1/48 Great Wall FW 189 A-2 (FINISHED....)
    February 2012
Posted by lawdog114 on Monday, September 14, 2015 3:37 AM
Here I present my latest build, the relatively new mold Great Wall FW 189 recon/bomber version.  This build is also for a friend, but I've always been intrigued by the Uhu (OWL) so I was excited to try it.  Furthermore, their new P-61 is next on my agenda, so I wanted to see what I was in for with this company.  The Uhu was the eye of the Luftwaffe and was very successful in that role.  It was extremely manueverable and could out turn just about everything.  It was also reportedly rugged and hard to shoot down.  The owl was used primarily on the Russian front, who called it "Rama" (frame) due to the strange design.
I started with the cockpit.  My reference said these could be either RLM 02 or 66, depending when it was built.  This will be a 1943 machine so I went with the latter.  It's nicely detailed but has a two part assembly that leaves a seam line on the side walls.  It sits low so I suspect it will be invisible once everything is added and closed up, so I didn't mess with it.  I added a color Eduard PE set and made flares from styrene rod.  I added wiring to the back of the instrument panel as I suspect it will be seen from the front HE 111 style.
Great Wall is unchartered territory for me, so I followed the instructions.  After I assembled the centre pod,  I attached the wings to the booms.  The wheel wells were painted RLM 02.  The wing boom joints were far from perfect.  I had a step on the starboard lower side....weird....but I muddled through and sanded what I could....that's what putty is for.  I also assembled the engines as they are need to attach the props, but the access doors will be closed so I just painted them black (unless it's a radial it's not my thing)..Big Smile
People have raved about this kit's fit, but I've had nothing but problems.  The wing root joints needed lots of putty.  I buckled down and got it done.  The kit does have poseable control surfaces which is nice, but some genius thought it was a good idea to make you install the landing gears as you close up the booms...so it will be a pain to paint.  Also, ejector marks everywhere in the bay.  I've heard this is their first endeavor into aircraft models so I'm inclined to give them a Mulligan.  Hopefully get made improvements on the P-61.
This turkey is a great candidate for Eduard masks.  These are God send.  My friend wanted the canopies closed, so I attached them before paint.  I used a combination of Tenax and white glue. Any gaps were filled with white glue.
The canopies were then sprayed RLM 66 then everything was preshaded in XF-1 Flat Black.
As I said, this one will be a machine from the Russian front in 1943 which carried RLM 70, 71 over 65.  It had yellow identification markings on booms and under wing tips.  I sprayed XF-3 flat yellow with a touch of XF-7 flat red.  These will get taped off before paint. It's almost time to start the scheme.
    March 2015
Posted by Toshi on Monday, September 14, 2015 5:56 AM
Great start, I'll be following this build closely.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    March 2015
Posted by bpanzer322 on Monday, September 14, 2015 6:17 AM
Looking good. I will definately be keeping an eye on this build.
    August 2013
Posted by Jay Jay on Monday, September 14, 2015 8:01 AM
Coming along nicely LD.  This is a realy cool lookig bird. I may hafta get one .
    June 2014
Posted by BrandonK on Monday, September 14, 2015 10:23 AM
That's a nice looking bird you got going there. I like (love) your techniques and enjoy watching you take us along for the ride. Thanks.
On a side note unrelated to your build. Is it just me or do these twin engine German birds look sexy as all get out until you attach the canopy? Then they look like they have a tumor growing on them. I can only imagine how awesome these would look with smooth canopies.
What paint scheme is this going to have? Looking forward to it no matter what it is.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    February 2007
Posted by Buckeye on Monday, September 14, 2015 11:25 AM
As usual your cockpit looks great!  Looks like an interesting build.
    June 2013
Posted by bvallot on Monday, September 14, 2015 11:38 PM
Well, I've been absent for a while due to work but it seems I've popped back on just in time. =] It's always a pleasure to see your front offices Joe.  Superb.  The owl is an interesting subject as well.  I hope the rest of the build goes a little better for you.  Looking forward.
On the bench:
Tamiya F4U-1  Kenneth Walsh
Posted by Bish on Tuesday, September 15, 2015 12:53 AM
Nice to see one of these, don't see this aircraft very often. Great work on the pit as usual, she is coming along really well from the looks of it.
    January 2015
Posted by Aggieman on Tuesday, September 15, 2015 10:40 PM
I built this kit not too long ago. It fought me in the places you mention, particularly in the boom attachments to the wing. Also watch out for the main landing gear, as I recall them to be delicate and finicky - once I got the gear together with the tires in place (which are molded with a flat spot on the bottom), I noticed to my dismay that I did not get the flat spot exactly facing downward, so the tires ended up looking, well, wrong.
you seem to have this dude under control. Looks good.
    February 2012
Posted by lawdog114 on Saturday, September 26, 2015 1:00 AM
Thanks everyone.  I'm sorry, but I just havent had much time lately for a more indepth WIP.  I hope to improve that with my next build.  Anyways, I finished this one up last night which is actually a commission build.  I unfortunately dont know much about the unit that flew this plane, other than it was on the Russian front in 1943.
This thing fought me pretty good, but I'm overall happy with the final result.  The greenhouse glass fit great.  I used Eduard masks which performed flawlessly.  Whoever invented these....Thank you!  Paint is Gunze RLM 70/71 and 65.  The decals were horrible so I sourced most of them from spare decal sheets.  The pilot came with the kit.  Detail was soft so I added masking tape parachute straps and painted it up.  I think it looks passible.  I still find the pilot's pose strange and your pretty much limited to what I did.
Next I will have a go at the Great Wall P-61.  We'll see how the two compare.
Thanks for following.  Comments welcome...
Joe
Posted by Bish on Saturday, September 26, 2015 2:33 AM
Sweet looking build as always joe.
    February 2011
Posted by knox on Saturday, September 26, 2015 7:31 AM
  Another great build!  A lot of glass done well is real eye candy.  I especially like the dude trying to decide if he wants to get in or go hide somewhere.  Thanks for posting.
        knox
    August 2013
Posted by Jay Jay on Saturday, September 26, 2015 8:12 AM
A beautifully professional job LD and such a cool looking subject. I love all that well done glass    TY for posting.
    September 2015
Posted by Flugzeug Fan on Saturday, September 26, 2015 10:46 AM
Poor guy probably can't figure out how to get in, no obvious handle on that folding glass entry. BTW, I'm the guy that torments LD with projects like this. Hey I'm happy with the way it came out but don't blame me for the P-61, I wouldn't do that to you, who will build my stuff if you're in a psych ward?
    June 2014
Posted by BrandonK on Saturday, September 26, 2015 11:13 AM
Beautiful work Sir!! You really made that kit come to life. I am a sucker for any twin engine fighter/bomber. Thanks for sharing this one with us.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    March 2015
Posted by Toshi on Saturday, September 26, 2015 11:40 AM
Wow, what a fantastic finish, absolutely amazing.  I still admire the way you pros are able to highlight the panel lines even on a dark camouflage motif.  How do you guys do that?  Thank you for sharing!
Toshi
    June 2013
Posted by bvallot on Saturday, September 26, 2015 7:17 PM
Fantastic Joe. Glad to see you back. Looks like you tamed this one into submission. The pilot is a bit different. I find I'm pretty fond of it though. Anything that isn't such a repeat is a warm welcome in my book. =] Nicely done!!
On the bench:
Posted by jeaton01 on Saturday, September 26, 2015 8:50 PM
Very realistic, Joe.  A perfect finish and the glass is Boyerish.
John
    January 2015
Posted by BrandonD on Sunday, September 27, 2015 1:25 AM
That came out great! I really like th epaint, and that greenhouse canopy looks fantastic. I agree the pilot's pose looks weird - almost like, "Did I leave my cellphone in the center console?" but I think it still adds to the overall life of the setup.
Nice job.
-BD-
    February 2012
Posted by lawdog114 on Sunday, September 27, 2015 1:44 AM
Thanks everyone...or " dang...I locked the keys in it!"
    September 2015
Posted by Air2AirJoe on Sunday, September 27, 2015 4:42 PM
Well hey if we weren't looking for a challenge we'd just buy a pre-built replica right? Jk sounds frustrating. I'm brand new to this but my first thought after reading you op was "do the makers of these ever try building them themselves?"  Really neat aircraft and I hope it comes together nicely
"Forgive me, I'm clueless"
    June 2003
Posted by allan on Monday, September 28, 2015 3:47 AM
Beautiful build!  Man, that is one strange looking plane.
No bucks, no Buck Rogers
    April 2015
Posted by UKguyInUSA on Monday, September 28, 2015 9:29 PM
Wow, that's an all round gorgeous build, from the inside to the outside! I love it : )
    March 2015
Posted by bpanzer322 on Tuesday, September 29, 2015 6:34 AM
Beautiful job on that build. Your hard work definately paid off.
    February 2007
Posted by Buckeye on Tuesday, September 29, 2015 11:26 AM
Another gorgeous build there.  Fantastic work on all that glass!
    April 2015
Posted by RudyOnWheels on Tuesday, September 29, 2015 12:22 PM
Excellent job! That is a wild looking plane, don't believe I've seen that one before. What a neat subject. I really like the realism of the panel lines and weathering.... THANK GOD for Canopy masks! Rudy
    March 2005
Posted by Devil Dawg on Friday, October 2, 2015 11:51 PM
Great job!!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    November 2008
Posted by plasticjunkie on Saturday, October 3, 2015 8:37 AM
Excellent job overall as usual dog. Great touch with the figures and the base, lending a scale look to the model.Beer
 GIFMaker.org_jy_Ayj_O
    October 2015
Posted by TomcatGuy on Saturday, October 3, 2015 9:24 AM
Wow looks great. This is a subject you see often. Great job!
    April 2014
Posted by Grant Dalzell on Tuesday, October 6, 2015 1:25 AM
Awesome work, well done. The Great Wall P-61 is a very noce kit to build as well so you won't be dissapointed with that one.
