Early P-51D Wheel Well Color
    February 2013
Posted by tomwatkins45 on Tuesday, March 27, 2018 2:56 PM
I'm building the Tamiya 1/32 Mustang as a P-51D-5. I think, based on the research I've done, that the main gear wells "should" be unpainted aluminum with a yellow zinc chromate main spar. At some point, due to corrosion problems, they would have started painting the wheel wells green zinc chromate, but I think this was after the D-5's were built. Does this sound reasonable? I'd like to get it as accurate as I can.
Thanks,
Tom
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, March 27, 2018 5:55 PM
It would be safe to say they were overall either/both (depending on the aircraft) yellow and/or green zinc chromate. Either one is suffice and I wouldn't worry too much about spot on accuracy.
Posted by jeaton01 on Wednesday, March 28, 2018 12:24 AM
Here are some photos of the wheel well on a very authentic restoration, later than a D-5.  Not Kimmberly Kaye at the top, Daddy's girl lower down.
http://www.yolo.net/%7Ejeaton/Propplanes/p51/p51.htm
John
    February 2013
Posted by tomwatkins45 on Wednesday, March 28, 2018 7:45 AM
Thank you both for your responses. With the changes that were made during the production runs and the field repairs and repainting it's hard to pin down. "Nobody knows for sure" is a pretty good answer. I think I'll go with overall yellow zinc chromate with green zinc castings.
Thanks,
Tom
    February 2012
Posted by lawdog114 on Sunday, April 1, 2018 4:23 AM
My research showed that they all came from the factory in aluminum and the rear spar was the only part in ZC.
    February 2013
Posted by tomwatkins45 on Sunday, April 1, 2018 6:18 AM
That's what my research showed also. Dana Bell says "At some point" in the P-51D/K production runs they started painting them due to reports of corrosion problems, but exactly when is undeterminable.
Thanks,
Tom
    February 2012
Posted by lawdog114 on Thursday, April 5, 2018 11:40 PM
Indeed.....I'm considering painting the whole bay ZC on my F-51 for the same reason.
    January 2017
Posted by damouav on Friday, April 6, 2018 4:40 AM
lawdog114
Mate, do you have a specfic colour your going to use for the ZC. I'm  building a P-51D/K for the Comenwealth GB and will also need the exact same paint.
Thanks
Damian
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    February 2013
Posted by tomwatkins45 on Friday, April 6, 2018 5:16 PM
Since I'm kind of a dinosaur, I still spray lacquers and enamels. I use Model Master green zinc chromate and Testors 1/4 oz. small bottle yellow zinc chromate. I add just a little green to the yellow zinc to make it a bit less yellow.
Tom
    January 2017
Posted by damouav on Friday, April 6, 2018 8:16 PM
tomwatkins45
Tom
I prefer acrylic or lacquer based paint, due to ease of cleanup. The variety I have found for the two types of Zinc Chromate are:
Yellow ZC
Tamiya XF-4
Mr. Paint MRP-129
Model Master ?
Mission Models MMP-067
Green ZC
Tamiya XF-3:2  XF-5:1
Mr. Paint ?
Model Master 4852
Mission Models MMP-068
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    February 2012
Posted by lawdog114 on Saturday, April 7, 2018 11:52 PM
damouav
lawdog114
Thanks
Damian
Yep...Tamiya XF-4 Yellow Green is the perfect ZC shade to my eye.
