Revell Ar 555 Complete page 5
Posted by Bish on Sunday, January 3, 2016 11:59 AM
With the osprey on hold for a couple of weeks, on Fri i got stared on my first build of the year. Been wanting to do this for a while. This is the oldr boxing, released in 1998.
Before i actually make a start on construction, i need to make a few changes and improve some detail with some scratch building. There are no AM sets for this, so the spares box is my new friend.
First, the bomb bay. This is moulded to hold the 2 large and 3 smaller bombs that come with the kit.
But i need it to hold a single 4,000KG Uranium bomb. I found a couple of sway braces in the spares box.
And after removing the moulded in braces, i added the missing detail with some stryene strip and the new braces.
Then onto the cockpit. The seats clearly needed some work.
So i removed the belts and filled the hole. I also sanded down the seat backs, i don't like that quilted look. I will fill the rest later with some perfect plastic Putty which i need to order.
Also added some PE foot peddles and acuator rods with some styrene rod.
Another area that needd attention was crew access, i need an open hatch for the dio The most sutable area was a panel between the front wheel well and bomb bay. Afraid i got carried away and cut it out without taking a pic, but the hatch goes here.
I would usually replace the hatch with sheet stryene. But the one i cut out has a gentle curve and some nice engraved detail that will pass for the locking mechanisim.
After thinning, i added some detail on the inside.
That hatch is right under the rear gunners seat, the seat fit onto these rails.
After xconsidering several soloutions, i setteled on putting the seat on rails so it can be slide towards the back and off to one side. This leave its clear of the floor/hatch and also allows personal to access the erar of the aircraft.
And on the underside of the hatch a ladder to ease access.
And finally the landing gear. The front gear is supposed to be fitted when the pit goes in. But taking an idea from a build on another site, i rigged the front leg so it can be fitted later. I still need to fill the gaps on each side at the front. I also removed the solid triangular plastic at eitehr side of the legs and replaced them with some plastic rod.
And the same with the main legs.
And that it for now. Just got a couple of small things to do and then its off for some primer and paint.
Thanks for looking, and of course, all comments welcome.
    July 2014
Posted by modelcrazy on Sunday, January 3, 2016 12:32 PM
The box art looks strangely like New York City Huh?
Steve
Posted by Bish on Sunday, January 3, 2016 12:54 PM
There is a good reason for the that Big Smile. The re boxing has a differant image but was still New York. But that idea is even more fanciful than the aircraft itself. This version has a range of just under 3,000 miles. The direct distance from Amsterdam to New York is over 3,600 miles.
Thats one reason why mine will be in eastern Front markings.
cnq
    March 2013
Posted by cnq on Sunday, January 3, 2016 1:28 PM
Looking forward to this build. I love the Arado 555 and built two last year.
Posted by Bish on Sunday, January 3, 2016 1:42 PM
Thanks cnq. I have seen yours and know your a Luft 46 fan as well, so glad to have you follwing along. Please feel free to share any suggestions or tips. I have a few ideas, but i might have missed somthing.
    September 2005
Posted by Sprue-ce Goose on Sunday, January 3, 2016 2:15 PM
Looking forward to watching your build as I only recently picked up the kit at a November IPMS contest / swap meet.
Will you be using a 1/48 scale German bomb as the 1/72 scale 4,000 kg Uranium bomb?
Maybe ya ought to look into adding a bay access door and Major Kong pilot figure ....Whistling
https://upload.wikimedia.org/wikipedia/en/7/73/Slim-pickens_riding-the-bomb_enh-lores.jpg
Posted by Bish on Sunday, January 3, 2016 2:31 PM
LOl, ye, that would be a nice idea.
There are 72nd scale German a Bombs on the market. Antares and Unicraft both produce the same set of 4 differant bombs in resin, i think mine is the Antares set. I was goign to use the bomb from that and make my own bomb trolley. But i was looking at the kora site just before Xmas and found they do a set with the same bomb i wnated to use plus the trolley and tractor. So i have ordered that and it should be here soon. Unfortunatly, the aircrafts max load is 4,000KG, otherwise i would have one being winched up and the otehr being moved into position. But the bomb i have is coming in handy for sizing up the fittings in the bay.
The Antares set is the first on the page here. The one i am useing is third one down.
http://www.antaresmodels.com/luft46.asp?s=L72
    September 2005
Posted by Sprue-ce Goose on Sunday, January 3, 2016 2:59 PM
Thanks for that hyperlink.
I like the idea of adding the Uranium bomb and did not know so much cool stuff was available in 1/72 for Luft '46.SurpriseStick out tongue
Posted by Bish on Sunday, January 3, 2016 3:04 PM
Sprue-ce Goose
There is quite a bit, especially if you don't mind going resin. Quite a few nice kits and some nice conversions as well.
    June 2014
Posted by BrandonK on Sunday, January 3, 2016 5:10 PM
Wow, great subject. I was eyeballing one of these on Amazon in 1/48 the other day. I forget who made it, but I love the looks. Awesome sauce !!
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2003
Posted by allan on Sunday, January 3, 2016 7:58 PM
The seat cushions are either grossly substandard, or the Germans came up with memory foam as early as WW2.
Nice save, though.  :)
No bucks, no Buck Rogers
    November 2008
Posted by plasticjunkie on Monday, January 4, 2016 6:27 AM
Great scratchwork Bish. This is one way to get around AM sets, specially when none are available. A very futuristic design copied in some of today's aircraft.
 GIFMaker.org_jy_Ayj_O
    November 2015
Posted by The Migrant on Monday, January 4, 2016 8:02 AM
Cool subject, and looks like a nicely engineered kit. Watching with interest...
Mike G
Western Canada
    February 2014
Posted by silentbob33 on Monday, January 4, 2016 12:05 PM
Very cool Bish! It looks like you're making some good progress there and some nice detailing too.
On my bench: Academy 1/35 UH-60L Black Hawk
Posted by Bish on Monday, January 4, 2016 12:30 PM
Thnaks a lot guys. This is one of those kits i have been wanting to do for a while now, so really glad to get round to it.
BK, i didn't know there was a 48th kit, that would be somthing.
allan, your not wrong. Just wait until i post a pic of the control surfaces. I have no idea what revell were thinking there. One of the guys on Brit modeller likened it to hessian.
Over all, it does look a nice kit. A few sink marks to be filled, but not as many problems as the later 2012 release that i have seen. Some nice detail on the pit control surfaces.
PJ, your not wrong there. But i do wounder if these German designs would have worked as todays aircrfat heavily rely on computers just to keep them in the air.
    April 2015
Posted by Mopar Madness on Monday, January 4, 2016 3:16 PM
Very cool!  Can't wait to see this one.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by Bish on Monday, January 4, 2016 3:17 PM
Thanks Mopar. Glad to have you along.
Posted by Bish on Saturday, January 9, 2016 11:05 AM
Been moving along with the Arado this week. despite the size and the nice detail, tehre is not a lot to this kit. In total, 3 sprues, and two of those contain the main body and tail sections.
And this is the only real negative, the sprue gates, especially on the leading edge.
Thats not pretty by anyones standards. And i am not keen on the control, surfaces, but this is not really a defect, just a differance of opinion.
But enough of that, after priming, the cockpit parts got a coat of RLM 66.
I then did a light dry brush and added a pin wash with Flory wash. next up was starting to paint some of the detail. I have also cut a slot into each seat betwen the cushion and headrest for the PE seat belts.
That dial on the left definatly needs to be re done. I can paint some more once my instrument decals arrive from Canada.
The landing gear has been painted and i have added some black wire for brake lines to the main gear.
And the wheel wells and bomb bay are also painted and ready.
So now i am waiting those decals and the putty, all i can do on the aircraft is paint the wheels and finish off the seams on the engines. In the menatime, i can start on a couple of the vehicles i will be adding. I am still waiting on the one fom Kora, but i will also be adding these two to the dio.
And thats all for now.
    June 2014
Posted by BrandonK on Saturday, January 9, 2016 11:19 AM
This is a really cool subject. I'm glad you are doing one for us to see.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Saturday, January 9, 2016 11:36 AM
Thnaks BK, glad to have you following along.
    March 2015
Posted by Toshi on Saturday, January 9, 2016 11:56 AM
This diorama will be a blast to see when it's finished.  I really love the details and the scratch building you're doing, great workmanship!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Bish on Saturday, January 9, 2016 12:09 PM
Thanks Toshi. I have rather gotten into scratchbuilding in the last couple of years, usually when there is no AM option. I had put it off for years, but after scratching the complete rear interiour in both sides of an He 111Z, i am reday to try anything.
    November 2008
Posted by plasticjunkie on Saturday, January 9, 2016 4:17 PM
Those wires add a lot of details to the gears. Great job Bish.
Posted by Bish on Saturday, January 9, 2016 4:36 PM
Thnaks PJ. I wasn't sure if i should add one for each wheel or not. I just figured what the hell.
    February 2014
Posted by silentbob33 on Sunday, January 10, 2016 10:05 AM
Great job Bish! The landing gear and bays look awesome. I can't wait to see more.
Posted by Bish on Sunday, January 10, 2016 11:59 AM
Thanks Bob, hopefully won't keep you waiting to long.
    October 2015
Posted by ModelMan68 on Sunday, January 10, 2016 12:24 PM
Bish...again great job on your build. As always your details are looking wonderful. I hope I get too see it finished. Keep up the great work!!
Jeff
a.k.a.  ModelMan68
ON THE BENCH:  Spending Time With Family and Friends Big Smile
Posted by Bish on Sunday, January 10, 2016 1:00 PM
Thanks Jeff, and me to.
Posted by Bish on Sunday, January 17, 2016 9:30 AM
While waiting for those decals, i have still been able to get some done. The undercarrage was put together and the brake lines put into place. I still need to give the straps for the lines a coat of RLM 02.
I also replaced the gun barrels with some brass tube.
And i used some PE belts from the spares bopx for the seats. This is the gunners seat fitted in its ground position.
The Mike Grant dcals arrived yesterday and they were worth waiting for. A very nice selection of dials and info panels. Al the decals share one carrier film and i cut them out as close as i could. But some of the excess does show up on the camera but is not as bad to the naked eye. The instructions recommend a punch and die set and i think its time i got one of those.
With that done i could fit the cockpit. I added the steering column and bomb site and some wire to the back of the IP.
Then it was time to get teh top on. This was a bit tricky, so i started at the back and then worked round doing one edge at a time easing it into place. In the end the fit was rather nice with just a bit of sanding along the leading edge.
The kit includes 2 fixed forward firing weapons, MK 103's i believe, one eitehr side of the cockpit. everal build reviews i have seen question the logic of these on a medium/hig level bomber. I can't imagine these aircrfat doing a low level strafing run. So like those other builds, i decided to not fit those weapons and had already filled in the spent case shute. One build i saw aded blisters over the holes for those guns for some advanced radar or guidance system. I rather liked this and found a couple of parts in the spares box that i liked the look of.
I just have a bit more rubbing down to do, then i can add the vertical tails and canopy befire i go to the paint shop.
Thanks for looking, all comments welcome of course.
    December 2003
Posted by sanderson_91 on Sunday, January 17, 2016 9:47 AM
Hi Bish,
Just saw you build - I really like what you're doing.  The cockpit and landing gear look great!  Can't wait to see more!
Steve
