DLButter
I just recently started the Special Hobby 1/32. The instruction sheet is drawings only and are very vague, especially where the resin cockpit is concerned. It took multiply dry fits and lots of experimenting to come up with something that might work. Also have found a fair amount of flash and some not so well fitting parts. One half of fuselage has a short shot on the scoop behind the cockpit while the other half has flash. I think this may take awhile. Anyone else have simler exp?
DLButter
I did one last year, out of the Revell boxing. It had its typical "limited run" qualities, which does require another set of skills, that is not necessary with todays top standards in injection molded kits...ie...Tamiya, Hasegawa, etc. Extra filling, extra sanding, extra trimming to make parts fit....as frustrating as it can be, that's part of the fun for me!
