Fuel viewing tubeclear
    September 2010
Posted by mikeymize on Wednesday, December 21, 2016 2:13 AM
   I'm building The Eduard Bf 109 late Gustav.  Kit Nr 82111  anyhow the tube busted and looking for ways to fix it. Thanks!
"Time you enjoy wasting is not wasted time".
    March 2010
Posted by Nathan T on Wednesday, December 21, 2016 7:19 AM
Scratch it using similar sized wire. Then paint the clear portion silver
    January 2009
Posted by fermis on Wednesday, December 21, 2016 10:58 AM
Ditto
...or...if you really want the clear portion to be clear...heat and stretch a piece of clear sprue, for that section, and use pieces of wire for the rest.
    September 2010
Posted by mikeymize on Wednesday, December 21, 2016 12:28 PM
Thanks for the quick responses. I think I'll try some .032 wire; as I already tried heating clear and normal spruce with mixed results.  Also the compound curve required to make it fit was bit too challenging with the plastic. I only wish Eduard had more than one in the box as they're super fragile
 Thanks again guys!
    September 2010
Posted by mikeymize on Tuesday, January 17, 2017 1:51 PM
Nathan T
. Thanks Nathan.  I ended up usung .020 safety wire and it turned out great!
