Snaps 1/16 Full frame JU87 G Stuka Build
    November 2004
Posted by snapdragonxxx on Monday, September 26, 2011 4:31 PM
Here we go with this build. This is only available in Germany, Austria and Italy. This means that as my knowledge of these languages is down to getting alcohol, food and an ambulance/Paramedic that Google Translate is my friend Hmm
This is a weekly build and so far I have the first 8 weeks in my grubby paws. It is also quite expensive so I am NOT rushing the job.
The Majority of this build is in etched Brass and I think aluminium skin. It is possible to solder this together, but as that is not in my skill set I am using Cyroan-whatever - Superglue to me!
Here we go chaps.
Issue 1 - Hachettes Build A JU87 Stuka.
The Parts
The Build
Starting off With the cockpit area I put together the pilots seat rostrum. This will have to be painted RLM 66 and RLM 02. First of all the sides put on and my trusty square to make sure that it is at 90 degrees.
Both sides on. My square used to make both sit properly upright.
THe top part put on. THis is only dry fitted to make sure that it does fit correctly before the inside is painted RLM 02.
The first frame is a double one. Above you can see the inner parts of the frame bent to the right angle and curve and glued in place. I think that this is where one of the wing braces fits so I use my square again to make sure that the inner parts are at the corrsect square angle. The other part of the frame will be put on after the painting is done.
Interior base coat of RLM 02 applied. I will do another 2 thin coats to firm up the colour and to even out the paint. After that has dried I will assemble the parts together and then add the RLM 66 cockpit colour.
Done! all painted, assembled and fits just right. I have the instrument panel to do - but at the moment I will leave it while later. So issue 1 is complete apart from the instrument panel which will be done at a later time.
    November 2004
Posted by snapdragonxxx on Monday, September 26, 2011 4:32 PM
Here we go with Issue 2 of the Build.
The Parts
The Build
Continuing on from last week we add another double frame and some longitudal framing. Basically the first bit is the same as last weeks frame and I rechon that there is some wing support spars to fit in here.
Ready for painting the interior of this frame with RLM 02. Once dry add the part to finish it off and stich to the bit I finished last post!
Some frame supports (I think) are added
Next up we put on some longitudnal framing. Initial dry fit.
Glued in place.
Apart from some paint that's issue 2 complete!
    March 2010
Posted by Scorpiomikey on Monday, September 26, 2011 4:38 PM
1:16th stuka? jesus mother mary of puss thats gonna be a big mother. I shall be watching with bated breath. Cant wait to see more.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    October 2010
Posted by LeeB on Monday, September 26, 2011 4:59 PM
I would be cool if you could put something in your photos to give us some sense of scale (like a coin or car keys, etc.).  I never heard of these type of kits until your post last week and I really look forward to your build!  Thanks.
    March 2010
Posted by Scorpiomikey on Monday, September 26, 2011 6:06 PM
Well, at a guess i would say thats about an 18mm blade on the dremmel. which is around 3/4 of an inch.
Long story short THAT'S A BIG MOTHER OF A KIT.
http://www.den-stuka-bauen.de/modell.htm Website of the kit.
Dims are
710mm long
930mm wingspan (nearly a meter)
240mm Tall.
Its a monster.
My signature
    October 2008
Posted by bsyamato on Tuesday, September 27, 2011 12:50 PM
Snaps never build something in 1/144 scale ? oh my gold Indifferent
Basically the build is near to real build... I see in tv spots about the 1/20 zero, but never really thinked to buy it ,not only for the enormous final price but is something too differents from normal kits.. ( i presume the instruction language are not in italian Geeked
follow with great curiosity and intrest YesYes
    November 2004
Posted by snapdragonxxx on Tuesday, September 27, 2011 2:20 PM
I actual fact bsyamato,
The Zero is available in italy. it is 1/16 scale it is mostly etched nickel I think plus metal skin AND the instructions are in italian.
Deagaustino Italy have said that I can purchase it and they will send me it to England - but it will cost an extra 25% postage.
THey are about week 20 at the moment. so it will cost me around 54 Euro for 4 issues plus bank charges.
The price is 10.99 a week. These are stunning builds if you take your time. My advice is to go for it!
I am certainly thinking about it and doing the maths to see if I can afford it. If you want to build it I can certainly help.
James
Posted by VanceCrozier on Tuesday, September 27, 2011 2:50 PM
1-meter wingspan.... WOW, that is a monster. Very interesting to watch one of these built up with a proper structure, ribbing etc. What do they give you for the engine bay??
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    April 2005
Posted by carsanab on Tuesday, September 27, 2011 2:55 PM
very cool.....its gonna take alot of brass to put his one together....looking forward to this build!!!
 Photobucket
    March 2006
Posted by TD4438 on Tuesday, September 27, 2011 3:51 PM
This is bound to be awesome!
Gotta keep an eye on it.
    November 2004
Posted by snapdragonxxx on Tuesday, September 27, 2011 3:52 PM
VanceCrozier
You get an engine, so I'm told. All this is in German, so Google Translate is my best friend!
If you search german ebay you may find someone who is willing to obtain all 140 issues and send them over..... It will cost though!
    November 2004
Posted by snapdragonxxx on Wednesday, September 28, 2011 11:08 AM
On with the build.
This post - ISSUE 3
The Parts
The Build.
This time we start off by adding 3 frames
I need to do some painting before adding the other 2 frames. Dry fitting is essential just to make sure that you know which frames go where. 2 are the same, 1 isn't. DON'T mix them up!
For those who want to see some scale. There is a 15cm/6inch ruler.
All 3 frames in position. still a little bit of painting to do, but getting the floor support frames in while I have the space is a good idea!
There we are! The cockpit floor frames in position and a couple of longitudnal frames underneath them too.
Picture of complete build to date.
    February 2005
Posted by rufioizgrreat on Wednesday, September 28, 2011 1:00 PM
WOW!
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time." -Lewis B. "Chesty" Puller
    October 2008
Posted by bsyamato on Wednesday, September 28, 2011 3:37 PM
nice progress snap, yes, is the Deagostini that sold the Zero (i thinkin was 1/20 Indifferent ) i brought one or two year ago the first number of the yamato 1/250 ... the first number contains the main tower and a single bulkhead.
The kits will be really in high dimensions, as the picture show compared to an 1/72 seabat. Conscious of the yamato too many pieces and the too much final prices i stopped with the first number. My opinion is to prefere to have all pieces from the start. Also in italy these things during the pubblications increase prices in b***tard way Smile Dots
following your great build, for now is enough to just see Wink
    November 2004
Posted by snapdragonxxx on Wednesday, September 28, 2011 5:40 PM
Deagostini in Italy have promised me all 100 issues of the Zero (1/16) at 10.99 Euro per issue plus 25% delivery charge.
I am willing to go for this as I don't think that this one will reach the UK. They are pretty unique models to build up. I agree that they are expensive, but so far the Stuka is going together really well ( as you can see) and I do want the Zero. The Stuka is by Hachette and I think is now available in Italy. If I find a link I will post it for you
Since the infection that I picked up in china damaged my heart to 75% permanent muscle and valve damage the specialists have prevented me from work, so I have to find things to challenge me and these partworks do that.
I do love doing plastic kit models, but these large scale stuff make you think about what you are actually doing and the scope for modding and extra detail is always there - and in a scale that I can get my fingers round!!!!
James
    November 2004
Stuka Build - Issue 4
Posted by snapdragonxxx on Sunday, October 2, 2011 3:43 PM
Hi chaps. Back with another update.
On to Issue 4. another frame to build up, paint and some more longitudnal framing.
I am finding this build educational as well as fun! whoever decided do do this in brass made an excellent choice as wood I think would not have done this kit/partwork justice. As it is I am not only learning metalwork 101 but framing 101 too! Also I wonder if I can weigh in the brass frets and offcuts and get money on it!?
As the size and weight increases I wonder if Hachettes statement that you can hang it from your ceiling is a wise choice. I don't want this thing crashing into me during the night! She's big, heavy took a long time to build and deserves a proper case!
On with the build!
The Parts
The ruler is there for size reference.
The Build
This issue took some thinking about as I had to bend one of the parts without a guide. To get the curve right for the upper drabe divider I finally used my Xacto knife as it was the closest thing to the correct curves I needed. I finished off the curves by hand with plenty of dry fitting until the guide pegs fitted into their holes easily and the curves were symmetrical. The lower frame divider was just a couple of streightforward 90 degree bends which the part had etched in. Once done it was time to glue them in place.
Once the glue has set it was time for painting once again before compleating the frame. Both inner areas were painted with 3 thin coats of RLM02 and left to dry. not only does this show the correct colour where it should be on the inside of the frame but acts as it did on the original aircraft as a primer and protective coat.
Once everything is dry, time to add the frame part and close it all up
Notice how the locating pins stick through. Hachette in their instructions say you must use a side cutter to nip them off and then a wuick rub over with a file. I much prefer to use my trusty Proxxon small multitool with its flexible shaft and a grinding wheel on it. It is much quicker, neater and also grinds and flattens the pin off so it seales the hole and provides further joining of the parts as well as the glue.
Some juggling about and bending of a couple of the latereral spars was needed to fit this part. The spars were bent back into shape and glued into place
After the glue had dried I then added the longitudnal spars underneath.
Issue 5 complete. Just some RLM 02 & RLM 66 to put on. You can see also the colating pins at the top of the frame. These will be ground off.
Anybody jealous yet, of got any questions? Please ask!
James
Posted by VanceCrozier on Sunday, October 2, 2011 4:16 PM
snapdragonxxx
... Also I wonder if I can weigh in the brass frets and offcuts and get money on it!?
Cash in on the spare brass?? You know what, it's probably worth something to a scrap dealer, it may help defray some of your initial costs! Jealous? JEALOUS?!?!?!?! Maybe... Embarrassed Wink
    November 2004
Stuka Build - Issue 5
Posted by snapdragonxxx on Monday, October 3, 2011 4:51 PM
Issue 5 build
We continue with the cockpit structure.
The parts
The Build.
We concentrate firstly in the front part of the cockpit and add a couple of frames
and a couple of longitudnal spars
Just as an item of interest, the square gap is where I thing that the bomb sight will fit..... and that is the next issue
On to some more Longitudnal framing. I work on opposite sides when ever possible. Al though this is brass I work on the same method that I d when planking a wooden ship. What I do on one side I do on the other to avoid stress on the frame.
The last two pieces for this issue is two large interesting parts. Once the glue has set fully I will grind off any protuding locating pins.
Issue complete. Just a little grinding and painting to do. I am using a superglue mixture of both gel and thick. this way it doesn't run and fulls the gaps (not that there are many at all) and is easily cleaned up to make neat joints with a sharp knife.
comments etc welcome
James
    October 2008
Posted by bsyamato on Monday, October 3, 2011 4:59 PM
Stick out tongue even more complex and real
    September 2011
Posted by hobbes on Monday, October 3, 2011 5:00 PM
I must say that I find this to be an interesting model.  I would love to do a full frame model some time, though not necessarily of a Stuka or in 1/16th scale or even out of brass.  Mostly because: a) I am more interested in planes of the RAF, b) I wouldn't have a place to put a 1/16th scale model and c) at the moment, a kit like this is way outside my budget.
If I could find enough references, I would probably attempt to do a scratch build in 1/32 or 1/48 of a full frame Hurricane or Spitfire out of styrene once I have acquired enough skills.  I did a bit of modeling in high school, but then left the hobby when I went to college due to lack of space and time.  I am out now and have more space and time available and am working on getting back into the hobby.  I plan on doing a few builds straight from the box and then working in more detailing once I have the basics down again.
I will be following this build though and using it as inspiration for a future project I am sure.
    February 2005
Posted by rufioizgrreat on Monday, October 3, 2011 8:57 PM
i am REALLY loving this thread.
maybe i missed it, but what do you mean by "issues". are you getting the parts in the mail? how much did the kit cost?
also, is it a pretty easy build, or are you just making it look that way?
    November 2004
Posted by snapdragonxxx on Tuesday, October 4, 2011 4:28 AM
This "project" is a weekly build. You get 4 parts a month (1 a week) and each part consists of a magazine containing the build instructions and articles on the development of the stuka, plus others on aircraft, people etc. Also you get the parts for that week and it costs 7.95 Euro per issue.
This build is a 140 week build and as it is not available in the UK I am having a friend get the issues in Germany for me and shipping them. If this "partwork" as we call them here does become available here then I will of course get another as I want one fully skinned and painted and one just framework.
Is this build easy? Yes and no. You are dealing with a mostly metal build. which means that the standard plastic skill set is the basic thing you need you are also working at a much bigger scale and in metal (mostly brass) this means that you have to be accurate with your work and spend much more time dry fitting and dranslating the instructions (google translate is my friend!).
These builds take time and money and produce fantastic and limited production run kits. Eventually you will be able to buy the thing complete in a box from Amati - but not for at least 10 years and will cost a small fortune.
Doing it this way at a weekly/monthly rate you don't feel the bank balance shrink violently and SWMBO doesn't go totally screwy at the cost start Bang Head making you Bow Down.
My first weekly build was the Titanic in 1/200. Just look at Amati's site. Now available all in one box ( and it takes 2 people to carry the box) turned out to be a stunning and accurate build.
During these builds you will learn new skills, sharpen up on old ones and manipulate existing skills to do something different. You also learn lots about what you are building and just how it goes together.
THere is another aircraft frame/skin build available in Italy and that is a 1/16 Japanese Zero. The publishing company is aggreeable to send it to me in the UK (not available here as yet) for 10.99 Euro +25% postage per issue. and this one is 100 issues.
It spreads the cost and gives me something to do / look forwards to and provides a challenge.
Recent partwork builds include Titanic, Fokker Triplane DR1, Bismarck, Flying scotsman.......
Current ones include HMS Hood, JU87 G stuka, Mitsubishi Zero, Formula 1 Mclaren MP40, Aston Martin DB5 (James Bond edition from Goldfinger) HMS Victory.........
If you live in the Eurozone, south africa, Australia and New Zealand then most of these are available somewhere.
On average I spend 6 hours + an issue. With the Stuka I have to translate the instructions, spend lots of time dry fitting parts and checking before I think about adding glue. This one can also be soldered together, but that is not in my skill set!!!
I have a spare Issue 1 of HMS Hood if you want to have a look at the format.
James
Posted by VanceCrozier on Tuesday, October 4, 2011 6:59 AM
snapdragonxxx
It does sound like a lot of $, and it is - but is it worth €8 a week in entertainment value? Sounds like it. Looking forward to next week!
    October 2008
Posted by bsyamato on Tuesday, October 4, 2011 11:31 AM
VanceCrozier
 snapdragonxxx:
next month i finish to pay my car Whistling put down some picture of  hood spares just to compare with the yamato kit
    September 2005
Posted by Sprue-ce Goose on Tuesday, October 4, 2011 11:46 AM
Very Impressive.
Building a Stuka the old fashioned way.
Will the kit fuselage final assembly entail joining top and bottom halves as done on the actual  aircraft?
    November 2004
Posted by snapdragonxxx on Tuesday, October 4, 2011 1:25 PM
Sprue-ce Goose
Very Impressive.
As far as I am aware the fuselage aft of the cockpit is in upper and lower halves. I won't know until I get the issues that deal with this part of the airframe.
What I would like is a hydraulical, electrical and control wiring diagrams as I am toying with the idea of adding those to the build, if they aren't included.
At this moment in time I have no idea on what is coming after issue 8 as that is all I have in my build box.
VanceCrozier
I think it is good value for money as not only is this entertainment it is learning too. It's a big step outside plastic kits where you stick two fuselage sides together. With this kit you put together the entire airframe and then add the skin (if you want to) so you are building the real thing, in metal but in a smaller scale. 8 Euro an issue for these parts, a magazine and the experience you get and a new skill set in my opinion is worth it.
Also they are limited edition and unique models you end up with and are unlikley to see them in a full kit - then they are worth the time and money as a talking point.
There has been a discussion on another forum on if it is possible to make this model fly. My feeling is that this is a large scale reproduction of a proven airframe so with the correct RC stuff added and an engine big enough then in theory it should be able to fly!
but there again Theory and practice are two different things!
Next up once I have translated all the instructions and studied the construction photos is the bomb sight.
James
Posted by 7474 on Tuesday, October 4, 2011 2:54 PM
It seems nice enough to make color scans of the parts, and use them as patterns to build an 80% scale flying replica. That would be cool. I'm enjoying this as well.
    November 2004
Posted by snapdragonxxx on Tuesday, October 4, 2011 4:37 PM
If that is the case, how about a full size flying replica. Hmmm.... pity I have started....
This would mean making each part 16 times bigger, finding an engine........ somewhere to build it.......
Anyone got some blueprints???
DADDDDDD!!!!
LOL
    September 2005
Posted by Sprue-ce Goose on Tuesday, October 4, 2011 6:14 PM
snapdragonxxx
DADDDDDD!!!!
LOL
Somebody who donated an engine to this museum
http://www.craftsmanshipmuseum.com/KnappCol.htm
may have made an engine for that size aircraft....
    November 2004
Stuka Build - Issue 6
Posted by snapdragonxxx on Sunday, October 9, 2011 3:08 PM
Here we go with another update. It is taking so long because
A) The parts have to come from Germany
B) I have to translate the instructions using Google into pidgeon English
C) Translate Pidgeon English into Proper (Queen's) English
D) build the thing and get it right first time!!!
Also you have to factor in visits to A&E when the cutting or grinding wheel hits my fingers and I end up with bandaged fingers (think the man from the Pink Panther films that kept on getting his hands stuck in things)
Issue 6 - The pilots Bombsight
The parts
The Build
This issue is a bit more complex and you have to work carefully and as accurate as possible or it "don't fit right" where it will end up. in otherwords itis a slanting box that has to end up square! The first three parts make up most of the build and have to go together correctly which means that you have to bend the middle part in more than one direction to match the sides of the other two parts. The locating pins etc do help but care has to be taken.
Once all the dry fitting is complete and everything looks good..... out with the superglue and the bonding process starts..... carefully as usual.
A little box to house the control lever is bent into shape and put in its place. A little tyding up is in order to remove some superglue which strayed slightly. nothing which a sharp knife can't handle. you can also see the last part of the box bent to shape and ready to go on.
There.... the bombsight box is complete and it is time to start adding the details!
Slap it on! I have not been able to find the correct colour that the interior of the bombsight was painted. The photos I have seen of museum exhibits show it as a very light colour... but flash has been used to take the photo which also changes the colour that the camera sees to a certain extent. It does look white, but I am not sure and as white is a right ****** ** ******* ********* to get a proper even coat I have opted for a very pale non-reflective grey.
While that is drying a primer coat of RLM 66 is put on the outside and then left to dry
I did a dry fit at this stage just to make sure that the thing was square and fitted where is supposed to go
The control lever is next to do before we can finish the bombsight. First of all there is a 7 degree bend, 39mm down the hollow copper pipe to do.
Then there are some small brass parts to add to the top of the control lever to make the handle and knob. The Ruler is for your size reference. Even at 1/16 there are some small bits to put together!
Once again a fry fit of the last parts including a clear acetate sheet and the outside frame for the sheet. This is so I can work out where to put the glue!
Finished! The bombsight is complete and painted up and then placed in it's position - but not fixed as yet.
Issue 6 complete. Comments & questions once again welcome
James
