Show off your F4 Phantoms!!!!
    June 2009
Posted by jimbot58 on Friday, October 3, 2014 3:21 AM
One of my Phavorite planes!
I will add my 2 completed kits. Another phour or phive are in the stash.
Both of these are Hasegawa kits.
F-4F with decals robbed from a Testors/Italeri kit. That kit was not very good, but I liked the decals-and wanted to do this color scheme. Sidewinders from a Hasegawa weapons set
F-4G "Wild Weasel". This kit was something like 25+ years in the building. I had it mostly finished, with paint and decals for a European "Lizard" paint scheme, then the kit was abandoned for all those years. One day picked up the kit and and decided I really wanted to do a Phantom in SEA markings. Paint and decals were stripped off to be redone. Some parts were missing and the above mentioned Italeri kit was used as a donor for some of those. A nasty crack across one wing had to be repaired as well. Weapons and ECM pod from Hasegawa after market sets.
I want to do more Phantoms and have an RF-4B partially built that kind of stalled, but someday......
On my workbench now:
Fujimi F-4K Phantom "Yellow Bird" and Zvezda Su-27SM Flanker
    February 2012
Posted by F105nut711 on Saturday, October 4, 2014 7:21 AM
Well I WAS going to say that seeing all these great Phantoms motivated me to dig out my Testors F-4G Weasel to mark my return to the hobby BUT... My son saw that it could be built as a German bird. So I well be posting pics of his Phirst Phantom! PS who makes the weird German colors? Super builds everyone!
    June 2009
Posted by jimbot58 on Saturday, October 4, 2014 8:09 AM
The instructions have mixes you can do yourself. Iet me know if you find them.
    June 2013
Posted by bvallot on Sunday, October 5, 2014 4:14 PM
=D I'm starring off this thread.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    August 2014
Posted by goldhammer on Monday, October 6, 2014 2:37 PM
Went out and got the Hasegawa 1/48 RF4E JASDF kit to backdate to an RF4C (not worrying about the slats or other minor differences)
IIRC the "C"'s did not have the rear windows under the nose back past the triangular bulge and windows there.  yes or no?
Worked ECM on them at Udorn RTAFB and Shaw AFB, but that was early mid 70's, memory bit fuzzy now.
Looked to aquire  the "tumbleweed" decals since that bird was at Udorn in my time, but looks to be long gone, but have query in.
Would also like to find the ECM pods, if someone has any running around in their spares box.  Both the ALQ-119 and  ALQ-71.  Worked in the ALQ-71 shop there for most of the tour.  From what I have seen of the resin version of the 71 they missed on it.  Sides are smooth, was 10" diameter, so it looks fat in the pics I have seen.
Drop me a PM if you have and want to get rid of any of the above in decals or pods.
Thanks, Art
    November 2003
Posted by mississippivol on Monday, October 6, 2014 6:27 PM
I don't have the decals or pods you need, but I can help with some info. The SEA scheme #'s are: dark green 34079, med green 34102, tan 30219, grey underside 36622. I think the RF-4C's had another window underneath between the bulge and the nose gear well, from what my references show. Good luck on your project; hope you'll post some pics when you're done!
    August 2014
Posted by goldhammer on Monday, October 6, 2014 6:31 PM
Thanks for the color #'s, hopefully I will get a hit on the pods and decals or an answer from Micro and Super.  I never got into the e-bay thing........
    November 2003
Posted by mississippivol on Monday, October 6, 2014 6:33 PM
Same here. If you need some diagrams of the scheme layout, you can go to cybermodeler.com and look under their reference tab. They have several Phantom camo scheme layouts there.
    March 2005
Posted by TarnShip on Tuesday, October 7, 2014 1:19 AM
I am somewhat puzzled by your description of what camera windows "the C did not have".
That is because there were "Rounded nose" and "Squared off nose" versions in each RF-4 series, depending on which block they were built in. RF-4C had both noses on different serial numbers, so did RF-4E,,,,and even though almost all RF-4B had the "Angular or Squared off noses", the last three had that rounded nose shape that the USAF also used.
The quick way to tell which set of kit nose parts to use is to look for the prism at the bottom of your decal's drawing,,,,,,it that is there, it is a square nose,,,,if there is a larger, smooth window there, that is the rounded nose.
Hope this helps
Rex
almost gone
    August 2014
Posted by goldhammer on Tuesday, October 7, 2014 9:38 AM
Tarn-  Thanks for that.  Our 4 boxes of gear was in the front left side of the camera bay, so never looked back to see what the glass configuration was, and of course being about 20 didn't care either.......but do have two rolls of slides somewhere of a couple in the revetments showing the color scheme and revetment walls.  Never will find those I suppose though.LOL
The pics I have seen of the 119's all look like there is a bulge on the front that hangs down below the "gondola" lower section.  If so that is a later mod, as the 119's in the early to mid 70's were just the 10 inch diameter upper section and the 8 inch lower gondola.  Back then the radomes were 10K each, and the gondola is nothing but circuit cards on edge crossways.  I dropped one on a taxiway when the cradle broke coming back from "fox" area.  Closed the taxiway for close to two hours till we got everything loaded on a trailer and the FOD sweep done.  About 240K damage to said pod since I managed to park the MJ-4 on top of the back third of it.  We only ran a two "can" set at Udorn (73/74) for the ALQ-71's, but at Shaw we ran a three "can" setup (76/76)
    March 2005
Posted by TarnShip on Tuesday, October 7, 2014 1:06 PM
 Gold, I think we need a good primer on ECM pods. Most models of just about any of the pods give us one version,,,,,,,and don't even mention the variations.
A really good example of the differences that can look almost the same from a distance is Berny's old chart posted in a Phantom build thread on here.
Many modelers wind up thinking that "company A got it wrong" when in reality, they might have just picked a diffrent sub-type of the pod.  (-131s are good for different visual appearance also)
Rex
almost gone
    August 2014
Posted by goldhammer on Tuesday, October 7, 2014 3:12 PM
Started a thread in General Discussion so as to not hijack this any further.  Thanks for the idea.
Art
    November 2003
Posted by mississippivol on Wednesday, October 29, 2014 10:02 PM
Monogram 1/48 F-4C of the Arkansas Air National Guard. Box stock with kit decals:
