Who has the best 1/48 A-10?
    August 2014
Posted by Timdude on Monday, June 20, 2016 1:52 PM
Looking to add a newer A-10 to my stash. I have a couple of the older Monogram kits. Other than the raised panel detail I believe they are decent kits. I also have the newer Hobbyboss two seat version still in the wrapper. My question is who has the better of the new kits, Hobbyboss, Italeri, Tamiya?
Thanks Tim
    July 2004
Posted by stikpusher on Monday, June 20, 2016 4:35 PM
The Tamiya A-10 is one of their older 1/48 jet offerings dating from the late 70s or so, and is not new by any stretch. To my knowledge it has not been retooled since first being issued. The Italeri kit is far more current, but I believe that I remember reading about some issues in the engine area, eaither fit or detail accuracy.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Monday, June 20, 2016 4:41 PM
Have a look here for some reviews
http://www.cybermodeler.com/aircraft/a-10/a-10_all.shtml
       - Plankton
LSM
    January 2014
Posted by jelliott523 on Monday, June 20, 2016 6:49 PM
I currently have the Italeri A-10(not quite a "C") kit. I have temporarily shelved it due to issues that I discovered while building, and I havent figured out yet how to fix them. The main wing fairing does not match up at all, and left a HUGE step that needs to be removed. the problem being, to remove such a large step will likely leave a hole in the fairing that would be quite difficult to fill. The reason I call it "not quite a C" is because as the review in Cybermodeler pointed out, the cockpit is that of the "A+" model, it does not have the glass cockpit of the actual "C". If this does not bother you, then I'm sure it will look fine, if you are into accuracy, you will have to do some scratchbuilding to get it there.
Posted by Gamera on Monday, June 20, 2016 7:59 PM
I built the Hobbyboss kit a few years ago. Really nice model.
Pros: Supposed to be the most recent, latest and greatest kit.
Lots of ordinance, I hung mine with two pods and about a zillion Hellfires.
Really good molding and fit.
Cons: Expensive, Squadron used to run it every now and then at half price, haven't seen it marked down like that in years though.
Hobbyboss molded the landing gear detail into the underside of the upper wing parts. On mine this created depressed areas over the wells. And it's hard to putty these over without removing the detail from the top of the wing.
    May 2016
Posted by Revenant on Monday, June 20, 2016 8:27 PM
No one...it's one of those a planes that no one seems to have gotten 'right' In quarter scale, even in 72nd, although the Italeri kit in Braille scale is VERY nice...
