Monogram B-24D Liberator 1/48 - Assembly Ship "First Sergeant" Complete
    January 2015
Posted by Aggieman on Sunday, October 15, 2017 12:58 PM
I remember when this kit was first released way back in about 1976.  Found it under the Christmas tree that year and probably spent about 2 hours putting her together.  Those were the days where a tube of Testors cement was all I needed; I had not yet started painting models. I want to say I built a second one some time during my childhood, but my memory is getting a bit fuzzy on some of those details.
So a few years ago, my dad asked what I would like for Christmas.  Since I have pretty much everything, I hemmed and hawed, and finally said something about a Liberator. Lo and behold the man got me not one, but two Liberators.  Well, I really don't need two of these beasts, so the second one remains wrapped in celophane and may end up on the selling block.
Here is the kit:
I spent a good bit of the summer months building two 1/32 Spitfires, and was really just looking for a quick build.  I've had my eye on a number of the old Monogram big bombers that I have in my stash, and those dual B-24s stood out.  So I pulled out the one that I had opened that Christmas with my dad.  When I do these big bombers, I always opt to build wheels up since I have no shelf space big enough to display these bad boys, so they are going "in flight mode" on the ceiling in my workshop.  As such, I made a determination that, in light of being a quick build, I was going to cut a lot of corners, not spend as much time detailing the interior (not ever going to be seen hanging from that ceiling, I reasoned).  I left out the majority of the interior parts other than the cockpit; no bomb bay, for instance, as I decided to display this Liberator with the bay doors closed.
Now what scheme to build?  The B-24 has a variety of great-looking schemes.  I had built a Ploesti bomber of the Pro-Modeler release from the late 1990s in a desert sand scheme, so I knew I didn't want to repeat that.  When I got to poking around, one scheme kept popping up that I found very intriguing.  It is also very unusual and one that I have rarely seen modeled.
The weather in England is often quite dreary, and visibility is rarely prime.  In addition, when the USAAF would send its fleet of bombers to visit targets in Western Europe, these bombers were coming from bases scattered across a wide area of Southern England.  They could not just take off and head straight for their targets; they would be sitting ducks to the guns of the Luftwaffe.  These bomber formations had to form up to travel as a group, where they were still pretty much sitting ducks but at least had some strength in numbers.  To form up they were looking for what came to be known as "assembly ships" - these were worn out bombers painted in garrish, bright, and almost obscene schemes.  Here is a great web site that speaks about these assembly ships:
http://www.vintagewings.ca/VintageNews/Stories/tabid/116/articleType/ArticleView/articleID/477/Polka-Dot-Warriors.aspx
I decided to build "First Sergeant", the first lead assembly ship of the 458th Bombardment Group, USAAC Serial No. 42-40127.  She was originally christened with the name "Thar She Blows Again" and had participated in the Ploesti raids in 1943.  During that raid she was hit by flak but managed to return to Algeria, where the raid originated, safely.  At some point she was assigned a new crew and stationed to the 458th in England under the new name "Bucket of Bolts".  When she was transitioned to the lead assembly ship role, she lost all of her armament and was painted with red, blue and yellow polka dots over white, neutral gray and olive drab.  Her job was to "take off before the other combat aircraft, and then lead them into a combat formation which would provide maximum coverage for each ship."  On 27-May-1944, while loading flare guns, a flare gun mis-fired which ultimately burned her to non-flight-worthy status; the crew was not aboard at the time and escaped injury.
So I was left with the daunting task of painting all these polka dots.  My focus was pretty much on that, and consequently I did make one very noticable mistake that I will point out shortly.  In any event, I experimented with a variety of methods of painting all these polka dots.  First effort was to use a hard-plastic circle template, but I quickly disacarded that when it became apparent that the template would be useless along all the curved surfaces of the fuselage, top and bottom.  Next up, I used my circle cutter on tape, and was actually going along pretty well when I noticed that my circles were not exactly right.  I'm still not sure what happened, but I think that I was simply losing my focus on that task and the cutter was slipping on me, which was resulting in oblong circles rather than proper 360 degree circles.  Finally, I remembered that we had sheets of circle stickers that, as it turned out, were a good size for use on my Liberator.
After putting down white Stynlyrez primer, I put down a coat of Model Master insignia red over all the surfaces where there would be a red polka dot, followed with a coat of Future (I was not sure how much sticking power these circle stickers would have).  Once the Future cured, I placed the circle stickers to mask red polka dots.  This was a laborious task that I probably could have done a better job at.  Next I put down another coat of white primer, then painted the forward section of the fuselage and the upper surfaces of the wings Model Master insignia blue, and the rear sections of the fuselage as well as the stabilizer and rudders Model Master insignia yellow, then after another coat of Future cured, I put down a second set of circle stickers for the blue and yellow polka dots.
Yet another coat of Future, then I paited the olive drab/neutral gray along the rear section of the fuselage, stabilizer and rudders, and Tamiya flat white on the forward fuselage section.  Finally I masked off the wings and stabilizer for the black de-icer boots.  Once everything dried sufficiently, I lifted all those circle stickers.  No paint lifted, although for the red polka dots, I did note that the stickers seemed more cured to the surface, probably because they had been hit with a coat of Future.  But I was able to get all the stickers off with no resulting problems needing re-painting, thankfully.
The mistake I made due to my focus on these polka dots had to do with the white circles for the big letter K.  I didn't pay attention as closely as I should have, and painted the white circle on one of the rudders on the lower half of the rudder rather than the upper half where the photos show it to have been.  When I noticed it, I was already done with the painting and thought, eh, well, it's not like they had Michelangelo out there painting these bombers.  So rather than re-painting, I just left it as is.
I opted to paint the remaining parts - props and canopy frames - and put a little oil staining under the engine nacelles.  That was all I wanted to do for this one.  I didn't use any putty on this build even though it needs it, nor did I work on the seams anywhere as I typically would.  One of the fuselage seams actually looks like it is a panel line, but one on the upper surface is one I typically would have made go away, but since it would never be visible from the floor, I'm not sweating it.
One final thing.  I say this as a big fan of Monogram kits, and one who grew up building them.  These kits have not aged well.  There were lots of bad fit problems with this B-24, and there was a tremendous amount of flash.  I'm really wanting to never build another Monogram (recent) re-release again.  I have many of their kits that were first sold back in the 1960s in the baby blue boxes, and having built a couple, one can easily see the difference in the molds between then and now.  I do still have a few newer re-releases in my stash, but it's very possible that I won't actually build those given all the frustrations I had with this kit.
Any way, on to my build photos.  She is wheels up, so I have her displayed for most of these pictures balanced on my airbrush stand, although I have cropped out most of that stand.  I hope y'all enjoy.
Finally, here are a couple shots of her leading out my fleet of heavy bombers, a B-36, a B-52, a B-36, a B-17, and the aforementioned Ploesti raider B-24 (which is not clearly visible, although you can just see its tail in the second picture poking out from behind the B-52).  Not exactly accurate as per history ...
I'm going to take some time away from the bench, but next up will be my final build for 2017, Hobbyboss' A7A Corsair II.  That will conclude my year of Allied/US warbirds, and next year I'm thinking of building only Axis warbirds.
    July 2012
Posted by littletimmy on Sunday, October 15, 2017 1:31 PM
Kind of remind's me of a loaf of Wonder Bread.
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    January 2015
Posted by Aggieman on Sunday, October 15, 2017 1:57 PM
littletimmy
Yeah, when I brought it into the house to show my wife, I introduced it as the "Wonder Bread" bomber.  She laughed.
Posted by Bish on Sunday, October 15, 2017 2:07 PM
Great looking build, you have finished that nicely. I have a set decals for various B-24 lead ships including this one. Nice to see what it wil look like if i decide to do it.
    January 2015
Posted by Aggieman on Sunday, October 15, 2017 3:28 PM
Bish
Thanks.  I actually did not use any decals on this build.  There should be a yellow Z on each of the rudders and a US insignia on the underside of one of the wings.  I didn't find any other photo evidence of other markings, so with my lackadaisical attitude toward this build, I decided not to even bother with markings.
Posted by Bish on Sunday, October 15, 2017 4:32 PM
The set i have users masks for the dots in the same way you have made your own. There is an alternative scheme without the dots, but then wheres the fun in that Big Smile
    July 2010
Posted by docidle on Monday, October 16, 2017 12:08 AM
Dang Aggie, that is some fine painting there! I also love your Air Force.
Doc
    March 2015
Posted by Toshi on Monday, October 16, 2017 2:58 AM
Great job on the idea of the polka dots.  I really liked the scheme!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Gamera on Monday, October 16, 2017 7:13 AM
Oh wow! I've always loved these assembly ship schemes but never had the guts to tackle one- great job!!!
    June 2014
Posted by BrandonK on Monday, October 16, 2017 9:02 AM
What a great looking build. That has to be one of the craziest schemes I've ever seen. You're attention to detail really shows through on this one.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2017
Posted by Chemteacher on Monday, October 16, 2017 5:58 PM
Wow! Great job. I also like your work space. Good to see others that have to do in-flight display due to space. Almost all of mine end up that way. Great job.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2015
Posted by Aggieman on Monday, October 16, 2017 10:07 PM
Chemteacher
Thanks chemteacher!
As for my display space, that is only one of them. I have two opposing air forces flying at each other, although only one can be seen in the pictures. This is all in the third bay of my three-car garage, otherwise known as my workshop/storage bay. But I also have a big lighted display cabinet inside, as well as a warbirds room in an upstairs bedroom. I have a great wife who tolerates all these airplanes all over her house. And it was my wife who suggested an addition to our guest bathroom, which is done up with a bunch of French decor that we inherited from my mom after she passed. My wife suggested I add a German bomber in there, so there is a huge 1/32 Heinkel He 111 mounted on the wall opposite some prints of famous Parisian structures. I call it my bathroom bomber.
    January 2015
Posted by Aggieman on Monday, October 16, 2017 10:12 PM
BrandonK
BK
Thanks Brandon. All the detail is in that paint job. I actually did the bare minimum everywhere else.
    January 2015
Posted by Aggieman on Monday, October 16, 2017 10:14 PM
Gamera
Thanks Gamera. I always knew about these assembly ships, but I never knew the details. And I always considered it sacrilege to paint such wonderful heavies in this fashion, but now that I know more of their story, I am happy that I did it.
    January 2015
Posted by Aggieman on Monday, October 16, 2017 10:15 PM
Toshi
Toshi
Thanks Toshi. It is certainly an eye catching scheme.
    January 2015
Posted by Aggieman on Monday, October 16, 2017 10:17 PM
docidle
Doc
Thanks docidle.  In the picture you can see the big B-36 that I consider among my best work. That thing was literally a beast, one that I could barely keep on my work bench.
    April 2013
Posted by Greatmaker on Tuesday, October 17, 2017 3:03 PM
littletimmy
Glad I'm not the only one to have that thought.  It definitely is an eyecatcher.  Wonder what the Germans would have thought of that scheme if that saw that coming over to do some bombing Terrific job on the build.  After I built mine I thought no more big Liberators for me.  I don't have the guts and/or skill to pull off that scheme
    February 2012
Posted by lawdog114 on Wednesday, October 18, 2017 8:42 PM
Well done loaf of Wonder Bread. It's making me hungry for a sandwich. Indeed the late releases are brutal. Not sure why they bother. Your way better off finding an early production one, particularly their P-40 or P-61. Thanks for sharing.
