quarters wrth of mesh. Not too bad, I'd say!!!
    September 2009
Posted by burner12 on Thursday, March 18, 2010 12:19 PM
WOW! She's a beaut! Keep up the good workBow Down
    January 2009
Posted by fermis on Thursday, March 18, 2010 9:15 PM
 Got her painted and weathered today. Weathering was my usual, paint, pastel, drybrush, drybrush again.
The walklines were brush painted, as well as the invasion stripes.
001-9.jpg picture by fermisb
002-8.jpg picture by fermisb
    September 2003
Posted by Daywalker on Thursday, March 18, 2010 10:37 PM
That is looking sweet mate, well done!
I really like your weathering methods (just wish I could remember exactly how you do it) as they turn your work into such realistic pieces.  Keep it going brother!
Frank
    January 2009
Posted by fermis on Thursday, March 18, 2010 10:54 PM
 Thanks Frank!!!
Here's the link to my A-20. Details for my weathering method start on page 3.
/forums/p/124657/1254454.aspx#1254454
    March 2009
Posted by Spike190 on Friday, March 19, 2010 12:24 PM
Fermis I like the results of your painting and weathering technique, excellent stuff. I wouldnt know the invasion stripes were brush painted, top notch!!
Cheers...
Mike  Toast
    January 2009
Posted by fermis on Sunday, March 21, 2010 5:33 PM
Finished her off this afternoon!!!
 Final fiddly bits were stretched sprue antennas, landing light and wiring on the nose gear. Exaust stains were drybrushed and pastels. Nose art was a spare from a P-51 "pyn-ups" set.
001-10.jpg picture by fermisb
002-9.jpg picture by fermisb
003-5.jpg picture by fermisb
005-2.jpg picture by fermisb
007-2.jpg picture by fermisb
008-1.jpg picture by fermisb
009-1.jpg picture by fermisb
010-1.jpg picture by fermisb
012.jpg picture by fermisb
    January 2008
Posted by artabr on Sunday, March 21, 2010 5:44 PM
A truly amazing job, Fermis.
Art
God & the soldier we like adore, In times of trouble not before. When troubles ended & all things righted God is forgotten & the soldier is slighted.       Francis Quarles 1592-1644
    June 2005
Posted by Lancair IV on Sunday, March 21, 2010 8:40 PM
Great job Fermis.  i wish I could figure out how you do it!  Bow Down
Rob Byrnes
Novi, Mi
Posted by rjkplasticmod on Sunday, March 21, 2010 8:46 PM
She came out beautiful.  Well done Yes.
Regards,  Rick
    November 2008
Posted by Wabashwheels on Sunday, March 21, 2010 9:08 PM
It's Art. It's inspiration. It encourages.  Thanks.  Rick
    September 2003
Posted by Daywalker on Sunday, March 21, 2010 9:23 PM
Stunning work my friend, the finest example of the Black Widow I have seen yet. Bow Down
Thanks for the link to your A-20! Toast
Frank
    March 2009
Posted by Spike190 on Monday, March 22, 2010 6:34 AM
Great job Fermis, I really like the finish you've achieved it looks fantastic! Whats next up? I enjoyed this one Yes
Cheers...
Mike  Toast
    January 2009
Posted by fermis on Monday, March 22, 2010 7:55 AM
 Thanks a million guys!!!ToastToastToast
She was a tough one, fought every step of the way!!!
As for what's up next.........I have no idea yet, probably something simple!!!
    October 2009
Posted by jetmodeler on Monday, March 22, 2010 8:35 AM
WOW! Really looks great.Toast I like the weathering on it.
    January 2009
Posted by fermis on Monday, March 22, 2010 11:06 PM
Danka!!!Toast
    April 2008
Posted by Von Alfalfa on Tuesday, March 23, 2010 4:39 PM
WOW! Now thats a B-E-A-U-T-Y!
Love the finish and weathering! I just wish to finish mine as awesome as yours!
Congrats for that beauty buddy! Yes
    December 2009
Posted by FastEagle1 on Tuesday, March 23, 2010 7:30 PM
Fermis,
Really good work!  She turned out beautiful; panel lines, weathering and all those clear surfaces.
I admire you for taking this project on.
Beer
    April 2005
Posted by wing_nut on Wednesday, March 24, 2010 6:43 AM
WOW Fermis, that is something special.  Whenever I read something about the 61 kit there are always creams of horror mixed in there somewhere.  You have really turned that into a precious gem.  Your finishing technique is stunning.  In one of the pics, at 1st glance it had the look of stressed skin.  May have to build a bird and try that out, but I bet it will have its use in armor too. I bow to youBow Down
Marc
    May 2008
Posted by MIflyer on Wednesday, March 24, 2010 10:48 AM
Awesome job, bro! Best Widow I've ever seen. Toast
Kevin
