Weather Washing a P-61 Black Widow
    March 2016
Posted by Johnny Reb on Monday, December 5, 2016 7:43 PM
Hi fellow modelers.
I am finishing my P-61. I have painted the exterior flat black, and then I sprayed everything with a gloss lacquer.
I would like to keep the shine from the gloss as much as possible, and, keeping that in mind, I would also like to give some type of weather wash as well.
My concern is that a wash might dull everything down to give the model a flat finish (which I really don't want).
I would like to give the plane a worn, battle look, while maintaining much of the gloss as well.
Any suggestions?
Thank you!
    November 2016
Posted by Gerhard on Tuesday, December 6, 2016 1:56 AM
Try and add some "chipping" effect using alluminium paint on the wing and props. P-61 Black widow
    November 2003
Posted by tempestjohnny on Tuesday, December 6, 2016 4:53 AM
If the plane is weathered it is not going to have a glossy appearance. You could give it a blotchy gloss and flat where it weathered more.
    February 2012
Posted by lawdog114 on Tuesday, December 6, 2016 6:59 AM
Agree with Johnny. I believe these dulled fast in the South Pacific. Is it a Monogram or Great Wall, if it's a Great Wall, try a panel line wash with a grey. Here's an idea how I did mine which may help.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/168128.aspx
Posted by Don Stauffer on Tuesday, December 6, 2016 8:48 AM
Most washes are applied either by brush or other implement, to local areas.  Even if applied by my airbrush, I do not apply to whole model.
To dull down a plane with gloss paint, I airbrush a dullcoat to top surfaces, easing off as I go around to sides.
If you are dulling down to represent a matt/flat finish, do not use a wash, apply dullcoat to whole model.
    March 2016
Posted by Johnny Reb on Wednesday, December 7, 2016 8:06 PM
Gentlemen:
Thank you all so much for your very helpful information!
    January 2009
Posted by fermis on Wednesday, December 7, 2016 8:30 PM
Personally....I do not like a gloss finish at all. Makes things look toyish/fake/not right, just a bit too much...especially "at scale".
A "sheen", however, is a good thing in this situation. The method to my madness for this is....do what you'd normally do if you were going for a flat finish....gloss, decals, gloss(seal in the decals), wash and final dullcoat over all. To get the sheen...buff with a soft cloth (old t-shirt, sock or even denim works well).
