Good Aluminum Paint?
    May 2014
Posted by SubarooMike on Monday, July 14, 2014 9:40 PM
      Hello everyone!   First off I would like to say I know this is probably not the correct section of the forum for this questions, but I know there a lot of modelers in this sections that will have great answers.
My latest build requires aluminum (Airfix's newly-tooled braille-scale P-51; what a gem of a kit), but I do not have the funds for Alclad at the moment.  I planned on using Testors flat aluminum, but I have found it impossible to airbrush. No matter what I do it clogs up my brush (i'm assuming because of the metallic). It's, in my opinion, liquid crap.
So -- I am looking for an affordable aluminum (cheaper then alclad) that you personally have experience airbrushing and that airbrushes well. Thank you for your help!
  -- Michael
    February 2012
Posted by lawdog114 on Monday, July 14, 2014 10:20 PM
Sorry Michael.  There really isn't a substitute for Alclad anymore.  They know this, which is why it is expensive.  You can try Testor's "metalizer" paints but they are fragile and you can't tape over them.  Tamiya XF-16 flat Aluminum thinned with their X-20 thinner might work as well.  You could always go the Tamiya AS spray can route too which. like Alclad, is lacquer based durable.
Good Luck,
Joe
    February 2011
Posted by Reasoned on Monday, July 14, 2014 10:23 PM
oops
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    February 2011
Posted by Reasoned on Monday, July 14, 2014 10:26 PM
Michael, not sure if you're looking for an enamel or Acrylic.  I've not used a NMF airbrushed (save Alclad), my experience has been very positive with MM Metalizers from a rattle can and they're relatively inexpensive (it's a lot easier too)Wink  Joe is correct, they can be easily scuffed if not sealed properly.
    July 2004
Posted by stikpusher on Monday, July 14, 2014 10:31 PM
I have had very good results with Humbrol. They make three different shades, two which are like Metalizer, with one being buffable, and both being on the lighter side. And one that is in their standard paint type and more of a faded grayish shade. It looks really good for weathered aircraft. I have also had good results with Tamiya flat aluminum.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    March 2008
Posted by Caveman on Monday, July 14, 2014 10:32 PM
I have had reasonable results with Citadel metal paints.  They thin forever and can be durable.  Just got to get used to the funny names they give the paints.
    January 2013
Posted by BlackSheepTwoOneFour on Monday, July 14, 2014 10:44 PM
The P-47 Thunderbolt I'm working on is spray painted with Tamiya Bare Metal Aluminum. Never had a problem using it in rattle can form. Maybe you can try that alternative instead.
    June 2014
Posted by BrandonK on Monday, July 14, 2014 10:55 PM
I've sprayed with the MM Metalilzer's as well as Mr Metal Color, and although I like them and how they come out they are VERY delicate and easily damaged. Not what I'd try to use on the overall scheme. I only use them on small parts.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2005
Posted by TarnShip on Monday, July 14, 2014 11:09 PM
Two tough Acrylic paints are Floquil Polly Scale Stainless Steel and Sante Fe Silver.
Both are available at these sites www.internethobbies.com and www.internettrains.com/.../merchant.mvc
There are some around on Tower Hobbies also, both Polly Scale and Floquil Enamel, but, I didn't check there for the colors.
hope this helps
Rex
almost gone
    June 2014
Posted by BrandonK on Monday, July 14, 2014 11:29 PM
I just watched a vid on youtube about this problem. I'm currently building a P-51 and I'm gonna do it this way just to see how it works. I'll be base coating with Rustoleum gloss black and top cut with Dupli-color chrome. It's not Alclad, which I have, but it doesn't look half bad. I will decant both before I spray and I'm hoping for a smoother finish than I get now with Alclad gloss black base but it's most likely just me. I will post picks when it's done, good or bad so we know. It will be a cheap paint job for sure. I hope it works.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, July 15, 2014 7:31 AM
There you have it. Lots of options yet so hard to pick what you want to do. :))
    November 2008
Posted by plasticjunkie on Tuesday, July 15, 2014 7:54 AM
If you want the model to look like metal then you go with Alclad.  It takes very little  Alclad to get the metal effect because it's extra thin and goes a long way. I'm just very happy at the realistic metal tone that Alclad delivers out of an air brush that other metallic paints fall short on.
 GIFMaker.org_jy_Ayj_O
    May 2014
Posted by SubarooMike on Tuesday, July 15, 2014 8:58 AM
I would first like to say thank you to each and every one of you who took the time to give me your opinion and timeBig Smile
I was not looking to necessarily to replicate a natural metal finish as much as much as just make it look presentable.  BUT I think I will just break-down and buy Alclad.  It seems like one of the few finishes that EVERYONE loves AND can be easily masked over.
That being said, I definitely don't have the funds to buy every shade of aluminium they offer.  So what is a good shade of aluminium that they offer that is a good general shade.  Not factory fresh, but not heavily oxidized either.
Posted by Don Stauffer on Tuesday, July 15, 2014 8:58 AM
I have never had any trouble airbrushing Testors flat aluminum.  While I prefer Alclad, I do occasionally use the Flat Aluminum enamel.  I thin to the amount I ordinarily use with Testors enamels, and it works fine.
    November 2008
Posted by plasticjunkie on Tuesday, July 15, 2014 9:11 AM
Instead of buying multiple shades of Alclad, you can use several shades of black and grey paint on the panels as primer. Just vary the shades between panels.  Glossy paint will give a more shiny metal appearance, flat paint gives a weathered look. By varying the primer shades, one shade of Alclad will yield several tones on the panels.  This is one way to keep your cost down.
The trick to Alclad is to spray it thin to let some of the primer background come thru giving some depth. Just shoot light coats and look at the effect. If you don't want a shiny clean look then go with the non high shine tones.
Make certain that the surface is perfectly smooth and that the primer goes on smooth and not pebbly. If you get some orange peel then lightly polish the area out before using the Alclad. This will give you the metal look you want.
    April 2005
Posted by wing_nut on Tuesday, July 15, 2014 9:19 AM
I find Tamiya XF-16 flat Aluminum  to be too grainy to look good.  But that's me.  When someone comes out woth something that beats Alclad, I'll try it.  But in the mean time...
Marc
    July 2004
Posted by stikpusher on Tuesday, July 15, 2014 5:58 PM
I like using Tamiya Flat Aluminum to represent lacquered surfaces such as P-51 wings, 60's era Century Series fighters, etc. Once gloss coated for decals and sealed with a satin coat, it really looks the part.
       - Plankton
LSM
    April 2014
Posted by r13b20 on Wednesday, July 16, 2014 8:44 PM
I can't add anything to this discussion. Except that the "liquid crap" comment was very funny! My brain is weird that way, sorry. Bob
