Ok, I got started on this one for the Pride of the Luftwaffe Group Build. I am building the 1/48 Eduard Bf-109E-3 in Condor Legion markings from this boxing:
I'll be building the box art version, because it has a beer mug the pilot put on the plane in reference to a game that used to be played in the U.S., where he had spent time, that revolved around drinking beer.
I started last night with some small cockpit buildup before I went to painting base coats.
I primed it with Mr. Surfacing Finisher 1500 Black, then sprayed it with Mr. Paint RLM 02. I'm not sure about the color, so I'm curious what you all think of the shade. It's a little different from Model Master RLM 02, which lookes pretty close to my eye, but in the end, I just really like the way Mr. Paint sprays, so I opted for it over Model Master.
One thing I'm certain of is that the Eduard color PE gray looks pretty far off from RLM 02 to me, so while I will use it on the instrument panel, I am not using the switches on the right side of the cockpit and will opt to paint them instead.
I'm not going to weather this pit too heavily, as the pilot (and presumably the plane, as an E-3) arrived pretty late, and he didn't score any kills in the Spanish Civil War.
I built the shell of the engine, which is needed to hold the prop and exhausts, but I omitted most of the detail parts simply because I'm building this one with the cowl on. I already built one of their E-4s with the engine and guns exposed, which was fun.
As of now, it sits with the wing halves together, and I will do it with neutral ailerons, dropped flaps and extended leading edge slats.
That's all for now.
-BD-
