Ok, time for an update with this one. Holidays have been busy, but I've managed to get some work in on this, and have it painted now.
I used Gunze Mr. Surfacer 1500 BLack for the first time, and all I can say is I am hooked. This is my new go-to primer, and I can't say enough good things about it.
Once the whole thing was blacked, I got on to the yellow theater marking under the cowl.
After the mottling undercoat, I sprayed the blend coat.
Next up was the RLM 76, which I used Tamiya paints for with the mix ratio of 7 parts white, 1 part light blue and 2 parts light grey. I followed the same mottling/blending treatment there.
After that, I shot the topside with RLM 74 and 75. These were Gunze colors straight from the jar with no mixing. I think I need to play with thinning ratios a bit more, as I found them more tempermental than the Tamiya colors I am used to, but when they were flowing nicely, they were flowing very nicely.
The soft masking was achieved by using thin rolls of tape to hold the masks off the plastic about 1mm and just being careful with the airbrush.
Then came the mottling. I'd been both dreading and anticipating this, given that it's 1/72, and I normally work in 1/48. I used the Gunze Grey Violet, and I eventually got the ratio right (3 drops paint to 14 drops thinner at 12 PSI).
I messed up the mottling on the left side and had to go back and fix it by spraying in a bit of the light blue. It was nerve-wracking, but I'm glad I did it rather than have overscale blobs of paint, even though it's slightly lighter in a couple of areas (which will hopefully blend with decals and weathering). I guess that's the downside of freehanding it.
Anyway, that's all for now. Decals to come soon!
-BD-
