Tamiya 1/48 Corsair Finished
    September 2014
Posted by rooster513 on Monday, June 20, 2016 10:50 AM
Just wanted to share with everyone my latest build. Pretty much OOB except for the masking tape seatbelts and some wire for the engine. Paint was tamiya Sea Blue and didn't a little bit of painting chipping with a silver pencil.
Quite a bit of decal carrier film can be seen in some of the pics. What's the best way to avoid this in the future? I glossed before decals and use Micor-Sol over top of them. Was hoping the flat coat over top would blend them so carrier film couldn't be seen but no such luck. Anyway here are the pics...
All comments and critiques appreciated!Big Smile
-Andy
    January 2015
Posted by Aggieman on Monday, June 20, 2016 11:03 AM
Great work. I love the look of the Corsair, and I like that yellow cowl ring. As for the carrier film, I have read suggestions to poke tiny holes in the decals to allow decal setting solution to swap under the decals as a way to obviate this issue. someone correct me if I am wrong on that.
I typically cut as much carrier film from decals as I can, although that is next to impossible with squad numbers such as on your cowl ring.
Posted by echolmberg on Monday, June 20, 2016 11:16 AM
I think you Corsair looks great!  I see what you mean about the decals silvering though.  It still happens to the best of us.  On my last couple of builds, I had a couple of areas that I just wasn't 100% sure if the surface was going to be smooth enough to avoid the silvering.  As a precaution, I put a SMALL drop of Future on the spot where I was going to apply the decal.  When I placed the decal, it caused the small drop of future to spread out under the decal.  As a result, I didn't have any silvering whatsoever.  I don't do that to every decal I place, only on the ones that might be questionable.  So far, I've had good luck with it.
After all the decals have been placed, you can then apply your favorite clear topcoat to seal the whole works.
Eric
    September 2014
Posted by rooster513 on Monday, June 20, 2016 11:36 AM
Thanks Aggieman & Eric! Aggieman, I actually used that trick on the side numbers and it did help some...you should have seen them before thatIndifferent That future idea is a good one Eric...I'll have to try that on the smaller decals. Next time I think I will cut each number out separate if they are large enough to do so. Thanks for the feedback!
-Andy
Posted by Gamera on Monday, June 20, 2016 12:04 PM
Beautiful job there, darn shame about the silvering.
As Aggieman said the pinhole and setting solution idea is a good one. The silvering is caused by the decal not sticking perfectly to the model surface and light getting underneath and bouncing back out. I've also had some success with doing the pinhole thing as well as slicing the decal with a penknife and brushing Future over it trying to get it to soak in underneath the decal to close in the gaps. If you can plug them the silvering will go away and then you can spray her with another coat of matt. Be careful the Future can get away from you and make a big mess, trust me I found out the hard way. Bang Head
    November 2003
Posted by mississippivol on Monday, June 20, 2016 12:06 PM
You did a great job!
    March 2015
Posted by Toshi on Monday, June 20, 2016 1:26 PM
I would personally like to say that, that's one of the best Corsair builds I've ever seen.  You did a fantastic job!  Of course that's my number one aircraft of all time!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    April 2016
Posted by Tangotango on Monday, June 20, 2016 11:26 PM
I did the same kit, folded wings same decals and also had the same problem with silvering. The decals seemed a little thicker on this kit than Ive seen on other Tamiyas. I guess even Tamiya can have a problem.
    June 2014
Posted by BrandonK on Tuesday, June 21, 2016 9:08 AM
Great work. The Tamiya kit is very nice to work with and you did a fine job. Thanks for sharing it.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    December 2010
Posted by 1943Mike on Tuesday, June 21, 2016 7:20 PM
Fine work on this kit of my favorite aircraft.
I wish I could help with the decal carrier showing but I'm having problems with that myself on my stringbag. I've just ordered some Gunze products to see if they're any better than my usual Microsol and Microset. I've also ordered some Solvaset for my real tough silvering problems. I hope both the Mr. Mark Setter and the Solvaset work well. I'll see.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    September 2014
Posted by rooster513 on Wednesday, June 22, 2016 7:40 AM
Mike,
Please let us know how those work out. I'm always on the look out for something that might help me...because I sure need it! LOL
-Andy
    February 2012
Posted by lawdog114 on Thursday, June 23, 2016 1:07 AM
Looks good Mike. I used to get that silvering when I didn't get the surface smooth enough. I switched to Alclad clear gloss and haven't had any more problems. It could be the decals as well. Tamiya's are notoriously lousy. Also try putting micro set or even sol under the decal as well. Thanks for sharing..
    April 2010
Posted by Theuns on Thursday, June 23, 2016 1:37 AM
Very nice build, I like the belts :-)
I also try to "bed" the decals into a little future, it seems to work well.
Theuns
    May 2014
Posted by alanp on Friday, June 24, 2016 4:35 PM
Great job - the Tamiya Corsair is one of my favourites.  I have four of them.
I have done the following to deal with decal silvering.  First try to cut close to the image and cut out separate letters and numbers. This may not be possible with small numbers/letters.  For things like "O", or "Q", or "R", "8" etc - numbers with an enclosed area, cut the letter/number in half to cut out the carrier film.  It isn't too difficult to place the images back together on the model.  If you're not confident on your decaling skills, you can get rid of the silvering by carefully cutting out the silvering when the decal is on the model, with a hobby knife using a new blade and a light touch.  The silvering image can then be removed with a small piece of sticky tape - I like to use Tamiya tape.  I have used this technique as a last resort if the image has unacceptable silvering - say in the middle of a "D."  This seems to work for me even after a covering of Future or other surface finishing treatment.  Having said all this, I always like to make sure that I have an alternate decal on hand in case of distater.
Good luck.
    March 2015
Posted by harp.ta on Saturday, June 25, 2016 2:05 AM
My solution for Tamiya decals silvering is to buy aftermarket decals for any Tamiya kit I build.  Its a costly solution but it usually works.  On the one's I have used I just wet sand the primer, the base coat, the post shading, and if necessary - the gloss coats themselves.  I use 2000 grit paper but you could probably do with an extra fine (600 grit) sanding stick.  For the coats that aren't visible you can even dry sand it.  Certain paints seem to have more of an issue than others too (the Navy Blue/Dark Sea Blue MM paint I just used on my Hellcat is an example - stuff had a crazy orange peel finish and its supposed to be glossy!).
As for the build - she's a knockout.  But I'm biased because I love Corsairs.  The engine is phenomenal.  Great work!
On the Bench:
  • Tamiya 1/48 A-1J Skyraider (USAF)
  • Tamiya 1/48 He-219 A-7
  • Tamiya 1/48 P-47M
In the Fridge:
  • Modern Times Brewing Blazing World
  • Lawson's Finest Liquids Sip of Sunshine
  • Half Acre Gone Away IPA
"Why do they lock gas station restrooms?  Are they afraid someone might clean them?"
- George Carlin
    August 2009
Posted by JOE RIX on Sunday, June 26, 2016 5:07 PM
Despite the decal issue, you have done a magnificent job on your Corsair Andy. The construction and paint work are very nicely done.
Seems evryone else has touched on viable solutions. I'm in the camp with Joe and harp in that it's likely an issue with tamiya's decals themselves. I've encountered my share of difficulties with them and I'm also usually looking for AM decals when building a Tamiya kit. It still eludes me that Tamiya punches out such fine kits yet seems to fall short on the decals. You would think they would have addressed that.
Thank you for sharing your top rate skills.
Joe
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2014
Posted by rooster513 on Monday, June 27, 2016 7:05 AM
Thanks for the kind words Mitch and Joe! I hope this was the first of many of these birds I'll build, so next time I think I'll look into some aftermarket decals.
-Andy
