Italeri 1/48 Hurricane Mk.1 Trop WIP/Review
    July 2014
Posted by modelcrazy on Tuesday, July 4, 2017 9:37 PM
I started the new Italeri 1/48 Hurricane. This kit hit the market recently and I have the privilege to build it. It looks to be a very nice kit with good detail and fit.
The box contains 1 parts bag containing 4 grey sprue trees and a separate bagged clear tree,. A small PE set and decal sheet for 6 different versions complete the contents.
The 16 page instruction booklet has 10 pages of instructions and 6 pages reserved for marking instructions.
Version A - RAF 274 Sdn, Gerawla, Egypt 1941
Version B - RAF 74 Sdn, Malta 1942
Version C - RAF 185 Sdn, Hal Far, Malta 1941
Version D - RAF 73 Sdn, Western Desert 1941
Version E - RAF 73 Sdn, El Adam, Libya 1941
Version F - RAF SAAF 3 Sdn, South African Air Force, Abyssinia 1941
I plan on building Version D.
I started on the cockpit which contains the majority of the PE parts as the Sutton harness and instrument panel. It builds up very nicely and the fit is excellent.
The kit also contains a nicely detailed Merlin engine which can be shown with most of the cowlings off. I plan one showing the engine in all it's glory and maybe scratch some hoses to enhance the already excellent detail if necessary.
The cockpit and engine are in their place.
More to come
Steve
    May 2017
Posted by MrStecks on Tuesday, July 4, 2017 9:44 PM
Wow, that's looking very nice indeed.  I'll be following this build.  Smile
Cheers, Mark
On the bench:  Revel 1/48 B-25J Mitchell
In the queue: Tamiya 1/48 F4U-1A Corsair
    July 2014
Posted by modelcrazy on Tuesday, July 4, 2017 9:51 PM
Thanks Mr. S
Steve
    September 2016
Posted by ManCityFan on Tuesday, July 4, 2017 9:57 PM
Wow, the pit and engine look great!  Putting the tools in the pics helps with showing the size of each.  They always look so much bigger than they really are without something to give perspective.  Looks like a really well made kit.
D
Dwayne or Dman or just D.  All comments are welcome on my builds.
    January 2015
Posted by M. Brindos on Tuesday, July 4, 2017 10:28 PM
Wowsers! I'm looking forward to seeing how this continues to go together.
So is Italeri jumping into the game with some new modern tooled kits too??
I'd be more than happy to check one out for myself if they are. :)
- Mike Brindos "Lost Boy"
    July 2014
Posted by modelcrazy on Tuesday, July 4, 2017 10:49 PM
Thanks D and Mike.
Mike here is a link to some of their new items
http://www.italeriusa.com/product-category.php?comingsoon
Also something you will be intrested in. I purched the Airfix 1/72 RAF Groung Crew set and will be putting some of these guys in on another diorama along with some of the equipment.
They look a lot better than depicted on the box.
Steve
    January 2015
Posted by M. Brindos on Tuesday, July 4, 2017 10:59 PM
Oh yeah, that does get my attention alright lol. I will look forward to that! :)
Now I'll go a browsin' :)
1/56th scale?? Some of those new items look pretty interesting. :)
No new tooled P-36A though :(
    July 2014
Posted by modelcrazy on Thursday, July 6, 2017 7:48 AM
Thanks Mike, I thought it would LOL.
Well now this is a problem. I glued the fuse half’s together and assembled the wing. As everything was drying I dry fit the wing to take a look at what I was facing for a gap.
Now to my recollection, isn't the leading edge of the wing supposed to fit behind the engine cowl? I thought there must be a piece that fits under the cowl. No. Do I have the wing on backwards? No. Looking through the instructions there isn't a hint of why this is happening.
I will be contacting Italeri and inquiring the possible reason. Is this wing going to be used on a Mk.2 etc.?
Stop the assembly line until a resolution is found. Back to the stash to look for something else while my AB and current build are down.
Steve
    January 2015
Posted by Aggieman on Thursday, July 6, 2017 8:32 AM
Yikes, that is horrible.
    June 2014
Posted by BrandonK on Thursday, July 6, 2017 9:09 AM
Well now, that's just not a good fit now is it? The rear looks like a simple cut/trim to fit would work fine, but the front looks a bit more complicated. Being the type that doesn't like to wait on others to give me a solution, I would be trimming the front and rear to fit and moving on; if that would work that is. Hard to tell without holding it in my hands.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2014
Posted by modelcrazy on Thursday, July 6, 2017 9:17 AM
Yeah, but I'm writing a review for it soooo, correct parts would be good. If Italeri dosn't come through with replacements I'll do that. The rest of the kit looks good and I would imagine that this lower wing is for a later version.
Just a boxing boo boo off a new run.
Steve
    June 2014
Posted by BrandonK on Thursday, July 6, 2017 11:40 AM
Ah yes, I wasn't thinking along those lines. And yes, that's a big problem that they definately need to address.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    February 2011
Posted by Reasoned on Thursday, July 6, 2017 9:15 PM
oops.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    December 2010
Posted by 1943Mike on Thursday, July 6, 2017 11:48 PM
Steve,
It must be really frustrating to have to be dead in the water like this. I'm really interested to hear what Italeri has to say about that misfit. Your conjecture about the wing perhaps belonging to a different version would make sense if, of course, they're producing such a kit.
Your initial work with the engine and the pit is outstanding as usual.
Do let us know what the problem is when you find out.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    November 2016
Posted by Gerhard on Saturday, December 9, 2017 8:20 AM
I was about to start this and dry fitted the fuselage and wings, same issue. What was the resolution?
    July 2014
Posted by modelcrazy on Saturday, December 9, 2017 9:27 AM
I received a new wings parts tree after 14 weeks and had the same issue. The fuselage may be the problem or Italeri may have messed up this kits parts list. Mine was free but since you paid for yours you will have a lot more pull getting this resolved. I'm sure they have heard of a reoccurring issue by now so they may have it fixed. If you contact customer service at Hobyco they are very helpful.
Steve
    June 2017
Posted by Chemteacher on Saturday, December 9, 2017 9:51 AM
The pit and engine look great. Too bad about the fit with the wing. Time to get the Dremel out.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2004
Posted by ChrisJH666 on Saturday, December 9, 2017 3:01 PM
I can't understand how they could have made such a pigs ear of that wing. It is definitely too long as the join should be exactly where you would expect, at the rear of the under-engine cowling panel. As for later versions, I am 99.99% sure that even though there were several different marks of Hurricane, unlike several other famous fighters, there were no major structural changes between marks (except for the very early change to metal skinned wings). No, the manufacturer has simply stuffed up, so I would be surprised if you got any joy out of them
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
Posted by jeaton01 on Saturday, December 9, 2017 10:30 PM
The desert filters were in that area but as far as I know they were added on to the lower skin profile.  Looks like a goof to me.  Bummer all around.
John
    November 2016
Posted by Gerhard on Sunday, December 10, 2017 12:14 AM
I did send them a mail , with various links to websites where this was reported. It was quite an expensive kit for a 1/48, so hope the sort it out.
    July 2014
Posted by modelcrazy on Wednesday, December 13, 2017 9:09 AM
A few weeks ago I asked for the fuselage tree thinking the fuse was the one at fault, but after looking around the internet and hearing from others, I believe this is a problem with the kit. It seems that all who have spoken up about this is having the same issue.
I am placing this build aside and may get back to it when I feel ambitious enough to use the Dremel and putty. This is too bad because it started out to be an excellent kit.
Once Italeri straightens this issue out, which they are probably working on now, this will be an excellent, fun kit.
Steve
    April 2013
Posted by Drifter on Wednesday, May 9, 2018 3:28 AM
I waited about 3 months and received the correct wing from Italeri.
    July 2014
Posted by modelcrazy on Wednesday, May 9, 2018 9:03 AM
Did that fix it? The wing didn't fix it. I need to get a new fuse. Unfortunately everything is glued in. Now that Hobbyco is gone, who would one go through I wonder.
Steve
