Thanks, guys. Yeah, Dre, despite my best (worst?) efforts to make it otherwise (ie, a ball of plastic), it looks like a Flanker. ;-)
T3ch--Spotted em! Those are the North Star burner cans. You probably don't want to know what I went through, but....I ended up buying not one, not two, but three sets of those things. Yep. Three. I probably spent as much on those as I did on the whole kit. Oh well.
The assembly of the turkey feathers doesn't take that long (maybe an hour or less), but I ruined the first two sets trying to get it right. The trick is trying to line them up correctly while making sure you've wrapped them tightly around the resin tube, which is hard because you're working with some really thick PE metal (brass?), there are four sets/layers of feathers, and I'm not sure that all of them line up correctly if you follow the instructions.
So after I ruined the first--"Oh, OK, NOW I know what I need to do." Then I ruined the second and "OK, NOW I GOT IF FIGURED OUT." Third time's the charm, I guess, although they're not perfectly assembled, they're still better than the kit or Aires cans.
Then after all that, you have to assemble the flame holder, which on the upside has a ridiculous amount of detail and is a whole model unto itself, the downside being the PE parts are so small you'd need an electron microscope to get everything assembled. So I left off the smallest bits since you won't be able to see them anyway.
