Stynylrez primer
    April 2013
Stynylrez primer
Posted by Greatmaker on Monday, September 26, 2016 8:28 PM
I've looked up the previous posts on this primer and I was wondering if anyone has used it with model master acrylics?  I'm currently working on a revell 1/48 P-38J in a NMF so I won't use it on the exterior. So far I've been very pleased with how it goes on. It's slightly darker than I would like.  I have the gray, but I think pre-shading would still work. I did a test on some extra drop tanks using Stynylrez vs model master acrylic primer. I let both primers dry overnight and sprayed model master clear blue on it. Let dry overnight and did the tamiya tape test.  Both lifted off so I'm alittle leary of using it on external surfaces. Thanks in advance
    January 2015
Posted by Aggieman on Monday, September 26, 2016 10:01 PM
I am using the same stuff and have had no issues with paint lifting (MM Acryl paints).
    April 2013
Posted by Greatmaker on Monday, September 26, 2016 10:26 PM
Thanks Aggieman
    April 2013
Posted by Greatmaker on Sunday, October 23, 2016 10:45 AM
Just an update. This stuff is some of the goofiest stuff I've worked with. Despite washing the plastic and wiping down the whole model with rubbing alcohol it peels off easily in some places and sticks like crazy in others.  I used gloves when I cleaned with alcohol and thereafter. Also de-tacked the tape
    March 2013
Posted by patrick206 on Sunday, October 23, 2016 3:01 PM
I still wash the intact sprues in dish soap and warm water, then a thorough rinse several times. Then after assembling I give the entire surface a wipe with alcohol, followed by a complete sanding with a light abrasive pad. Then, after priming with Stynylrez comes another sanding and prepping for paint, never had any lifting with any finish.
It may be considered overkill, but I still feel it's important to wash before parts leave the sprues. Then sanding seems pretty clear to me, a good way to ensure the successive primer and paint layers have a sufficient "bite" to ensure good adhesion.
Patrick
    May 2013
Posted by Greg on Sunday, October 23, 2016 11:19 PM
Greatmaker
This seems odd. Are you thinning the Stynylrez with anything? (Don't)
Are you making sure it is going on nice and wet? (as opposed to spraying from too far away and drying before it hits the surface, for example?)
If you could talk a little about what primers you've used in the past and how you've applied them, that might help somebody to hit the correct solution.
