1/48 Academy F-86F-30
    April 2010
Posted by Mustang8376 on Tuesday, December 16, 2014 8:16 AM
I am in the process of building my first NMF model before I start an inter-office completion. (Revellogram Mig-21PF)  So I am more focused on trying to get the exterior correct over the interior.  I had this one in my stash since 2002 when I picked it up while deployed to Korea.  I've gone through all of the FineScale magazines in my possession regarding how to build and paint a NMF jet, but any hints and tips that anyone has I would be appreciated.
Current build: 1/48 Monogram A-1H & AMT Jedi Starfighter.
Completed:  1/48 Monogram/Revell P-61B, 1/32 Hasegawa F6F-5, 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
    June 2014
Posted by BrandonK on Tuesday, December 16, 2014 9:12 AM
I love the look of the F86. Looks great so far. The NMF finish is finicky at best but I enjoy trying. Can't wait to see how this turns out.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by oortiz10 on Tuesday, December 16, 2014 10:35 AM
Mustang8376,
I enjoyed building this kit.  Looking forward to seeing what you can do with yours.
Happy modeling!
-O
-It's Omar, but they call me "O".
Posted by echolmberg on Tuesday, December 16, 2014 11:33 AM
Mustang, the Academy kit went together so very nicely for me.  I hope it's treating you the same way.  Are you going to be using the kit decals?  Let me put it this way...I hope you're not planning on using the kit decals!  When i built my Academy F-86, the quality of the kit was phenomenal but the decals pretty much caused me to trash my build.  The kit decals were so unresponsive to the setting solutions I used that they might as well have been made out of Scotch tape.  They did not adhere to any curves.  They did not sink down into any of the panel lines.  They were pure garbage.
I tried lifting the bad decals off with masking tape.  It sort of worked but I just couldn't get rid of them.  The more I tried to strip the decals and paint off, the worse things got until I couldn't take it anymore and I tossed the whole works.  That was maybe five years ago.  I hope they're improved them since then.
Eric
    April 2010
Posted by Mustang8376 on Tuesday, December 16, 2014 2:33 PM
Looks like I will need to be on the look out for some after market decals.  The build has been interesting.  While it came together fine, there was just enough issues to cause frustration.  Mostly dealing with cockpit and pilot fit issue with the canopy.
    November 2003
Posted by mississippivol on Tuesday, December 16, 2014 4:34 PM
I'm a Model Master Metalizer guy myself (cost), but you will want to check out the guys using Alclad. Simply great stuff, properly applied. There's usually a natural metal finish group build going on, or one that's been completed which should give some info on how it'll work.
    January 2014
Posted by jelliott523 on Tuesday, December 16, 2014 4:41 PM
Just my .02, I was terrified of trying Alclad products; they just sounded so technical, I thought there was no way that I'd be able to get a nice finish.  Granted, I haven't used a lot of the product yet, but what I have used has turned out really nice.  You can find complete threads on the painting board about using these products.  There is a ton of great information out there.  Also take a look at some of the videos on youtube.
Posted by echolmberg on Wednesday, December 17, 2014 10:48 AM
I'd also like to add another suggestion about painting a natural metal finish on aircraft.  I have had nothing but good luck using Floquil Silver Mist and Old Silver.  They are extremely forgiving, easy to use, tough as nails and holds up to masking.
Just a couple of examples...
Eric
    April 2010
Posted by Mustang8376 on Wednesday, December 17, 2014 10:54 AM
Those look nice! :)
Posted by Texgunner on Wednesday, December 17, 2014 10:59 AM
echolmberg
Eric
I agree Eric, those Floquil silvers do work well.
Old Silver:
Bright Silver:
Gary
"All you mugs need to get busy building, and post pics!"
    April 2010
Posted by Mustang8376 on Monday, December 22, 2014 8:57 AM
Assembly is just about complete.  Ran into an issue since I am building this wheels up, not wheels down.  So some fit issues with the gear doors.  Plus, for some reason the front of the model near the nose does not sit flush.  There is a good size gap and step between then nose cone/engine intake where it mats to the fuselage.  Looks like I am going to be doing some puttying and sanding. :)
Posted by Gamera on Monday, December 22, 2014 10:01 AM
Mustang: Very cool! I'm building the same kit and had a few problems with the forward intake though I think I installed the cockpit too far back though.
Frankly I've been using Alclad for years, it itself is almost foolproof, the big issue with it (and most NM products) is getting a perfect and I do mean perfect undercoat since any flaws in the under surface will show up like a sore thumb in the NM.
I undercoated mine with Model Master Gloss Black Acrylic- the only gloss I can get to go down without really bad orange peel.
And then applied a couple of coats of different shades of Alclad. And yes those yellow stripes are a pain, I need to touch up a number of spots here and there.
Eric and Gary: Those look pretty darn good too!
    April 2010
Posted by Mustang8376 on Monday, December 22, 2014 10:24 AM
Very nice.  I was wondering if an acrylic undercoat would work with Alclad.  You just answered my question.  Are those the kit decals regarding the stripes??
Posted by Gamera on Monday, December 22, 2014 11:40 AM
Actually enamel might work better as an undercoat, since it dries slower it might be less likely to orange peel. But as to the Alclad melting either, it seems ok on the the acrylic finish.
I bought a set of aftermarket decals but they didn't include the stripes so yeah they're the original Academy decals there. I didn't have quite the same problem as Eric but still big decals like that are such a pain to get lined up properly- there are some small gaps and overlaps as you can see on the top. It might be easier just to paint them but I was a little afraid to try it. Going to try to use them as a guide to overspray the gaps there.
    April 2010
Posted by Mustang8376 on Monday, December 22, 2014 12:34 PM
Thanks for the info on that.  Will try to work on this build sometime this week.
Posted by Gamera on Monday, December 22, 2014 1:03 PM
Cool, looking forward to seeing how she comes out!
    April 2010
Posted by Mustang8376 on Wednesday, December 31, 2014 3:50 PM
Deluxe Material Putty has arrived earlier this week.  Will put some work on this build in the next day or so.
    August 2013
Posted by Jay Jay on Thursday, January 1, 2015 10:19 AM
Hmm looks like bad fit issues there.  I'm thinking of building the F-86 as my 1st jet.  The LHS has only the Revel in 1/48 but I'm hesitiant to buy it because I don't know if it's any good.
How does the Revel stack up to the Academy ?
Can anyone tell me what the best 1/48 F-86 kit is out there ?
Posted by Gamera on Thursday, January 1, 2015 10:25 AM
From advice and internet reviews I've read the Academy and Hasegawa kits seem pretty equal in quality- both have strong and weak points. The Revell kit is older and not bad but not as detailed as the other two. I didn't encounter any real issues with the Academy kit other than the intake but I think it's more my own mistakes than problems with the kit.
Posted by Texgunner on Thursday, January 1, 2015 11:14 AM
While it is a much older kit, the Monogram F-86 can be made into a nice looking model.  Mine came in the double kit along with a MiG-15.
Gary
    April 2010
Posted by Mustang8376 on Friday, January 2, 2015 4:10 PM
Glad to see issue with the intake may not just be a mistake on my part. Overall, I am very happy with the model. Will be back to work on this within the next couple of days.
    March 2005
Posted by Devil Dawg on Friday, January 2, 2015 9:52 PM
Good Luck on this build!!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    April 2010
Posted by Mustang8376 on Monday, January 5, 2015 8:25 AM
Had the chance to work some on the model last night.  I was apple to try out the Deluxe materials putty and I am happy with it so far.  Very easy to use.  I am also in the process of sanding the seam lines, glue spots, and any of the panels that are not flush.  Still trying to figure out what to do witht he nose section that isn't flush on the right side.
    January 2003
Posted by murph on Sunday, January 11, 2015 10:36 AM
Good luck with your Sabre.  For a great NMF, it's all abut the surface prep of the plastic and the primer coat.  I use Alclad for all my NMF builds.  Get the surface of the model as clean and as bump and lump free as you can.  As a primer for Alclad, I use Model Master enamels exclusively.  Depending on the sheen I'm going for, I use MM Light Grey for a subdued look and for higher sheens I use MM Gloss Black.  I spray the enamels at 18-20 psi and the Alclad at 12-15 psi in very light coats and build up instead of one thick coat.
When I think I'm satisfied with the finish of the plastic, I spray a light coat of flat grey as primer to check for imperfections and rework as necessary.  I'll then shoot my primer coat and let it dry thoroughly.  If the flat light grey primer, I polish it with an old cotton tee shirt to smooth the paint and hopefully remove any lint that may have been caught in the paint while drying.  If the gloss black primer, I always wet sand with 2000 grit paper to remove lint / dust in the paint.  I always handle the primed model with white cotton or vinyl gloves.  With practice and patience, the Alclad 'intimidation factor' decreases quite quickly.
Here's a few Alclad finishes for you:
Two light gloss coats of gloss black covered with mist coats of Alclad #106 (white aluminum)
Two light coats of gloss black covered and Alclad #12 (duraluminum)
Two light coats of light grey covered with mist coats of Alclad #108 (pale gold)
Two light coats of light grey covered with mist coats of  Alclad #106
Retired and living the dream!
Posted by Gamera on Sunday, January 11, 2015 5:03 PM
Mustang: Looks good, you're making nice progress there.
Murph: Those look great! And good advice there, thanks!
    April 2010
Posted by Mustang8376 on Tuesday, January 13, 2015 7:46 AM
    August 2008
Posted by tankerbuilder on Tuesday, January 13, 2015 10:52 AM
I gotta say:
  You got a good start going there .On the NMF , now , I am a bare metal fellow .Why ? Well , I don't really know , unless the first one I did , I took so much time getting it right , It was the first ever plane that copped an award . No , I didn't plan that !
   My students entered it in my name . In a National contest at that ! Was I embarressed ! You see , for me it was an example to my students to shoot for . Not to be in competition with !
   All in all . though I think it is my preference anyway .To me Alclad and the others look to painted . To me They are beautiful in their own right  . I just prefer B.M.F .
    April 2010
Posted by Mustang8376 on Friday, January 16, 2015 8:15 AM
Had the chance to do some more putty work and sand some more.  Not too bad.  Of course, I rush and couldn't wait to attach the canopy.  Also, first time I can actually recall trying to blend in any type of a seam on a build.  Room for improvement, but overall I am happy with it.  I am sure I am going to regret doing so, but what can you do. Big Smile
Posted by Gamera on Friday, January 16, 2015 10:21 AM
Looks pretty darn good to me Mustang.
    February 2012
Posted by lawdog114 on Friday, January 16, 2015 8:06 PM
Looking great Mustang.  It's not you, I had the same issues when I built this kit a few years ago. I look forward to your progress.  My 2 cents, Alclad all the way.  It's second to none for a NMF.
Joe
