RAF sky blue "or light blue I should say"
    February 2011
Posted by randypandy831 on Friday, December 28, 2012 5:14 PM
Xtradecal calls for sky blue on the bottom side of a Mk.I Spit. I never have heard this color and Im wondering if anyone has info on this color?
Could it be within the lines on duck egg blue or even a lighter version of azure?
thanks!
tamiya 1/48 P-47D $25 + shipping
tamiya 1/48 mosquito $20+ shipping
hobby boss 1/48 F-105G. wings and fuselage cut from sprue. $40+ shipping.
    August 2005
Posted by Phil_H on Friday, December 28, 2012 5:24 PM
For a Mk.1 I would go with "Sky Type S" or something along those lines (the pale greenish colour) Tamiya XF-21 or similar
    January 2003
Posted by bigfoot01 on Friday, December 28, 2012 5:26 PM
I think it may mean "Sky". It is a common color on the underside of WWII British aircraft. In Tamiya acrylics it is "XF-21". It is actually a very light gray with a green tint to it.
John
    December 2006
Posted by Jester75 on Friday, December 28, 2012 5:32 PM
 I used Model Master Acryl 4840 RAF Sky Type's' ANA 610 for my Spit and I really like the color. Not sure if  its an exact match to what was used but it looks good.
Eric
    April 2010
Posted by LDSModeller on Friday, December 28, 2012 7:38 PM
Sky Blue is NOT, Sky Type S or Duck Egg Blue.
There are two types of Sky Blue that appeared on Some RAF Fighter Aircraft at the beginning and early part of the Battle of Britain.
They are
BS 381c (1930) No. 1 Sky Blue
and
Air Ministry Sky Blue  or AM Sky Blue
This colour Chart will give you an idea about the BS 381c no. Sky Blue (first one on chart)
www.e-paint.co.uk/BS381%20Colourchart.asp
This link gives you AM Sky Blue,  as you can see it could vary
1.bp.blogspot.com/.../RAF+Sky+Blue.png
This link to a discussion on Britmodeller (bit of reading) may help you?
http://www.britmodeller.com/forums/index.php?showtopic=54264
Hope that hepls you?
Regards
Alan
    February 2012
Posted by lawdog114 on Friday, December 28, 2012 8:04 PM
Hey Randy, I just finished the above Spit Mk I using an Xtradecal sheet (probably the same one you're using).  According to my research for this build, early Spits and Hurricanes were "Sky Type S" then changed to a bluish-green they called "Duck Egg Blue" towards the later part of the Battle of Britain.  I'm more partial to the earlier Sky which I made my own concoction.  Its Tamiya XF-21 Sky mixed with a smidgen of XF-3 Flat Yellow.   I think I got it fairly close, at least to my eye.  If you prefer Model Master paints, they make both of these colors.
Hope this helps,
Joe
    April 2010
Posted by LDSModeller on Friday, December 28, 2012 8:55 PM
I think you will find that 'Sky" in early to mid 1940 was the same as "Duck Egg Blue".
Duck Egg Blue AKA Sky then, was a Blueish/Greenish colour which existed in that form till later modified to the Sky (mid -late 41-42), which we know now as the Greenish/Greyish colour, also found on Post WWII British Military aircraft also.
Regards
Alan
    February 2011
Posted by randypandy831 on Saturday, December 29, 2012 5:20 PM
nope, not Sky S.  it's more into the bluish side.
LDS got it right.
thanks for the help everyone!!!
    December 2006
Posted by Jester75 on Saturday, December 29, 2012 5:52 PM
Looking at those plates of AM Sky that were posted, it looks quite similar to the MM Sky S out of the bottle.
Eric
    July 2006
Posted by constructor on Sunday, December 30, 2012 9:46 AM
I encountered this color in one of my builds, "azure blue" which is a bit more blue. I think they used it in their desert camo for Hurricanes and Spitfires.
    February 2012
Posted by lawdog114 on Sunday, December 30, 2012 7:04 PM
Jester75
I agree. I tried to match my old Model Master bottle of Sky S with Tamiya colors.  i came up with XF-21 Sky and a dash of of XF-3 flat yellow.  It looked dead on to me.  Just paint it so it looks right to your eye.  This practice has been working for me so far.  Truthfully, once its cleacoated, decaled, panel line washed, dullcoated etc...(if your so inclined) the color is going to change anyways.
Joe
    December 2006
Posted by Jester75 on Sunday, December 30, 2012 7:12 PM
Very true Joe.
Eric
    April 2006
Posted by jgeratic on Monday, December 31, 2012 2:38 AM
... hmm, well the research is out there if you are interested.  The one thing you have to be open to is during 1940 there were several standard colours used, not to mention the use of paints mixed at squadron levels.  Factories also had to make do with what was at hand until supplies of Sky Type S became available.   As has been said before, Sky Type S was pretty much standard issue by mid-September, and would continue to be used until the advent of the Day Fighter Scheme, around the middle of August 1941.
As far as sky blue is concerned,  Alan has kindly provided the two options that were standard colours back then.  BS 381c no.1 Sky Blue (also refered to as duck egg blue) is a deeper blue/green colour.  Am Sky blue in much lighter, with a hint of blue, unlike Sky Type S which is a grey/green colour - there is a noticeable difference when compared side by side.
Azure blue doesn't enter the picture here, it was a colour introduced for tropical based aircraft.
regards,
Jack
    October 2005
Posted by antoni on Monday, December 31, 2012 4:13 AM
constructor
Azur Blue did not exist at the time of the BoB, not being  invented and named until December 1940.
    October 2005
Posted by antoni on Monday, December 31, 2012 4:25 AM
LDSModeller
Regards
Alan
There were no later, earlier, darker, lighter, upside-down, inside-out, or any other variation of Sky. The colour remained the same throughout its use. First used by the PRU it was adopted in the beginning of 1940 by bomber command for the undersides of day bombers. When it was adopted throughout the RAF in June 1940 it was in short supply and consequently a number of similar colours were substituted. Sky did not become common until September 1940. BS381c Sky Blue was one of the substitute colours used. The Sky Blue in the current version of BS381c is slightly different from the 1930 edition. Best described as a pale Aquamarine.
There never was a colour in use by the RAF called Duck Egg Blue. Duck egg blue was first used by an AM official in response to a question as to what Sky was. After that that duck egg blue became a commonly used alias for Sky. Previously Sky was usually described, more accurately, as a duck egg green colour. In recent years some authors have used duck egg blue as a sort of collective term for BS381c Sky Blue and similar colours that were used as substitutes for Sky. Duck egg blue is an accurate description for the pale Aquamarine colour of BS381c Sky Blue.
It is sometimes said that there was no colour Duck Egg Blue. Not entirely true as the RNZAF used a colour called Duck Egg Blue 33B/N.90, S13-909. The RNZAF used the same 33B Stores Reference   as the RAF. The letter N indicates that the colour was locally produced and S13-909 is the paint manufacturer’s code. The colour did not match Sky. Most similar are BS381c Sky Blue or BS381c Pale Blue. It was the standard under surface colour for Harvard, Hudson, Kittyhawk and Ventura.  The also seems to have been a deeper, richer variant similar to BS381c Verdigris Green used on Vildebeeste, Vincent, Oxford and communications aircraft.
White Ensign Models have both BS381 (1930) Sky Blue and AM Sky Blue in their Colorcoats range, ACRN29 and ACRN24 respectively.
I wrote a detailed post on the history of Sky and Sky substitute colours with photographs of examples here (my last post near the bottom):
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/140999.aspx
It is very likely that Xtradecal used as reference one of the more recent publications such as The Battle of Britain Camouflage and Markings 1940, Peter Scott and Gary Madgwick, The Aviation Workshop Publications. The Sky Blue they refer to will almost certainly be BS 381c (1930) Sky Blue.
    April 2010
Posted by LDSModeller on Tuesday, January 1, 2013 2:17 AM
Certainly the term 'Sky" was in use early on in the peace (pre war), and early WWII.
However not all, is so simple, as there were other colours in the melting
pot so to speak, such as 'Eau De Nil" and terms as Camotint, which existed
also and had more of a direction to the eventual "Sky Type S" as we know it.
I would suggest reading this article, the gentlemen who writes this blog is very
well researched and in my opinion quite authoritive.
amair4raf.blogspot.co.nz/.../blue-skies-and-duck-eggs.html
With respect to the references to the RNZAF, not so cut and dry.
The RNZAF had two versions of Duck Egg Blue
1) (NZ) Duck Egg Blue:  BALM S13-909.  33B/N.90
2) (NZ) Duck Egg Blue (this one darker than the previous)
In his book  'We Also Served",  WWII veteran Wally Ingham (RNZAF Air frame fitter) made mention that parked out on the strip, there were many aircraft all  Quote" painted in Duck Egg Blue,
like the RAF" end quote.
As to the P 40's and Venturas and Hudsons wearing Duck Egg Blue, many of the
early  P 40's (E version and some M versions) Hudsons and Ventura's arrived from the United States in US "RAF" versions of Camouflage being Dark Earth/Dark Green/Sky.
To make understanding easier, I will deal with the P 40 E's, but comments for Hudsons etc will be similar.
In early 1942 the RNZAF received a shipment of P 40E's from British Stock held in the USA.
The Aircraft were painted in RAF colours using DuPont paints that were a version of RAF colours, being Top: Dark Earth/ Dark Green and Sky lower (per Curtiss documents held by RNZAF Museum).
The DuPont colour for Sky (US version) was DuPont 71-021 Sky Type S Grey.
This paint was a Bluish/Greenish colour with a grey tint and was colloquilally called Duck Egg Blue in the US and would have for the RNZAF as well.
This restored P40E shows how the aircraft would have looked circa 1942, note the lower colour
i40.photobucket.com/.../FILE0263copy_zps5a2334d5.jpg
The Duck Egg Blue  (manufactured either in New Zealand or Australia under the BALM series)
would have been close to the US version for repairs etc.
The RNZAF did use Sky for Spinners and aircraft codes, some of it's aircraft for example No. 14
Fighter Squadron P 40E's, had "Sky" spinners and Codes. Ths 'Sky" would have been very similar
to RAF Sky AKA Duck Egg Blue.
Later in 1942-43 RNZAF Aircraft began to be camouflaged in New Zealand colours of NZ Blue Sea Grey/Foliage or Dark Green/Sky Grey. This generally only applied to New Zealand based aircraft.
Later toward the wars end, in New Zealand, aircraft began to be painted in Foliage Green/Sky Grey.
(this also applied to returning P 40's from the Operational areas  used for training)
(NOTE: Other lend lease aircraft, wore what ever colours they arrived in, in the forward operational areas (TBF-1's P 40(M-N) SBD's F4U's etc)
The Sky Grey, interestingly had a similar hue to the Original Sky Type S - Grey, that the previous US built aircraft wore on arrival.
Videbeests/Vincents/Oxfords ect, would have worn Duck Egg Blue.
The only other green (non camouflage) found on WWII era RNZAF aircraft was a matt green for ID purposes.
Harvards wore either Trainer Yellow or Dark Earth/Dark Green/Yellow.
Regards
Alan
