Tamiya 1/72nd Mosquito B Mk IV Complete
Posted by Bish on Saturday, November 17, 2018 2:48 PM
I started this year by building my first Tamiya aircraft kit, now i am on my second.
I am replaceing the kit cockpit with a resin one from pavla. The resin replaces the whole front section of the fuselage, which are seperate pieces in the Tamiya kit allowing for the different versions they produce.
Along with resin parts to replace the interior.
I am also fitting a resin bomb bay, also from Pavla.
Even though i have an Eduard PE set with pre painted parts, i decided to only use the IP and paint the rest. The resin parts are a perfect fit, not somthing i am used to with resin cockpits. You can see a gap between the upper and lower sections, behind the pilots seat. This should be blocked off by the end of the bomb bay, and fortunatly the Pavla one does this. But if you don't use the bay, this will need blocking off, which the pavla pit instructions don't mention.
And then with the bomb bay fitted, the fuselage halves were put together. A bit of a tight fit, but nothing major.
Just a little bit of cleaning up of the seams to do before fitting wings and tail.
    March 2013
Posted by patrick206 on Saturday, November 17, 2018 3:36 PM
Hi, Bish - What a great project, coming along very well. I never gave it any thought before, but how does one attach the clear plastic side windows in the resin nose bits? Do you have to rely on something like clear paint?
Looking forward to seeing this one go through your assembly line, I always learn something new and useful to me. Thanks for the photos.
Patrick
Posted by Bish on Saturday, November 17, 2018 4:00 PM
Thanks Patrick. The resin part is exactly like the kit part only with more detail. The clear kit parts fit in from the outside
    May 2009
Posted by Pawel on Saturday, November 17, 2018 4:01 PM
Hello Bish!
Your model is lookin' good! What was your main reason for using the resin here?
Some time ago I got an unusually good deal on a Hasegawa 1/72 Mossie B (not even 7 Euros...). I wanted to build it with the little son of my brother. Ended up finishing it myself, it looked like this when done:
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
Posted by Bish on Saturday, November 17, 2018 4:08 PM
Thanks pawel. I bought the kit at a time when i was just buying AM for every new kit i bought without even looking at it. This resin set does have the advantage of having the entry hatch open and so saving me having to cut the kit, but the kit doesn't really need it.
Nice job on that one, hope mine looks as good.
    May 2013
Posted by Greg on Saturday, November 17, 2018 4:46 PM
Haven't watched you build for a while, Bish. Looking forward to watching this Mosquito go together.
So far , so good.
    August 2012
Posted by Rambo on Saturday, November 17, 2018 7:40 PM
Looking great Bish that's alot of resin.
Clint
Posted by Bish on Thursday, November 22, 2018 2:21 AM
Thanks guys.
Clint, ye, it is a fair bit, thought to be honest the cockpit part is not really needed. The kit is very nice itself and you won't see much in there. But i have learned my lessons sincei bought this a few years back.
    November 2003
Posted by tempestjohnny on Wednesday, November 28, 2018 5:04 AM
Looking great. Haven't built the 72nd scale yet but the 48th was a breeze.
Posted by Bish on Wednesday, November 28, 2018 9:06 AM
Cheers TJ. This one is very nice. Been a while since i updated, but just got the primer on so hope to have some pics at the weekend.
    May 2013
Posted by hogfanfs on Wednesday, November 28, 2018 12:04 PM
Nice surgery Dr. Bish!
I'm looking forward to seeing those in prime pictures.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
Posted by Bish on Wednesday, November 28, 2018 1:20 PM
Thanks Bruce.
Posted by Bish on Sunday, December 9, 2018 5:51 AM
'm slightly over due an update, so here it is.
With everything together and cleaned up, i masked off ready for painting. I use an Eduard mask set designed for this kit, but that set does not take into account the blisters on the side windows so i had to use some liquid mask there.
the cockpit frames were painted interiour green then the kit primed.
And then the camp painted useing Xtracolor enamels.
Now time for the decals.
I also have a single Type B bomb trolley from Flightpath redy for paint.
    November 2010
Posted by Eagle90 on Monday, December 10, 2018 5:43 AM
Looking pretty awesome Bish!  Great work!
Posted by Bish on Monday, December 10, 2018 6:01 AM
Cheers mate.
    November 2008
Posted by plasticjunkie on Monday, December 10, 2018 8:41 AM
Missed this one. She's looking really good specially the office. That bomb cart looks super cool too and will look great in your dio setting.
 GIFMaker.org_jy_Ayj_O
Posted by Bish on Monday, December 10, 2018 8:51 AM
Thanks PJ. I have done a couple of these bomb carts before and they are nice pieces.
    June 2010
Posted by rocker286 on Monday, December 10, 2018 3:47 PM
Excellent job so far, Bish! It's always nice to see a mossie being built.
4badges
Posted by Bish on Monday, December 10, 2018 3:50 PM
Cheers rocker, its about time i built. Though i have just started applying the decals and its official, Tamiya decals suck.
Posted by Bish on Sunday, December 30, 2018 9:04 AM
Time to wrap up this one. I have been going full on to get both this and 2 other builds complete by the end of the year so i can start 2019 afresh and i just about managed it. That along with the issues i have had with all 3 meant i just plowed on and didn't get any updates. But now i am just glad they are done.
I finally got the decals on after digging out the decal sheet from the other kit but even though i was more careful i still had issues with them coming apart in places. I dffinetly won't be useing Tamiya aircraft decals again. I do have 3 more Tamiya mossies which fortunatly i have am marking sets for and i have now ordered some am stencil sets.
Here she is with markings on, main issues is around the wing roundels on one of the right side which have had little bits come away.
I gave it a light weathering, these aircraft arrived new at Horsham St Faith in Norfolk in May 1942 and were only there for 6 months before 105 Sqn moved on, so i wanted to depict an aircraft that had not been long in service. I added a bomb trolley fom Flightpath and just about managed to find 3 figures that fit the scene, though i really am now scraping the barrel.
As you can see, i have not added a name plate. I am having priner issues at the moment so i'll added the plate once thats sorted out.
Thanks for looking and following along.
    April 2010
Posted by redraider56 on Sunday, December 30, 2018 9:57 AM
Very nice, Bish!  Always enjoy seeing your work.
-Matt
On The Bench: 1/48 HK B-17G "Man-O-War II"
On Deck: 1/48 Tamiya P-38H, 1/48 Revell PV-1
Posted by jeaton01 on Sunday, December 30, 2018 10:30 AM
Well done, Martin.  I like the Blenheim too, but too bad about the salt issues.  I've never trusted that method.
John
Posted by Don Stauffer on Sunday, December 30, 2018 10:57 AM
Looks great!
    June 2014
Posted by BrandonK on Sunday, December 30, 2018 11:02 AM
Beautiful work, Bish. That is a super nice build.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    April 2015
Posted by Mopar Madness on Sunday, December 30, 2018 12:44 PM
Bish, your clearing em‘ off the bench! I have quite a few on the assembly line but no time to wrap them up before years end.  Another nice RAF bird to add to your display!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
Posted by Bish on Sunday, December 30, 2018 12:48 PM
Cheers guys.
Posted by keavdog on Sunday, December 30, 2018 12:48 PM
That looks great Bish.  Well done.
Thanks,
John
    January 2004
Posted by ChrisJH666 on Sunday, December 30, 2018 1:33 PM
Looks good Bish
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
Posted by Bish on Sunday, December 30, 2018 2:18 PM
Mopar Madness
I really got stuck in this last week or so, had some time to make up.
