How to Apply Instrument Panel Decals?
    November 2010
Posted by Bigb123 on Saturday, September 5, 2015 6:37 PM
Hello,
What is the best way to apply instrument panel decals in large scale aircraft?  For instance, the Trumpeter 1/32 F-18E and it has both raised detail and decals for the instrument panel and cockpit side controls.  How would the decals best be applied?  Thanks!!
    May 2014
Posted by SubarooMike on Saturday, September 5, 2015 7:02 PM
I apply the decal as I do any other decal. Then give it quite a few coats of Micro Sol. After a few coats, the decals hugs down beautifuly over any raised detail.  The trick is lining up the decal instruments over the raised detail!
Posted by Don Stauffer on Sunday, September 6, 2015 10:58 AM
On some kits like that I have drilled out the plastic and glued the decal sheet behind the panel (backing and all, don't wet decal and slide off).  I fill the recess with some of that window making material to give a better gloss representation of the glass.
    November 2008
Posted by plasticjunkie on Sunday, September 6, 2015 6:04 PM
Hi Big
It depends how detailed the IP is. If it's just flat with some anemic details then it's best to punch each instrument and add the decal with a sheeet of plastic sandwhiched together. If details are sharp and rich then I punch out each individual decal and attach them to the proper instrument. Lots of Solvaset will make the decals snuggle down. Then I use Testors Clear Parts Cement for the glass faces.
Here is the IP for a 1/32 Revell Bf109G-6 using my MicroMark mini punch.
 GIFMaker.org_jy_Ayj_O
    January 2009
Posted by fermis on Sunday, September 6, 2015 11:09 PM
Don Stauffer
YesYes
Posted by jeaton01 on Sunday, September 6, 2015 11:27 PM
Hi, Fermis!  Whereyabeen!
John
    November 2010
Posted by Bigb123 on Wednesday, September 9, 2015 1:22 PM
Hello All,
These all seem easy to do.  I apprecieate the advice and help!!
