P-51K "Nooky Booky IV" (WIP)
    June 2016
Posted by Murphy's Law on Sunday, February 26, 2017 6:02 PM
This will be my first attempt at a natural metal finish so keep your fingers crossed.  Kit I'm using is the Tamiya 1/48 P-51D. I will be using a Aires cockpit kit and Alclad II finishes. Hope you enjoy the updates.
    November 2003
Posted by tempestjohnny on Sunday, February 26, 2017 6:13 PM
Interior looks great
    November 2004
Posted by Bronto on Sunday, February 26, 2017 7:50 PM
Cockpit looks good!  If its not too late the armor plating behind the seat should be black not green.
    June 2016
Posted by Murphy's Law on Sunday, February 26, 2017 8:01 PM
Bronto
Thanks a lot Bronto!, I haven't put the halves together yet so I will fix that.
Posted by keavdog on Monday, February 27, 2017 2:16 AM
Looks great. I built that one ootb and it's a great kit. I just sprayed alclad ii aluminum on my tamiya p47d tonight . Do the gloss black first and let it dry for a couple days. And turn down the psi when spraying the alclad to 15-17. On my p51 I hit the panel lines with tamiya smoke after the alclad set for a couple days.
Thanks,
John
    March 2015
Posted by Toshi on Monday, February 27, 2017 4:28 AM
Nice job on your cockpit.  Looking forward to the Alclad NMF.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    May 2009
Posted by Pawel on Monday, February 27, 2017 12:23 PM
Hello!
Many years ago I have read on these forums, that on a P-51 Mustang the wings were puttied to be very smooth and then painted silver. Only the fuselage wa true NMF. Maybe someone could confirm that? Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    January 2017
Posted by Thuds on Monday, February 27, 2017 7:08 PM
Hi, yeah overall.The wings were puttied and painted silver overall.The only parts that were left natural metal are the flaps,ailerons wnd the wing tank on the bottom of the wing.       Frank
Met fan
    February 2012
Posted by lawdog114 on Tuesday, February 28, 2017 12:38 AM
Pawel
Hello!
Paweł
Yes indeed, eveything except the gun access/ammo doors on top.  It was done at the factory to keep the "laminairflow", which it was called.  I must confess I never fill the panel lines because I don't particularly like the looks of it.  It's also my understanding the putty would eventually work it's way out.  So technically both could be right.
That pit looks great Murphy.  Here's my recent build of this kit should you need a quick reference on the tricky areas.  I look forward to your progress.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/162455.aspx
    June 2016
Posted by Murphy's Law on Tuesday, February 28, 2017 8:52 AM
lawdog114
Pawel
Hello!
Paweł
Awesome!!, That build looked great! I will defiantly be going to that thread many times for reference.
    August 2014
Posted by Timdude on Tuesday, February 28, 2017 10:35 AM
The entire wing was not painted though, only about the first 2/3rds or so and the flaps and ailerons were bare metal. The are some very good color photos of factory aircraft in books and on the web. Also, yes combat pilots reported that the Laminer flow only lasted a little while. With fuel hoses being drug across and crew crawling all over it the wing got trashed pretty fast. But the pilots said they could feel the difference when they got a new mount. What ever you do, do not use modern Warbirds as a reference.
    June 2016
Posted by Murphy's Law on Friday, March 3, 2017 6:10 PM
Not much progress this week (hate it when work gets in the way Confused)
Removed the molded instrument panel dashboard so that the resin dashboard will fit
Took the pencil grinder and removed the raised detail in order to accept the resin sides
I decided not to attach the sides to the resin cockpit first and then installing as one whole piece. Instead I super glued to the fuselage halves so there wouldn't be any gaps between the resin sides and the fuselage
    February 2012
Posted by lawdog114 on Friday, March 3, 2017 8:07 PM
Very nice work so far....flashbacks. I'm curious to see how that Aires instrument coaming fits in there.
    January 2016
Posted by Hunter on Friday, March 3, 2017 9:10 PM
Murph -
It's looking great....nice work on the pit. I'll be watching and look forward to the final photos. When you reach the section of the build where you apply the alclad II share your thoughts on it....I also have a P-51 build coming up and thought about using the same paint.
Hunter
    June 2016
Posted by Murphy's Law on Saturday, March 4, 2017 5:05 PM
lawdog114
Here ya go lawdog114
    September 2016
Posted by SaltydogII on Saturday, March 4, 2017 11:40 PM
Coming along nicely!
Chris
    June 2016
Posted by Murphy's Law on Sunday, March 5, 2017 12:38 PM
Replacing the kit gun fairings with some Ultracast fairings
This came out easier than I was expecting... just took my time. I made cuts with the saw in the panel lines in the direction of the guns and for the cross panel line where I couldn't reach with the saw I just scribed deep with the knife until I was able to break the piece off.  Also note I did this before attaching wing halves which makes it much easier to work with.  I will attach the resin fairings on once I have the halves together.
