Wasp WIP
Wasp WIP
Posted by Don Stauffer on Thursday, May 10, 2018 3:44 PM
Got my bench cleaned up after putting last project aside, and ready to go with the Wasp.  Actually, I had glued two cylinders together to see how much of a job it is.  I remember it being a bit of a job on my previous build, but that was a long time ago.  And this time I really want to work on getting the fins even!
My workbench has a particle board top, and a good and proper cleanup involves pulling up the Contact shelf paper finish and replacing it with new stuff.  Gets rid of all the paint spills, glue gobs and whatnot in about half an hour or less.
    November 2008
Posted by mrmike on Thursday, May 10, 2018 4:59 PM
Looking forward to your build!
    March 2015
Posted by JohnnyK on Thursday, May 10, 2018 7:07 PM
That looks like an interesting build. I never heard of the Williams Brothers Model Co. It seems like they make large scale models like your kit and parts for  RC airplanes. Here is their website: http://www.wmbros.com
Posted by keavdog on Thursday, May 10, 2018 9:23 PM
I'll be watching Don!  Mine's in the closet currently.
Thanks,
John
Posted by Don Stauffer on Friday, May 11, 2018 8:29 AM
JohnnyK
They also made airplane kits.  One specialty I really liked were racing planes.  I see so many available now that the new owners must be repopping those too.  They were/are 1:32 scale, which is nice because those racing planes were pretty small.
    July 2016
Posted by Johnny1000 on Friday, May 11, 2018 8:46 AM
Hi Don
Looking forward to seeing what you do with this
In the meantime, I like your bench--very businesslike. I also appreciate clearing the decks before starting a new project. I do that as well, and often just after a session, or even in the middle, so I have a clean slate.
cheers
-J
Posted by Don Stauffer on Sunday, May 13, 2018 11:30 AM
Mea Culpa!  I had remembered (gee it had been a long time since I built that first kit) as a Wasp Jr.  It isn't- it is the big Wasp, the 1340.
Posted by Don Stauffer on Tuesday, May 22, 2018 10:27 AM
Okay got  some more work done.  Front case glued to crankcase, and intake manifold halves glued together, seams filled, and primed.
The manifold was a bear!  It warped easily, and I had to glue the halves together in two operations to maintain decent alignment.  A lot of flash made cleaning the holes where the intake pipes fit.  Some areas were so bad I had to make plastic "washers" to make the hole circular and fit the pipes.  Above you see the pipes ready for priming.
Posted by Gamera on Tuesday, May 22, 2018 11:29 AM
Oh wow Don that bench is waaaaaaayyyyyyy too clean- gives me a headache to look at it!!!
Good to see you with a new project to get it messy again!
Looks good so far. Seems like it'll be some work getting everything aligned proper and straight.
    July 2014
Posted by modelcrazy on Tuesday, May 22, 2018 1:13 PM
Hey Don, sorry I missed this. I have the WB Cyclone.
I'll be watching.
Steve
Posted by keavdog on Tuesday, May 22, 2018 9:58 PM
Looks really nice Don
Thanks,
John
Posted by Don Stauffer on Wednesday, May 23, 2018 8:44 AM
Gamera
I just pushed everything aside to clear a little area in the front of the bench to take the picture.  It is messy again already.  The reason the surface is so clean is that I refinish the surface each couple of models with contact paper.  My bench becomes really bad with glue gobs and paint drips and spills, and  I needed a fast way to refinish it.
And Steve, I'd love to do the Wright!  I had already done one Wasp, and wrote them encouraging them to repop the Wright.  But when the Wasp came out first, I took a look at mine and determined I could use the skills I had obtained in the 20+ years since then to do a better Wasp.  Really looking forward to the repop of the Wright.- why don't those of you want the Wright also write WB, the more emails and letters they get, the better
Posted by Don Stauffer on Tuesday, May 29, 2018 9:19 AM
Got the crankcase assembly painted, and all of the cylinders cleaned up and ready for painting.
Got the lower section of the cylinders painted, and they look great.  I am now contemplating painting whole cylinder that color of blued steel, instead of the aluminun color I had originally planned.  I see so many color combinations of Wasp cylinders!  I wish I knew what metals were used in which areas of the cylinder, and what process was used to get that color.  I am sure the lower part of the cylinder was blued or other chemical treatment, but do not know what were used on various others in the upper cylinder and head area.  Having a tough time finding the info.  And I assume many of the engine pictures I see these days are overhauled/re-manufactured engines with processes that didn't exist back in days when engine was manufactured.
    July 2014
Posted by modelcrazy on Tuesday, May 29, 2018 4:23 PM
Oh, I  never thought of them being blued. What would you use, gunmetal? I'm intrested in seeing what you do with them.
Steve
    June 2014
Posted by BrandonK on Tuesday, May 29, 2018 9:28 PM
Oh cool !! I wanna hear it run.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2015
Posted by Toshi on Wednesday, May 30, 2018 4:09 AM
Looking forward for you to add some fuel to it to start her up sir!
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
Posted by Don Stauffer on Wednesday, May 30, 2018 9:03 AM
modelcrazy
I mixed up a concoction, a mixture of Testors Gunmetal and gloss blue.  The gunmetal is dead flat, and no color to it at all.  I wanted a touch of blue in it, and a bit of a sheen.  I took the full (new) bottle of gunmetal, which was full up to the neck (square bottle).  I then poured in the gloss blue until it reached halfway up the neck.  This was a first cut, and it worked beautifully.  Picture maybe tomorrow.
Also, I learned yesterday that while the cylinder is one piece steel, the big cooling fins on the top part, and for the head are an aluminum "muff".  The top of the cylinder is threaded, as is the inside of the muff, and they are screwed together.  So I decided to do the top areas of the cylinder in alclad.  I masked off the bottom section with the blued steel and applied Alclad directly over the black plastic.  Worked great!
Posted by Don Stauffer on Thursday, June 7, 2018 8:55 AM
Been working on the cylinders, now that the crankcase is ready to receive them.  Got them all painted now.
Detailing the cylinders is becoming a lot of work!  Every time I think I've got them ready to put into the crankcase I find another widget I have to add.  But one cylinder is now, I am sure, completely finished and ready to mount, though I want to finish them all before gluing them in.
    July 2014
Posted by modelcrazy on Thursday, June 7, 2018 9:16 AM
Oh wow, those look really great Don. Yes
Steve
Posted by keavdog on Friday, June 8, 2018 12:58 AM
Wow looking really nice Don.  Hoping for cliff notes on colors from you so I can do mine as nice ;)
Thanks,
John
Posted by Don Stauffer on Friday, June 8, 2018 8:38 AM
keavdog
On cylinders, bottom part is Testors gunmetal plus Steel.  I started with full bottle of gunmetal, which was full right up to neck. I then added steel halfway up neck.  Mixed well and then thinned for airbrush.  I use a suction feed airbrush so poured fom Testors bottle and thinned in airbrush jar.  Upper part of cylinder is Alclad aluminum, applied directly over kit black plastic.  Rocker box covers are painted gloss black, then Alclad Polished aluminum applied very lightly.  Crankcase is Testors Gray, engine accessories (mags, starter and carburetor) are new Testors semi-matt black.  Handpainting nuts and screws with the gunmetal/steel mix.
    July 2014
Posted by modelcrazy on Friday, June 8, 2018 8:59 AM
Don, I have to say again, they look great. You are really making me want to break out the Cyclone.
Steve
Posted by Don Stauffer on Tuesday, June 12, 2018 2:43 PM
Got all the cylinders on the crankcase now, and some of the accessories on the rear.  First view is the front of engine, sitting on its mount (not screwed down yet).
Next is a shot of the rear, on a mount to hold it (board of mdf with hole drilled for propshaft.
I had finally lost one of the (18) rocker box covers, taking it out of my paint dryer box.  Could not find it.  Made a simple one-piece mold of clay, using one of the others, and cast it in resin.  Matches pretty good after Alclad, huh?
    January 2015
Posted by PFJN on Tuesday, June 12, 2018 4:22 PM
Wow, that's looking great.
1st Group BuildSP
    September 2012
Posted by GMorrison on Tuesday, June 12, 2018 4:30 PM
I think you need to wire those bolts on the bearing cover. But seriously, that looks real. I have no idea which rocker cover is the new one.
A very nice project.
Posted by Don Stauffer on Wednesday, June 13, 2018 8:30 AM
GMorrison
Good idea!  I think I can handle that.
Posted by Don Stauffer on Thursday, June 14, 2018 1:49 PM
Got the engine mounted to the engine mount.  A few tips for anyone building this kit.  Do not put on either the starter or the carburetor before mounting the engine to the mount. If you mount the starter first, you will have trouble getting the mount around the assembly. If you mount the carburetor first, and try to screw in a machine screw to mount the mount to the intake manifold, the carburetor prevents getting a socket type wrench on the screw (see below).  Good luck finding a 0-80 open end wrench that will fit.
A great tip- you can make a great socket wrench for a 0-80 hex head machine screw from a length of 1/8 in (od) aluminum tubing.  Drill a 1/16 inch hole in a block of something- I used a piece of MDF.  Insert the body of the screw into the hole.  Place the piece of tubing centered over the screw head, and tap in it with a small modeler's hammer. The tube will deform over the head, forming a handy wrench.  I wrapped some masking tape over the other end to give a bit more purchase for my fingers.  If you drill a hole in plastic with the normal tap drill, the screw can act as a self-tapping screw.  I used that type of wrench to screw the screw through the mount and into the intake manifold with no problems.  Easy turning, and four or five screws hold the mount tight to the engine (or vis versa).
Posted by Don Stauffer on Wednesday, June 20, 2018 8:48 AM
Been meaning to take more photos, but things are changing rapidly now, and finish is in sight.  However, a warning to anyone else building this kit.  I had already glued the wiring loom into place before I began the ignition wiring- a mistake!  It is almost impossible to get the wires inserted into the loom once the loom is fastened to the crankcase- at least for the top five cylinders!  In trying, I loosened two of the lugs holding the loom to the crankcase, and was then able to break loose the other two.  I found it easy then to cut the two wires that go on the five front openings on the loom, and fasten it back in place on the engine. I will now proceed to wire these to the plugs.
I recommend this procedure rather than trying to wrestle the loom end of the wires into the loom when it is in place on the engine!
The four lower cylinders go to wires fastened to the ends of the loom and this looks like it will work okay with the loom on the engine.  Display stand is already finished.  More pics in a day or so.
Posted by Don Stauffer on Wednesday, June 20, 2018 7:33 PM
All the pushrod tubes are in place and I have cylinder 1 wired- both plugs.  The wiring is every bit as difficult as I feared.  Working with soft vinyl is not fun, and the hole in the plug connector fitting for the plug end is way undersize, you have to push it down hard on the plug till it yields.  But, it is coming.  Here is a shot of the engine front, with one cylinder wired, a couple more connectors in place, and some of the wiring visible behind the cylinders.
    July 2014
Posted by modelcrazy on Wednesday, June 20, 2018 7:41 PM
That's looking fantastic Don Yes
Steve
