Tail sitter
    December 2014
Tail sitter
Posted by Rory T on Saturday, June 6, 2015 2:17 PM
Hello, building Revells, F/A 18E super hornet in 1/48, do I need to add weight to the nose of this model. Thanks
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, June 6, 2015 2:33 PM
Does the instruction mention using weights? If not, there's your answer. I've done Hornet kits or two and I know for a fact they're not tail sitters.
    June 2013
Posted by RobGroot4 on Saturday, June 6, 2015 2:55 PM
Rory,
I haven't done their E but I've done plenty of Revell F/A-18C's and had no problems.  Is the nose cone a separate part like it is on the C model?  If so, build up the rest leaving the cone off, see how it sits, and you can add weight if needed.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    January 2014
Posted by jelliott523 on Saturday, June 6, 2015 5:19 PM
I've built their "E" model and it is not a tail sitter after its completed.
    December 2014
Posted by Rory T on Sunday, June 7, 2015 12:08 PM
Thank you all for the info,
