1/48 Hasegawa Fw 190 A-8 JG 300 "Ernst Schroder" (FINISHED)
    February 2010
Posted by 68GT on Tuesday, September 12, 2017 9:06 AM
Great job, your 190 looks beautiful!
On Ed's bench, ???
    July 2003
Posted by ridleusmc on Tuesday, September 12, 2017 10:04 AM
Excellent Work,
The model looks realistic enough to fear.  The Alclad flat looks good to my eye, but must of the subject I choose can't be too dull.  I very much like the paint effects on the underside of the aircraft.
How'd you do the base?  I want to do something similar for a Zero on Buin Airfield.
Cheers to a great build,
Beer
    December 2010
Posted by 1943Mike on Tuesday, September 12, 2017 11:39 AM
Another delightful, skillfully done build!
As to your question regarding a flat coat - have you tried Tamiya's XF-86 Flat Clear? If it is not dull enough for you when you've sprayed it on a test piece, try adding Tamiya's X-21 flat base to it - not much, just for an experiment. The X-21 should NOT be used by itself - it's for adding to Tamiya's regular paints to dull them down. Adding a little of X-21 to XF-86 would give you some variation in using these bottles from Tamiya. I have not tried this myself, just read a blurb on the 'net regarding what I've mentioned. If, however, the XF-86 Flat Clear is too dull, than all this verbiage is for naught.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    February 2014
Posted by silentbob33 on Tuesday, September 12, 2017 3:21 PM
Again, great work Joe, and those new paints look really nice. Like you I like the Testor's, but I have to leave the room for a few hours after I spray it
On my bench: Academy 1/35 UH-60L Black Hawk
    April 2006
Posted by jgeratic on Tuesday, September 12, 2017 7:30 PM
Hi Joe, standout work on this one! Yes
What about a satin finish?  I've  been quite happy with Vallejo acrylic brand, just add about 50% distilled water.
regards,
Jack
    February 2012
Posted by lawdog114 on Wednesday, September 13, 2017 1:54 AM
1943Mike
Thanks all...
Mike, thanks, I may try this.
    February 2012
Posted by lawdog114 on Wednesday, September 13, 2017 1:59 AM
ridleusmc
It's basically a wooden plaque with real dirt secured by Elmer's glue.  I know that there's no pics due to Photosuck, but you can read through this to get the gist.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/165668.aspx
    July 2003
Posted by ridleusmc on Wednesday, September 13, 2017 9:21 PM
^ Thank You LawDog!  Great work on the 190, 109, and F4U!
    March 2015
Posted by Toshi on Friday, September 15, 2017 3:25 AM
I love how you added the little diorama to your 190 build.  That sir is an excellent finish!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    September 2013
Posted by blackdog62 on Friday, September 15, 2017 8:58 AM
Howdy lawdog fine build and info also thank you for showing us.
Did you know that testors in there model master arcrylic line of paint they have clear coats in gloss and flat. No smell easy clean up. I use the 2 mixed how ever I want to make different Sheens.
They spray nice lay down good and I have no problems with them. So if your still looking givem a try.
Jerry.
    September 2017
Posted by Kien on Friday, September 15, 2017 11:42 AM
Hey lawdog,
I was wondering how you do the fading on the camoflauge to have tonal variation. I use tamiya paints with a badger 105 at 12 psi and was not really managing to get a nice result, little much of speckles. Do you need to thin the paint much more when you do the shading/variation? If so what ratios? I have wanted to get my hands on mission model paints but my LHS doesn't have them... where do you purchase yours?
Kien
 Youtube Channel:                                                       https://www.youtube.com/channel/UCkcc2P3-PluSdehvVCEKLdw
    February 2012
Posted by lawdog114 on Sunday, September 17, 2017 10:28 PM
Kien
Hey lawdog,
Kien
Thanks guys,
B-dog, thanks for the suggestion.
Kien, I bought mine directly from their website, missionmodelsus.com.  I think that's the only place you can get it.  It doesn't require much thinning, perhaps a drop or two. Unfortunately I'm not familiar with your airbrush.  I use a gravity fed Iwata and generally spray in close at about 15 psi.  I basically bought Mission's tan (Britsh Sand I believe) for the RLM 74 and plain white for the RLM 75, to lighten them.  I then shaded it in to simulate fading.  I like Tamiya paint too, but have no luck mixing their RLM colors.
    September 2017
Posted by Kien on Sunday, September 17, 2017 10:43 PM
Lawdog, seems like I should give a try at some other paints. I only use tamiya. I'd like to try gunze, mission models, and tamiya with the laqcuer thinner. Probably time to experiment on some older kits to find out my niche of paints.
Thanks
    June 2013
Posted by bvallot on Wednesday, September 20, 2017 8:16 PM
Damn Joe. You sure got these 190s licked huh. This looks like it's down to a science now. That new paint looks like it's winning some high marks in those completed pics. Very very nice Joe. I think 1:32 is your new home maybe. =]
Damn sexy 190.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2012
Posted by lawdog114 on Thursday, September 21, 2017 3:29 AM
Thanks B...this one is actually 1/48. I do have the big Hasegawa A-8 in the stash which is scheduled to built soon.
    June 2013
Posted by bvallot on Thursday, September 21, 2017 10:59 AM
Really?! Damn Joe. That is damned pretty to look at. Hats off to you.
On the bench:
    February 2012
Posted by lawdog114 on Tuesday, September 26, 2017 2:52 AM
Thanks Britt
