Tamiya P51-D
    February 2018
Tamiya P51-D
Posted by andy.t on Thursday, January 31, 2019 3:03 PM
I thought I would document this build in a single post. It's my first use of Photo Etched parts.
Here is the seat:
The cockpit:
The fuselage:
All comments welcome.
Andy
On the Bench: Hasagawa HH-60D Night Hawk, Polar Lights Lost In Space Robot
Imagination is Forever
    February 2012
Posted by lawdog114 on Thursday, January 31, 2019 6:04 PM
Not bad. I assume your going to paint the gold on the seat.
    February 2018
Posted by andy.t on Thursday, January 31, 2019 6:09 PM
Yep.
Andy
    February 2018
Posted by andy.t on Saturday, February 2, 2019 2:12 PM
So a couple of lessons learned so far.
1) PE parts are small and difficult to hold on to. I've dropped more than a few.
2) The EDUARD instruction sheets are not the easiest to read, and I need to spend more time studing them and identifying where the PE goes. I initially did the wheel well backwards. It would be helpful if the added the model instruction step where to apply.
Andy
    January 2019
Posted by The Drifter on Saturday, February 2, 2019 2:21 PM
andy.t
Looking good there Andy.
Instead of holding the PE parts in your hand and trying to form them (if that's what your doing), lay them on your bench and use standard razor blades to bend the PE part(s) into position. Eduard IMHO is one of the best in PE parts, and with time you will come to understand their instruction sheets and their placement. Don't let these discourage you from future PE builds.
Jeff
On The Bench: Coming Soon
    February 2018
Posted by andy.t on Saturday, February 2, 2019 3:41 PM
Definately not holding by hand. Trying wax pencil, tweezers and jewelry pickups.
Here is the landing gear I am currently working on.
Andy
    April 2009
Posted by Cadet Chuck on Saturday, February 2, 2019 4:35 PM
Before cutting tiny PE parts off the sheet, I put a piece of Tamiya masking tape under them, and press them down.  Then I cut them from the little attachment points, and remove the tape with the part(s) stuck on it.  It is then easy to lift each part from the tape with a fine point tweezer.  No more launched tiny bits!
    February 2018
Posted by andy.t on Saturday, February 2, 2019 4:43 PM
Finished landing gear. Only took about 3 hours.
Andy
    February 2018
Posted by andy.t on Saturday, February 2, 2019 5:21 PM
Great idea. Thanks for the tip.
Andy
    January 2010
Posted by rob44 on Saturday, February 2, 2019 6:09 PM
I also brush the PE with some vinegar and let it sit for a few minutes then rinse it off. It creates a fine "etching" of the metal so the paint will adhere better.
    February 2018
Posted by andy.t on Saturday, February 2, 2019 6:21 PM
Here is the second landing gear. It only took an hour :)
Andy
    January 2015
Posted by PFJN on Saturday, February 2, 2019 9:26 PM
andy.t
Yikes Surprise
That looks great.  I'd be tearing my hair out if I ever tried something so detailed.
Can't wait to see more of your build.
PF
1st Group BuildSP
    February 2012
Posted by lawdog114 on Sunday, February 3, 2019 1:42 AM
PE is a pain. That's why I mostly use it for seat belts and instrument panels. You'll improve with practice. Looking good Andy.
    February 2018
Posted by andy.t on Sunday, February 3, 2019 3:07 PM
Here is the wheel well. I initially missed these pieces.
Andy
    February 2018
Posted by andy.t on Sunday, February 3, 2019 6:45 PM
Fuel tanks:
Andy
    February 2018
Posted by andy.t on Tuesday, February 5, 2019 3:01 PM
OK that's it for the PE. Next step is Metal Cote Spray which I have never used.
More lessons learned on the PE.
1) Having the right tools is critical. I lacked micro tweezers and this caused me no small amount of crawiling around on the floor looking for dropped parts. I have a set on order now.
2) Of all the ways I tried cutting the PE the Tamiya PE scissors was by far the easiest and best.
All in all the PE looks great, however it is expensive and time consuming. I will use it in the future but only on selected kits.
On to the Metal Cote.
Here is the fuselage primed with Krylon colormaster.
Here is the model with the metal cote applied and dried overnight. Next is the buffing stage.
Andy
    September 2014
Posted by rooster513 on Tuesday, February 5, 2019 3:30 PM
Nice work so far Andy! I really like the fuel tanks. It's that kind of detail that really makes a difference with the finished model. Looking forward to seeing how the Metal Cote comes out buffed!
-Andy
Posted by Ray Marotta on Tuesday, February 5, 2019 3:47 PM
Your Mustang build is looking really good! One small note, the wing skin panels on the real P-51 were puttied smooth to assist with laminar air flow over them. Since you're already "in the paint shop," I wouldn't change a thing. I'm currently building up my courage to do Dragon's 1/32 F-6D Mustang as a post war RF-51D with Eduard's "Big Ed" detail set and cast metal landing gears. I'm going to call it MY Mustang since my Dad was the Crew Chief and I used to sit in the cockpit as a two year old and pitch a fit about being pulled out of it. It's serial number was 511659, side number was FF-659. 15th Tactical Recon Squadron.
    February 2018
Posted by andy.t on Tuesday, February 5, 2019 5:04 PM
Here it is after a light wash of flat black over the panel lines and buffed.
The spray went on grainy but buffed smooth with a cotton swab.
Andy
    May 2013
Posted by Greg on Tuesday, February 5, 2019 7:50 PM
Enjoying watching your progress. You are doing well. Yes
On your coordinating the Eduard instructions with the kit instructions, I guess I always considered that part of the fun. Takes a little bit of studying. As the Drifter mentioned, it'll come easier.
    February 2018
Posted by andy.t on Wednesday, February 6, 2019 6:46 PM
Here she is painted and with a coat of future applied.
Andy
    January 2013
Posted by BlackSheepTwoOneFour on Wednesday, February 6, 2019 7:02 PM
You’re a brave one using Krylon paints. They’re garbage. I’ve had enough kits ruined because of that garbage paint.
    February 2012
Posted by lawdog114 on Wednesday, February 6, 2019 10:57 PM
Looking good. Nailed the blue nose pretty well.
    February 2018
Posted by andy.t on Friday, February 8, 2019 7:40 PM
Here it is finished.
Andy
    January 2019
Posted by Edwin on Friday, February 8, 2019 9:10 PM
andy.t
Is that decal (star emblem) on the wing upside down?
