I find myself between projects at the moment. This one has been giving me the evil eye from the shelf so I figured I'd drag it out again. It got back burnered over a year ago when the back of the spinner went missing and getting a replacement from Hasegawa was impossible at the time (probably still is....Hasegawa is not known for good customer service). I figured I'd wait until I found a reasonably priced kit on ebay then I'd use it to fabricate a new spinner back out of scrape styrene....a visual reference if you will. So I got cracking....
I left off after I sprayed the airframe Alclad Duraluminum. If you recall, this will be a experiment with chipping fluid. I'm going to go for heavy chipping without overdoing it...if that's possible. I will be using this stuff, which is essentially the hairspray method so I'm told.
I sprayed the stuff on the NFM and let it dry. I forgot I bought Montex for this project, so out those came. I painted the appropriate color then masked thusly. I also added the wing walk stripes and yellow leading edge markings and taped them off.
The underside will remain NMF, but the upper will be XF-11 JN Green. I did a little preshading.
I then added the JN Green. It's quite dark and covered most of the preshading. I added some XF-57 Buff and faded it a bit.
After removing the masks, I got to the chipping. I wanted it in certain areas, like heavier on the port wing root, a bit on front cowl, and more on leading edge wing root where the prop would blow stuff back. Again, I didn't want to go crazy with it. I wet an old Testors stiff paint brush and started rubbing some off. The water helped break up the paint and I was surprised about the control I had. I was fairly happy. I stopped here with the risk of overdoing it.
The underside got some attention too. I sprayed the control surfaces XF-76 IJN Grey Green to simulate the fabric and also sprayed some panels different shades of Alclad. This will get dirtied up later.
A few coats of Alclad Aqua Gloss went down to seal everything. I still have a couple decals that need to go down.
Overall I'm quite pleased with how this stuff works. I think I got the look I was going for. I see more in the future.
