Phantom kitbash- Happy Hooligans ND ANG F-4D-Finished! 5-21
    March 2010
Posted by Nathan T on Friday, January 23, 2015 7:22 PM
I've been wanting to build a North Dakota Happy Hooligans bird for quite awhile now as ND is my home state, and seeing many of their aircraft at airshows in Fargo growning up has really fueled my interest in the 119th figher wing's history. The phantom just looks perfect to me wearing the Hooligans logo in Hill Gray camo. Like here:
The problem is no decal manufacturer makes markings for a ND F-4 in Hill gray. After lots of scrounging and Help from a great FSM Forum Memeber- Thanks Oritz!, I've got the tail codes and markings I need.
Now for the kit- I looked at Academy's new F-4C as the parts for a D are in the box, but I couldnt' get the kit shipped to me for less than $70 and having built a few Hase phanotms I just didn't feel like giving the Academy kit and it's multi-colored plastic a try. The old Hase F-4D has raised panel lines, and I don't feel like rescribing a whole kit. So I got the F-4J kit as a base and I'll use a few parts from the raised lined D.
On to the pics:
Lots of Aftermarket here, as I need a cockpit specific to the D,as well as the short exhausts, which will come from Eduard's excellent Brassin set. Stabilators of the unslotted type come from Hypersonic models. This is a great, comprehensive resin set that includes some pe as well for the boiler plates and pivot plate. The kit stabs in the old D kit are undersized, otherwise I would rescribe and use those. Here's a closer look at the set:
Here's a look at the decals:
I have another set from Afterburner coming that has all the gray lettering for the tail codes as well as the nose wheel numbers. The Hooligans logo comes from the Caracal set. This set is actually for an earlier F-4D in ADC gray, so the insignias and stenciling/wing walk decals are wrong for a Hill gray A/C. Other stencis from the Xtradecal sheet will be used as necessary.
Oritz on the Forum here gave me some spare decals from an older Microscale sheet for a Hooligan phantom in SEA camo. It has the correct ND ANG badge for a hill gray phantom, as well as the correct style ribbon. Thanks O!! Here's the differences:
Here's a shot of the resin goodies:
I started with the wings. Assembled the halves together and started grinding off the wheel bumps on the top:
I used a dremel for the major work, then sanded it smooth. The panel lines then got a rescribing like so:
Now on to the cockpit:
Aires seats:
Kit sidewalls have been thinned, and the resin pit being dry fitted:
The pencil marks are to line up the sidewalls when I'm ready to glue. Time to make sure the windscreen fits over the resin:
Got some MR. Surfacer black primer on and the cockpit sprayed in DDG:
Painted the back side of the acetate instruments off white:
I was gonna use the nose from the D kit, but most of the ND birds had the Ds without the chin pod IR sensor. I figured I would just use the J nose and cut off the small antenna. I'll save the D nose for another build:
More to come!
    July 2007
Posted by scorpr2 on Friday, January 23, 2015 8:54 PM
She's looking good!  Keep up the good work!!!
    March 2010
Posted by Nathan T on Tuesday, January 27, 2015 1:00 PM
A few boring dry fitting:
Adding plastic shims to the underside wing/fuselage gap:
The kit intakes fit pretty good if you take your time and dry fit:
White plastic card was glued behind the intake to close the infamous Hasegawa gap:
Checking the sit of the seats:
Phront looks Phine, rear seat sits too Low. Looks better now:
Detail painting of the pit is underway, so more later after my eyeballs recoverIndifferent
    March 2010
Posted by Nathan T on Monday, February 9, 2015 4:55 PM
Have a little more progress to show. Cockpit has been painted up and gloss coated. An oil wash will follow. The instrument panels havent' been assembled yet. I tried a few pics with and without flash:
I've turned my attention to the Eduard Resin exhausts. I had to delete some panel lines and make new ones on my -J fuselage appropriate to the -D, as in this pic:
I sanded the edge where the exhaust will be glued to the fuselage at an angle to get the proper tilt, and made a new panel line to mimick the thickness of the stainless band on the fuselage:
Once the burner cans are in place I can close up the fuselage, and things will move much quicker then Cool
    August 2012
Posted by AndrewW on Monday, February 9, 2015 5:08 PM
Wow, awesome work so far, Nathan!
Life is hard, it's even harder when you're stupid - John Wayne.
    January 2015
Posted by TheMongoose on Monday, February 9, 2015 6:27 PM
I love seeing all this detail.. It give a good perspective of what it takes to create a really exquisite build. Thanks for sharing. Great work!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    March 2010
Posted by Nathan T on Monday, February 9, 2015 6:34 PM
Thanks guys. There's lots more details to add, I just hope I can paint them up good enough to show them off.
    February 2012
Posted by lawdog114 on Monday, February 9, 2015 6:42 PM
Excellent work Nathan.
Joe
    November 2003
Posted by mississippivol on Monday, February 9, 2015 8:09 PM
Phreaky! Lookin' great, Nathan!
    March 2005
Posted by Devil Dawg on Monday, February 9, 2015 10:37 PM
Impressive, Nathan!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    March 2010
Posted by Nathan T on Monday, February 9, 2015 10:43 PM
Thanks pholks
    September 2014
Posted by rooster513 on Tuesday, February 10, 2015 8:36 AM
Looking great so far Nathan! Might be a silly question, but what's that tool you're using to scribe the panel lines? I'm building a F6F right now and have lost some panel lines from sanding the seams. Looks like your lines came out perfect!
-Andy
-Andy
    March 2010
Posted by Nathan T on Tuesday, February 10, 2015 8:43 AM
Thanks Andy. The scriber is from umm-usa.com. Best scribing tool out there.
    September 2014
Posted by rooster513 on Tuesday, February 10, 2015 8:49 AM
Thanks Nathan. I'll look it up. With that tool and the tape looks like you have a great amount of control. Looking forward to seeing more.
-Andy
    November 2008
Posted by mrmike on Tuesday, February 10, 2015 12:29 PM
Following along with interest Nathan, As usual, your attention to detail is amazing and your work is first cabin!
    March 2010
Posted by Nathan T on Tuesday, February 10, 2015 12:55 PM
Thanks for checking out my build Mike.
    March 2010
Posted by Nathan T on Friday, March 27, 2015 11:44 AM
Update time coming very soon, but first...a question:
Anyone know if the Navy style refueling prob door was on the F-4C/D? I know the prob itself was gone of course but was the door still on the starboard fuselage? Wondering if I need to fill that on my kit?
    January 2015
Posted by Aldershot II on Saturday, April 11, 2015 9:38 AM
USAF F-4C/D's fuselage was flush with no panel lines where the refueling probe would have been on the side of the cockpit. That should have the panel lines filled for this. I was very familiar with the ND ANG aircraft and the "smooth" nose radome  was only used very late in the units use of the F-4D. For most of that unit's use of the aircraft they had the standard F-4D radome.
    March 2010
Posted by Nathan T on Saturday, April 11, 2015 10:34 AM
Hey thanks Aldershot. That's what I assumed and went ahead and filled it. Did you serve around the ND Air Guard? If so, I'd love to hear more.
    March 2010
Posted by Nathan T on Saturday, April 11, 2015 1:10 PM
I've been moving right along with the Phantom. I masked the cockpit and primed the model with Mr. Surfacer 1500 black. Then I sprayed Gunze Gloss black on the radome and the areas that will be painted with Alclad later on. The intakes were painted gloss white then masked off while I started painting the neutral gray:
In the meantime I completed and painted the Eduard Brassin exhausts:
The Aires seats were painted with Vallejo Model colors:
I've also been slaving away at the ordinance. 2 travel pods, Aim-9Js, Sparrows, and outer gas bags:
...Off to start the main camo now.
    August 2012
Posted by AndrewW on Monday, April 13, 2015 12:54 PM
Looking really nice, Nathan.  On those seats, were the harnesses moulded in?  I love the look of those exhaust cans.  I have an Academy kit in the stash that one day I'd like to mark out for the Midway.
    June 2013
Posted by bvallot on Monday, April 13, 2015 1:12 PM
Phantastic ;) job Nate!  Just read through all of this.  I have an F4-E that I'm doing for a friend that flew in the Air Force in the 80s.  Having never built one yet, this ought to come in mighty handy to help with figuring out all the nit-picky corrections that I'll need to make.  I have a somewhat limited grasp of fixing up the Hasegawa kit.  Looking forward to what you have next on deck.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    March 2010
Posted by Nathan T on Monday, April 13, 2015 1:44 PM
Thanks Andrew and Bvallot! The belts on the seats are pe, bent to shape and painted up best I could. Aires always includes the belts as pe.
    August 2012
Posted by AndrewW on Tuesday, April 14, 2015 8:21 AM
I am very impressed at how realistic  you can make those metal  belts look, I always have such a hard time with those.
    March 2010
Posted by Nathan T on Tuesday, April 14, 2015 2:10 PM
Take a stiff tweezers and bend and pull and twist and crumple them best you can, then straighten them out and bend them to your final pose. And don't forget to anneal them first on the fret.
Posted by Gamera on Tuesday, April 14, 2015 2:14 PM
She's looking fantastic so far Nathan!
    March 2010
Posted by Nathan T on Tuesday, April 14, 2015 3:46 PM
Thanks Gamera! I remember seeing you're F-4EJ awhile ago. Great inspiration!
Posted by Gamera on Wednesday, April 15, 2015 8:28 AM
Thanks Nathan but other than the crazy decals my Phantom was pretty much straight outta-da-box. I love all the stuff you're adding here.
    March 2010
Posted by Nathan T on Thursday, April 16, 2015 7:32 AM
Finished painting and started decaling. Its been a tedious process piecing all the markings and stencils from 4-5 different sheets. I swear, every decal has to be evaluated. Canopy lock stencils need to be correct, insignias from one sheet are too dark, so I need to rob them from another. The stencils for the smooth radome have come from 2 different sheets. Hopefully it will be done soon, and I can move on to weathering. I still need to piece together stencils for the ordinance, those will come from 3 different sheets as well!! No one decal manufacturer gives you everything you need!!
    June 2013
Posted by bvallot on Thursday, April 16, 2015 10:38 AM
Daaaaaaaannnng Nate!  This is moving fast, huh?!  =D
On the bench:
