Another 1/48 Revell F-15E WIP
    January 2009
Posted by fermis on Thursday, January 19, 2017 1:59 PM
Been doing a little here and there...mostly at the airport, while waiting for snow to pile up enough to get busy moving it. Got a little ahead of myself and forgot the obligatory pit pics, before closing it up....best I can do at this point...
Bring on the HURT!!!!
Weapons from a Hasegawa set...CBU's are from HobbyBoss' A-7 kit.
Since this build will be traveling via the US Postal Service...some extra work is required to toughen things up a bit. I used brass rod to make pins that will run through the fuse/or wing parts, through the pylon and into the stores. As of right now, these will pressure fit without any need for glue(they will get glued though too).
Customer wanted AMRAAMs loaded up on the missile rails. The kit includes AIM-9s. I cut off the rails for the AIM-9s and replaced them with the rails for the AMRAAMs from the Hasegawa set.
Ready to start painting some stuff!
    March 2015
Posted by Toshi on Thursday, January 19, 2017 2:07 PM
This is a fun kit to build.  As always, you're doing a fantastic job.  I'm looking forward to your progress!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    January 2017
Posted by Redman7176 on Thursday, January 19, 2017 3:32 PM
Can't wait to see how this turns out. Propeller
    June 2016
Posted by XF-15DCC on Thursday, January 19, 2017 5:54 PM
Being an X Eagle Keeper I will be watching.
Are the CFT pre-molded to the fuselage or do you need to put them on.
Kevin
We live in fame or go down in flame.
    January 2009
Posted by fermis on Thursday, January 19, 2017 11:28 PM
Thanks guys.Toast
XF-15DCC
They are separate pieces. Both of mine had a bit of a warp to em. A bit of a PITA to hold em in place (they slip pretty easy) and glue at the same time. I had to use some tape to help hold em in place, while I gluing and working out the warp.
    November 2003
Posted by tempestjohnny on Friday, January 20, 2017 6:01 AM
I'm watching this. Have got one in the stash.
Posted by Bish on Friday, January 20, 2017 6:18 AM
Looks great so far.
    December 2015
Posted by templar1099 on Friday, January 20, 2017 10:37 AM
Nicely done so far,par for the course. When you get a moment tell me what you use as adhesive for the brass to plastic.
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
    February 2006
Posted by DantheMan85 on Friday, January 20, 2017 11:50 AM
Excellent job, the E model is a lot better than there older ones with those nasty raised panel's. Cool
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    January 2009
Posted by fermis on Friday, January 20, 2017 10:18 PM
ToastToast
templar1099
I use CA. The drill bits are the exact same size as the brass rod, so it's a tight fit to begin with...the glue is just a little extra "insurance".
DantheMan85
The truth is what you speak! I did the old C model many moons ago...long gone. I did another early on, during my 1st return to building. I did a terrible job on it. Upon my 2nd return to building, that F-15 was destined for the trash can...I signed up on an "Air Racer GB" here, and decided to redo that model as a "what-if" racer. Stripped it down, de-militarized it, clipped the wings and whatnot...
    June 2016
Posted by XF-15DCC on Saturday, January 21, 2017 5:48 PM
Now that is an Eagle! Well done!
Bow Down
Kevin
    January 2009
Posted by fermis on Tuesday, January 24, 2017 1:05 PM
Got this sucker painted up...
    January 2009
Posted by fermis on Friday, January 27, 2017 2:25 PM
Decals are done!
Bring on the hurt!!!
    June 2016
Posted by XF-15DCC on Friday, January 27, 2017 7:12 PM
Sweet, I have had this kit (or some what the same kit) in my hand before. Need to finish my Tamiya F-15C model first.
Did you hand paint the yellow and brown stripes on your munitions or are those decals?
Kevin
    January 2009
Posted by fermis on Friday, January 27, 2017 9:23 PM
XF-15DCC
Kevin
I did the yellow in the bombs...the missiles are decals though.
    January 2009
Posted by fermis on Saturday, January 28, 2017 2:21 PM
Did a panel line wash (amplified a bit in the pics), as well as some more weathering with some tinted dull coat through the a/b.
I'll do a bit more weathering with some pastels, once I get the other stuff on there.
    June 2016
Posted by XF-15DCC on Saturday, January 28, 2017 4:11 PM
Your weathering on the belly inbd of main gear and back to the exhaust is spot on. Bow Down
    January 2009
Posted by fermis on Tuesday, January 31, 2017 3:27 PM
Got this beast loaded up.
    January 2017
Posted by Redman7176 on Tuesday, January 31, 2017 3:36 PM
That looks aweome!!! Fantastic job.Bow Down
    January 2009
Posted by fermis on Tuesday, January 31, 2017 7:02 PM
Got'er wrapped up!
    June 2016
Posted by XF-15DCC on Tuesday, January 31, 2017 7:09 PM
Wow, even the external ladder. Was this an option or aftermarket?
Well done!
Kevin
    December 2010
Posted by 1943Mike on Tuesday, January 31, 2017 8:16 PM
Your normal, brilliant work!
I just love looking at your finished kits as well as following your WIP threads. I've been looking at your tutorial on your SBD-3 Dauntless:
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/160714.aspx
and am at a the beginning of my AM 1/48 SBD-5 build. Your mastery of painting and weathering the pit is more than I could hope to accomplish but your step by step instruction as to how you do it with the images is invaluable.
As has been pointed out by Fermis, the thread I linked above is by LawDog. Both Fermis and LawDog are fantastic modelers who's WIP are of great interest to me and from whom I've already learned a lot.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    January 2009
Posted by fermis on Tuesday, January 31, 2017 9:52 PM
1943Mike
I've been looking at your tutorial on your SBD-3 Dauntless (http://cs.finescale.com/fsm/modeling_subjects/f/2/t/160714.aspx
Thank you very much!
That's "Lawdogs" thread, if I'm remembering correctly. Been a LONG time since I've built one of those (got 2 in the stash though!). We do do things quite similar though.
XF-15DCC
That was included with the kit.
    March 2009
Posted by wolfhammer1 on Tuesday, January 31, 2017 10:27 PM
Fermis, just beautiful  Always loved the Eagle, and you certainly did this one justice.  Quick question, what are those massive JDAMs on the conformal racks?  Are they bunker busters?  Thanks.
John
    December 2010
Posted by 1943Mike on Tuesday, January 31, 2017 11:15 PM
Ooops Embarrassed
Yes, I must make my attributions more accurately. LawDog is another modeler who I always enjoy following. That error takes nothing away from my compliment to you and your skill.
Hector Berlioz
    March 2015
Posted by Toshi on Tuesday, January 31, 2017 11:36 PM
Another beautiful build.  Excellent mastery!
Toshi
    December 2015
Posted by Dash8 on Wednesday, February 1, 2017 12:19 AM
Stunning ! The panel line shading is perfect.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    November 2008
Posted by plasticjunkie on Wednesday, February 1, 2017 9:57 AM
Great job as usual fermis. That is quite a load on that Eagle and it will certainly do some hurting on the other end. That is an excellent idea to pin the weapons to keep them on during shipping. I do the same thing on my comissions to keep them on while being thrown around by the USPS.
The Pro Modeler Eagle has a ton of weapons and pops up now and then on ebay. Again fermis, super job. Beer
I think Mike was talking about the awesome TBD you did a while back.
 GIFMaker.org_jy_Ayj_O
    December 2010
Posted by 1943Mike on Wednesday, February 1, 2017 10:38 AM
Nope, I just made a mistake when attributing the thread to fermis. No matter, both fermis and LawDog are such fine modelers that I learn from both and admire all the work I see from both of them.
Hector Berlioz
    September 2011
Posted by falconmod on Wednesday, February 1, 2017 10:45 AM
Are you talking about the Revell of Germany version?    it seems to have more ordinance than the Revell F-15E strike eagle version.
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
