Old Revell 1/72 Thud WIP (Finally Completed)
    November 2008
Posted by plasticjunkie on Thursday, November 29, 2018 9:22 AM
Doing this one for the Bomber GB so figured to post here for those not involved in the GB.
Reviews on this old kit are mixed but as i started on it looks very good for its age (1988). The raised details are light and the molded details look good.
I will be using Print & Scale decals 72-096 that has plenty of options and I think I will go with "Hanoi Special". This Thud scored two Mig-17 kills.
The decal sheet has several options.
Got the 750 pounders glued up and cleaned up. I also scored along the MER and pylon line to have some separation. I also glued up two Mk.20s from the Hasegawa set to ride on the outer stations. Got the seat and pit cleaned up and ready for painting.
The tanks went together and got cleaned up also.
So this Thud will have a MER on the C/L with six 750 pounders, fuel tanks on the middle station and Mk.20s on the outer stations for a typical Nam load.
Got the pit painted. The molded details are VERY tiny and on the faint side but the dry brushing still brought out the instruments.
The fuselage and wings went together really well with an excellent fit. No putty was used at all.
The seat was painted and will get some washes later to help separate the belts from the seat cushions. Looks big in the picture but man that is on tiny seat!
The tires were glued up then had flat spots sanded to mimic the weighted effect.
I grabbed a wood base and glued up some cardboard with Elmers and painted it with craft acrylics. It still needs more touchups and additional details ere and there. The small Thud has been a pleasure to build and is ready for some paint.
I have all the small parts in my plastic baby food container and all will get painted too.
 GIFMaker.org_jy_Ayj_O
    May 2009
Posted by Pawel on Thursday, November 29, 2018 1:48 PM
Hello!
I'll be watching this one!
Too bad it's not the "Cherry Girl", huh, huh...
I'd like to ask you, what does the H stand for in WHIP?
I have the Trumpeter kit in stash, I wonder how does it compare to the kit you're building.
Good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
    November 2008
Posted by plasticjunkie on Thursday, November 29, 2018 2:26 PM
Pawel
Lol auto correct. Sometimes I don’t proof read things and the computer has a mind of its own.
I have the Trumpy G and is a bit more detailed with recessed Panel lines. This scale is small enough that I just may do a couple more.
    November 2003
Posted by tempestjohnny on Thursday, November 29, 2018 3:56 PM
Looks great. Sometimes those old kits get blasted because they are not the latest and grestest
    September 2011
Posted by falconmod on Friday, November 30, 2018 8:26 AM
Cherry girl is on the decal sheet.  unfortunatley if you use that one you have to put a tarp over it if you take to any model shows.
John
On the Bench: 1/72 Ki-67, 1/48 T-38
1/144 AC-130, 1/72 AV-8A Harrier
    November 2008
Posted by plasticjunkie on Friday, November 30, 2018 10:11 AM
tempestjohnny
Thanks TJ. I might get a couple more, way cheaper than the Trumpeter.
    November 2008
Posted by plasticjunkie on Friday, November 30, 2018 10:14 AM
falconmod
John
I was wondering about that since they have a “no nudity” rule.
    November 2008
Posted by plasticjunkie on Thursday, December 6, 2018 6:07 PM
Shot the SEA camo. Polished the paint out with a 2800 pad which exposed the raised panel lines.
I still have to do some touchups here and there then Future the Thud in preparation for decals followed by weathering.
    November 2008
Posted by plasticjunkie on Sunday, December 9, 2018 1:36 AM
Got the bombs painted and weathered up including hand painting the yellow nose rings. Got them attached to the C/L MER.
Got the gears and outboard stations glued down. The mains still need another part attached and painted.
    November 2008
Posted by plasticjunkie on Sunday, December 9, 2018 8:12 PM
I will never use Print & Scale decals again. They are a PITA to work with, they curl up as they are removed from the backing paper and the carrier film is not clear but semi opaque making silvering a real problem. To remedy this issue, Future was brushed on the spot where the decal will go and immediately slid the decal over the wet Future, centering it and then brushing on more Future over the decal. This method gets rid of the silvering and makes the decals look like actual paint.
I have most of the decals on but still have more to apply. This is a very slow process due to the decals curling up and just being stubborn to apply.
The tail codes
The kill marks and misc small decals
Fuselage art
    November 2008
Posted by plasticjunkie on Monday, January 14, 2019 1:10 AM
I finally completed my little Thud and Hanoi Special is ready to go "Downtown". I took  pictures of the dot weathering steps but somehow got them deleted by mistake from my camera so here are the completed views:
The dot filter helped in adding tonal changes to the paint making it look weathered.
I made my own blue formation lights using metal clothing pins and painting the heads in clear blue located under the rudder
and up front. Notice the double Mig 17 kill marks.
Cluster bombs on the outboard stations
and 750 pounders on the CL pylon.
The molded landing lights were drilled out and replaced with gemstones from Hobby Lobby.
The base is pine, stained and the tarmac is made from thin cardboard squares glued with Elmers then painted in varius grey Craft paints. The joint lines were left a tad wide then filled in with an old siringe with black artist oil paint.
Posted by keavdog on Monday, January 14, 2019 1:27 AM
That looks really great.  Just did an SEA camo myself.  Really nice job
Thanks,
John
    August 2013
Posted by Jay Jay on Monday, January 14, 2019 10:31 AM
Greta looking little Thud Ernie.  I always look forward to your W.I.P's partly because of the valuable tips therein ie. fabric pins and gems for lights etc. TY for freely giving all the info.
GAF
    June 2012
Posted by GAF on Monday, January 14, 2019 11:33 AM
PJ> What a great looking Thud!  Well done!
Gary
    August 2012
Posted by Rambo on Monday, January 14, 2019 2:31 PM
Great looking Thud again showing these old Revell kits can still make beautiful builds.
Clint
    November 2003
Posted by tempestjohnny on Monday, January 14, 2019 2:48 PM
You've done it again. Great build
    November 2008
Posted by plasticjunkie on Monday, January 14, 2019 5:58 PM
Thanks gents.
JJ the lights are super easy to create and the clear paint actually makes it look like a lens.
    August 2013
Posted by Jay Jay on Tuesday, January 15, 2019 10:29 AM
I'm honored that you used my initials on the tail LOL
    May 2013
Posted by Greg on Tuesday, January 15, 2019 10:46 AM
Nice work! Thanks for sharing the build here, Ernie.
    November 2008
Posted by plasticjunkie on Tuesday, January 15, 2019 8:06 PM
JJ
I figured you'd like that LOL.
Greg
Thanks for dropping in!
    August 2015
Posted by crown r n7 on Wednesday, January 16, 2019 6:54 AM
Beautiful job on that F-105 I’m sorry I missed the wip it’s been getting cool in the Miami area . I been out side enjoying the weather before it warms up again.
 Nick.
    November 2008
Posted by plasticjunkie on Wednesday, January 16, 2019 7:54 AM
Thanks Crown. Yea it’s cool up here in Central Fl too, low 40s this morning so I think I’ll head over to Home Depot to load up my Tundra with mulch to refresh the front landscape.
