- Member since
January 2004
1/48 P43 Lancer WIP
Posted by ChrisJH666
on Saturday, January 19, 2019 6:15 AM
Witht the Boomerang basically finished bar the shouting, it is time to start the next project. This one will be interesting! The cockpit will need a fair bit of work and correcting, especially as I intend to finish it with the cockpit open. This will not be the easiest job as the winscreen, canopy, and the area immediately behind the cockpit are a single vacfrom piece. This will also mean rebuilding the area behind the cockpit. The kit engine will be replaced with a Vector one, and as the cowl flaps will be cut out and remodelled open, the engine firewall will have to be moved back to its correct position (it currently fouls the cowl flaps), and I will have to figure out the arrangement of the exhaust at the rear of the engine. Oh what fun!!!!!!!
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
