1/48 Pro-Modeler P-47N Complete
    June 2014
Posted by BrandonK on Tuesday, October 3, 2017 12:59 PM
Well, I've been rather busy lately and I just haven't had much bench time and for that reason this one took a great deal longer than intended. But alas it is done.
This kit went together without any real fuss and the only issue I ran into was the old decals fell apart and I was able to save only the nose art and tail numbers. I had some extra P-47 decals and I was able to use those to make up for the lost ones from the kit.
I painted it with Alclad and Gunge paints. I coated the Gunge in flat clear and the Alclad in Semi gloss and I like how it came out.  From the photos I could find of this AC it was well maintained and in good condition so little weathering was needed and that saved me some work. I hope you enjoy it.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2017
Posted by Chemteacher on Tuesday, October 3, 2017 1:28 PM
Beautiful finish. I like the blue/black against the NMF.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
Posted by keavdog on Wednesday, October 4, 2017 3:48 AM
Really nice work- great looking model!  Well done and congrats!
Thanks,
John
    May 2006
Posted by Shipwreck on Wednesday, October 4, 2017 5:56 AM
Very nice Brandon!
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    January 2017
Posted by damouav on Wednesday, October 4, 2017 7:12 AM
Well done Brandon, excellent build.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    January 2015
Posted by Aggieman on Wednesday, October 4, 2017 7:17 AM
That's a good-looking T-bolt.  Nice effect on your NMF.
Posted by Gamera on Wednesday, October 4, 2017 7:27 AM
Super job! The NM looks perfect. I don't think I've seen many USAAF fighters with the light blue trim, love the look of it though. Heart
Posted by echolmberg on Wednesday, October 4, 2017 9:11 AM
Ditto  Gotta agree with everyone here.  Fantastic build of a awesome plane.  I'm working on the very same kit as we speak and I hope it turns out as well as your did.  I'm a slooooow builder though so it's going to be another month before I finish it.
What did you use for your Alclad base coat?  I used the Tamiya grey primer out of the rattle can.  It goes on glass smooth but, for the first time, I actually used polishing cloths to give it a glass-like surface.  Then I applied a thin layer of Testor's Gloss Black and that, too, was polished.  So that's where it stands at the moment.  My next step is to apply Alclad Airframe Aluminum.  I'm rather nervous about using Alclad and I hope I don't botch up what has, to date, been a really good build.
Eric
    June 2014
Posted by BrandonK on Wednesday, October 4, 2017 9:22 AM
echolmberg
I use Alclad black base and micro filler. It needs to be put on heavy and wet otherwise you have lifting issues with it. Once I give it at least 24 hrs cure time I hit it with 3000 grit padded autobody sanding paper you can pick up at Walmart. This knocks down all the issues on the surface and makes it super smooth and it makes the surface dull in some spots and still glossy in others which helps with the NMF effect. I then shoot the alclad over that in a few very light coats until I get the effect I want and I then seal that with Alclad Aqua Gloss before adding decals. It took me several Alclad adventures before I found this method worked for me. As with all painters you just have to play around with things until you find a method that works well with your painting style.
I hope this helps.
Thanks for all the kind words they are always appreciated.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    June 2013
Posted by bvallot on Wednesday, October 4, 2017 11:26 AM
I'm really loving all these posts about Jugs! Must be a GB going on =P
Nicely done NMF BK.
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2005
Posted by RadMax8 on Wednesday, October 4, 2017 11:54 AM
Pretty unique scheme on your P-47N. I really like how it looks. I've got two of these kits in my stash, I'll definitely have to look and see if I've got decals for this one. Nice work!
    January 2015
Posted by BrandonD on Wednesday, October 4, 2017 11:57 AM
Nicely done, Brandon! Love tghis bird.
-BD-
    February 2012
Posted by lawdog114 on Wednesday, October 4, 2017 8:06 PM
Very well done. Thanks for sharing.
    August 2016
Posted by Keyda81 on Wednesday, October 4, 2017 9:06 PM
Beautiful!
    July 2012
Posted by littletimmy on Wednesday, October 4, 2017 9:34 PM
She's a pretty one all right !!!!!
What's the "Drinkin Sister " dirinking?         I'm buying !
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
Posted by jeaton01 on Wednesday, October 4, 2017 10:58 PM
Very nice, Brandon.  Skill and patience have been well rewarded on this one.
John
    August 2013
Posted by Jay Jay on Thursday, October 5, 2017 5:31 PM
Beautifully flawless NMF finish. Well done Mate
    March 2015
Posted by JohnnyK on Thursday, October 5, 2017 7:14 PM
Very nice looking model!  The NMF came out very nice.
    March 2015
Posted by Toshi on Saturday, October 7, 2017 4:16 PM
Looks fantastic sir.  Need I say more?
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    June 2014
Posted by BrandonK on Saturday, October 7, 2017 7:10 PM
You are all too kind.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
