The Sky Samurai (1/48 Hasegawa A6M2 21 Zero)
    February 2012
Posted by lawdog114 on Monday, July 9, 2012 11:55 PM
Hello, I'm taking a little break from the group builds at which time I had decided to start a subject I've always wanted in my collection. One of the Zeroes flown by Japanese ace Saburo Sakai, the "Sky Samurai" of the Tainan Air Group.  Not only was he a skilled pilot, having once flew 640 miles to his base half blind with a bullet in his brain, but he seemed like a genuinely guy as well.  I'm using the 1/48 Hasegawa A6M2 Model 21 kit.  I even used the decal for the instrument panel which turned out fairly nice.  I did utilize an Ultracast seat.  I also decided to detail the Sakae engine a bit, by means of scratchbuilding the ignition harness with the assistance of some reference photos.  Here is my process:
I started with some small .010 styrene rod and glue two pieces together side by side (like the appearance of a  double barrel shotgun).  I then sliced it salami style into small appropriate sized squares (tiny) and added these to the ignition ring to simulate wire attachment points with tweezers. To make this easy, use Tenax or similar type weld cement and glue these to the ring "pre" paint.  The styrene should fuse right to the bare plastic with little fuss.  I then ran thin solder to the cylinders attached with super glue.  I sprayed the engine itself different shades of Alclad, specifically dark aluminum on the cylinders and regular on everything else.   like the contrast it shows.  I then hand painted the wires a brownish copper color I mixed up with Tamiya red brown and Khaki.  This process requires patience but is not difficult.  I think it looks better than PE too.   Heres what I have so far.
Joe
    December 2011
Posted by Luft Modeler on Tuesday, July 10, 2012 12:01 AM
Awesome work Joe!! Another great piece of work. What wash do you use again in the pit?
Posted by tigerman on Tuesday, July 10, 2012 12:11 AM
Great work so far. I like that office.
 Eric
    February 2012
Posted by lawdog114 on Tuesday, July 10, 2012 1:39 AM
pzl66
Thanks! I've been using a pre-mixed wash called "The Detailer" and really haven't looked back.  I found it at my LHS for like 4 bones which comes in small white bottle.  It also comes in different colors.  I use black which seems to be more of a dark grey.  Its water soluable too.  I buy a bottle everytime I'm there just in case they stop making it.  If you can't find it, heres the website:
http://thedetailer.net/
Good Luck,
Joe
    November 2008
Posted by plasticjunkie on Tuesday, July 10, 2012 6:48 AM
Great work on the pit and engine Beer I think Hobby Lobby carries that wash. I may just pick up a bottle to compare against my homemade brew.Hmm
 GIFMaker.org_jy_Ayj_O
Posted by Anonymous on Tuesday, July 10, 2012 8:08 AM
lawdog114
Great looking work!
But it is not true about the bullet in the brain.  He took a glancing slug to the head, which severely lacerated his scalp and cost the sight in one of his eyes due to the glass from his goggles being shattered and driven into his eyes...the flight back was indeed a great feat of airmanship, however...Early Japanese Zero pilots were almost superhuman in their ability to navigate over water for extremely long distances, which was required because of the incredible endurance of the Zero...
Posted by VanceCrozier on Tuesday, July 10, 2012 10:32 AM
That is some beautiful work Joe.
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    March 2010
Posted by Hercmech on Tuesday, July 10, 2012 10:36 AM
Fantasitc work on the pit and such.  Should turn into a nice build. Looking forward to seeing it all finished up.
13151015
    February 2012
Posted by lawdog114 on Tuesday, July 10, 2012 1:49 PM
Manstein's revenge
lawdog114
Thanks for the compliments all.  Manstein, thanks for clarifying Sakai's injuries, however, understand my intent was to provide some brief examples of why I was inspired to build Sakai's bird.  The following passage from Wikipedia is where I drew some of my inspiration, which I found extremely impressive or as stated "superhuman".  Of course Wiki has been known to be wrong from time to time and I'm by no means an expert in Japanese naval aviation.  It appears that Wiki's references were fairly good.  Perhaps I should have stated the bullet passed through his brain.
Although in agony from his injuries (he had a serious head wound[14] from a bullet that had passed through his skull and the right side of his brain, leaving the entire left side of his body paralyzed, and was left blind in one eye,[15]) Sakai managed to fly his damaged Zero in a four-hour, 47-minute flight over 560 nmi (1,040 km; 640 mi) back to his base on Rabaul, using familiar volcanic peaks as guides. When he attempted to land at the airfield he nearly crashed into a line of parked Zeros but, after circling four times, and with the fuel gauge reading empty, he put his Zero down on the runway on his second attempt. After landing, he insisted on making his mission report to his superior officer before collapsing. His squadron mate Hiroyoshi Nishizawa drove him, as quickly but as gently as possible, to the surgeon. Sakai was evacuated to Japan on 12 August, where he endured a long surgery without anesthesia. The surgery repaired some of the damage to his head, but was unable to restore full vision to his right eye. Nishizawa visited Sakai while he was recuperating in the Yokosuka hospital in Japan.
Anyways, I still have to post shade the cockpit then its time to put her together.  E-bay had decals for Sakai's bird offered by a company named "Berna" .  I've never heard of this company but I'm going to give them a try.  Does anyone have any experience with these decals?   They offer some enticing subjects and I've been eyeing a KI-43 sheet as well.
Joe
Posted by Anonymous on Tuesday, July 10, 2012 2:07 PM
Wikepedia has it wrong.  I actually have a pic of the flying helmet, goggles and scarf he wore that day and it is clear (just from the pics) that the bulllet never entered his skull...if it had, he'd most likely have died...Indeed, he doesn't even claim in his own bio that the bullet entered his skull...
    February 2012
Posted by lawdog114 on Tuesday, July 10, 2012 6:15 PM
"I stand corrected Wyatt, you're an Oak"....Bow Down
Posted by Gamera on Tuesday, July 10, 2012 7:00 PM
Joe: Great work there on the cockpit and the engine is just WOW!
Hmmmm, looked up Berna Decals and they have some really nice stuff there, please let us know how it goes if you pick them up.
dmk
    September 2008
Posted by dmk on Tuesday, July 10, 2012 7:44 PM
Joe, have you read Sakai's book Samurai? It's a very interesting read. I think you'd enjoy it.
http://www.amazon.com/Samurai-Saburo-Sakai/dp/0743412834/ref=sr_1_1?ie=UTF8&qid=1341967452&sr=8-1&keywords=martin+caiden+samurai
Looking forward to watching your Zeke come together.
Posted by Anonymous on Tuesday, July 10, 2012 8:27 PM
Sakai's gear...my sources tell me he was wounded on 7 August 1942 by .a 30 cal tracer bullet fired from the rear gunner of a SBD:
An extremely rare pic of Sakai just as he dismounted after his epic flight:
    February 2012
Posted by lawdog114 on Tuesday, July 10, 2012 11:14 PM
dmk
Cool pics Manstein!.  The pic of Sakai dismounted is actually used on Wikipedia, but your example is higher quality.  Dave, no I havent read the book.  Unfortunately I have little time for reading right now (family, long hours at the job...yadda yadda).  I havent even read "Munster-Before and After", about the Munster Raid in Germany on 10-10-43.  My grandfather, a ball turret gunner in the 390th BG, was shot down on this mission and apparently his B-17 is mentioned somewhere in the book.   Hopefully someday.  Anyways, back to the Zero.  I postshaded the 'pit a bit more and added 5 minute epoxy to the gauges to simulate glass.  I love this technique but you have to work fast say........5 minutesHmm.  I glued in the cockpit starboard side in but when I attempted to glue the port sidewall and fuselage together around it, to my surprise, it was not fitting right.  It turned out the starboard side was badly warped, which completely convoluted the fit of the cockpit.  (theres probably a reason this kit was 10 bones at a model show vendor's tableHuh?).  Oh well, I was able to muscle it into position with some Tenax and finger pressure, but lets hope there arent adverse affects later.  Heres some more pics..
Joe
Posted by jeaton01 on Wednesday, July 11, 2012 12:35 AM
Nice looking engine.
John
    May 2012
Posted by Old Ordie on Wednesday, July 11, 2012 12:49 AM
Joe,
Great cockpit, as usual.  Ditto the engine.  Can't wait to see it finished.
Mark
Flight deck:  Hasegawa 1:48 P-40E; Tamiya 1:48 A6M2 N Type 2 ('Rufe')
Elevators:  Airfix 1:72 Grumman Duck; AM 1:72 F-4J
    February 2012
Posted by lawdog114 on Sunday, July 15, 2012 10:26 PM
Hello, I thought I would post a little update in my progress.  I got the airframe put together and I did have fit issues due to warpage.  It was enough to where I had to walk away from it for a few days.  This thing has been fighting me the whole way thus far.  Not only was the starboard fuselage warped, but so was the port upperwing.  It was nicely bowed and I had a heck of a time getting enough Tenax on it to make it stay flat Bang Head.  Unfortunately the warpage affected the fit of the wings to the fuselage and the whole thing need quite a bit of fiddling, especially at the wingroots and where the lower wing meets the fuselage.  In the latter area, I ended up sanding the Censored out of it then rescribing the panel lines.  For some unknown reason, a groove was left at the port wingroot which I had to sand out.  I think I have it squared away now.  I suppose every now and then a kit just fights you for whatever reasonConfused.  Oh well, I'm almost ready for paint...
    December 2011
Posted by Luft Modeler on Sunday, July 15, 2012 11:46 PM
Im sure it will turn out great, I have seen your skill in two of my GB! The Emporer demands high quality, nothing less from a samurai! Lol.
    May 2012
Posted by Old Ordie on Sunday, July 15, 2012 11:57 PM
Looks to me like you've whipped it into shape ... it's looking real good to me.
    March 2010
Posted by Hercmech on Monday, July 16, 2012 9:16 AM
She is coming along very nice!
13151015
    February 2012
Posted by lawdog114 on Thursday, July 19, 2012 9:19 PM
Hello...heres a little update.  I got her painted and clearcoated.  Now I'm just waiting for the Berna decals to arrive which should be anyday now.  Sometimes E-bay can be slow.  For paint, I went with Tamiya XF-76 Grey Green which is supposed to be the last word in "Ame-Hiro" (key word supposed).  I sprayed it on and it looks pretty good to my eye, I then added some white and did my normal streakng on the wings and changed the hue of the control surfaces by altering the ratio.  On a side note, the guy at my LHS talked me in to trying Tamiya "Lacquer Thinner" with Tamiya paints in lieu of my normal 91 Iso Alcohol.  He said I would be so happy with the results I would return specifically to thank him.  Well...it did spray nice and smooth, dried quick and it seemed to have more "bite".  It also left a slight sheen which is something I'm not used to with Tamiya XF paints.  The down side is that it smells like Tamiya's Extra thin cement and costs 9 bones a bottle.   Anyways, I mixed flat black and flat blue and came up with my own version of Mitsubishi cowl color.  I also made a custom mix of clear blue and green over aluminum for the Aotake coating in the wheel wells.  I may redo this since this isn't exactly the look I was going for.  I wanted it to be more translucent.
I'm attempting to get away from Future on my clear coats for reasons I've explained elsewhere and I have been experimenting.  While at the LHS on the same trip outlined above, I saw that Alclad had a clear gloss coat available.  I decided to get it.  I must say, so far I'm pleased and it has dried to a rock hard smooth finish in a matter of a few hours.  The down side is that it smells like lighter fluid and costs 9 bones (18 bones out the window...just like thatDunce.  I figure I'll use these sparingly for decaling and stick with Testors Gloss for other stuff, such as barriers between washes.   Heres where I'm at so far
GAF
    June 2012
Posted by GAF on Thursday, July 19, 2012 10:25 PM
よく成された仕事. (yoku nasa reta shigoto)
This looks like it will be a good one.
Gary
Posted by Gamera on Friday, July 20, 2012 7:32 AM
Looks pretty darn near perfect to me!
    January 2012
Posted by Cdn Colin on Friday, July 20, 2012 8:11 AM
I build 1/48 scale WW2 fighters.
Have fun.
    March 2010
Posted by Hercmech on Friday, July 20, 2012 10:00 AM
Awesome paint work!
13151015
    May 2012
Posted by Old Ordie on Friday, July 20, 2012 12:23 PM
Joe,
The XF-76 looks great.  Very nice shade.  Your Aotake looks great, too.  Can't wait to see it complete.
Ord
    September 2004
Posted by Borg R3-MC0 on Saturday, July 21, 2012 1:35 PM
Fabulous build, I really like the cockpit, the shading etc etc!
    February 2012
Posted by lawdog114 on Wednesday, July 25, 2012 2:37 AM
Hello all, the Berna decals finally showed up and I got the zero decaled.  These are fantastic and only needed a soak in Micro Sol to snuggle right down.  Highly recommended!  The only gripe I had was the lack of the red wing walk box decals.  They supplied everything else, why not these?  I was forced to use the kit decals for these and they laughed at Micro Sol.  I then tried the stronger Mr. Mark Setting solution which completely melted the decal into a pile of goo.  I was forced to substitute an old set from a Tamiya Zero I had on hand....in hindsight, I should have just painted these on like I did on my P-61 Bang Head.  Reference the Hinomarus markings (meatballs), are they supposed to be this bright of a red?  I'm gonna have to find a way to tone them down.  I decided I'm going to paint in the blue fuselage and tail stripe in lieu of the decals.  I'm thinking Tamiya flat blue with a bit of white would be suffice.
Joe
    December 2011
Posted by Luft Modeler on Wednesday, July 25, 2012 4:00 AM
Keep up the work man, looks great!!
