USCG C130K - Finished Pictures
Posted by rodc on Monday, October 12, 2015 8:17 AM
After picking away at this old 1/72 scale Airfix C130K (very old Series 8 kit) for about 3 years, I have finally finished it!  This kit was rife with problems and thus the long build time – I used to have to put it away so I wouldn’t throw it away.  The fit was terrible, raised panel lines, fuselage repeatedly popped apart on the seams (my own fault for not adding styrene tabs during assembly to keep the halves joined), twisted fuselage causing misalignment of main and tail wings, major tail sitter even though there is about 40g of weight in the nose and I used almost all my putty on the bugger!  Although the photos of the finished kit look pretty good, the fit problems and repeated repairs on the fuselage halves resulted in some undesirable blemishes.  It is a fairly big finished subject measuring 17” long with a 22" wingspan.  Challenging kit to say the least.
I finished the kit in the livery of a USCG International Ice Patrol C130K using the decal set from Hawkeye Models (set #CGDS-07) from Australia.  Decals look OK but are somewhat transparent and sometime change in color intensity especially on the full color decals.  I think I would have masked and painted if I had my time back.  I modeled this particular Hercules as #1347 which was stationed at Argentia Naval Base in Newfoundland Canada back in the 1960’s.  The decals for the USCG aircraft number and air station, I custom made.  Propeller warning strips were drawn in CAD and printed on peel and stick white vinyl.  The props were not the best and I had hoped to get a set of aftermarket ones but had no luck.  Antenna wire is EZ Line (fine).
All in all, I am glad it is finished and would probably do another one finished in the same livery, but with a better kit such as Italeri.  Finished photos below.
Thanks for looking.
RODC
    July 2010
Posted by Echo139er on Monday, October 12, 2015 8:26 AM
Wow.  That turned out great.  I have a couple C-130s waiting to get built and dressed in USCG colors.
Great work!
    June 2014
Posted by BrandonK on Monday, October 12, 2015 8:28 AM
You may have struggled with this one but it doesn't show in the photos. Nice work on a great subject. Thanks for sharing.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2014
Posted by modelcrazy on Monday, October 12, 2015 8:55 AM
Great work on an apparent dog of a kit, Way to preserver. I have the old Revell kit I'm a little hesitant to dig into for the same reasons....and I hate painting white.
Steve
Steve
    November 2003
Posted by mississippivol on Monday, October 12, 2015 9:19 AM
Great job, I applaud your persistence.
    February 2007
Posted by Buckeye on Monday, October 12, 2015 11:27 AM
Fine job!Yes
    March 2015
Posted by Toshi on Monday, October 12, 2015 11:39 AM
Beautiful colors, amazing!  Those colors are some of the most difficult colors to AB/paint with.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    June 2003
Posted by allan on Monday, October 12, 2015 8:45 PM
Thats persistence for you.  The USCG colors look real great on a Herc.  Great job!
No bucks, no Buck Rogers
