Creating Step on surfaces.
Posted by Anonymous on Friday, February 6, 2004 1:28 AM
On modern aircraft, there are usually some rough surfaces for maintenance. How should I create that?? Thank you.Big Smile [:D]
Posted by djmodels1999 on Friday, February 6, 2004 1:54 AM
I've had some great results using masking tape to replicate the 'step' areas on my 1/72 Leclerc Main Battle Tank. The masking tape was thin enough, not too rough and easily 'sealed' into place with liquid glue. I'm sure it would work well on aircraft too, particularly at larger scales...
Posted by Anonymous on Friday, February 6, 2004 3:47 AM
I wonder if a small strip of like 600 or 1200 grit sandpaper glued onto the surface would work?
Posted by Anonymous on Friday, February 6, 2004 7:57 PM
The sandpaper would definitely give you the right finish, but I think the paper would look too thick?
What about adding talc or other fine poweder to your black paint, and then brushing it on?
Intersting topic, something I've never tried ...
Bruce
Posted by Melgyver on Friday, February 6, 2004 9:07 PM
For "scale" effect I think flat black paint looks just right for 1/48th and smaller!
Clear Left!
Mel
    November 2003
Posted by chopperfan on Saturday, February 7, 2004 12:34 AM
Sign - Ditto [#ditto] That's what I have found also.
Randie Cowboy [C):-)]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
